[QGIS Commit] r13975 - in docs/trunk/english_us/user_guide: . print_composer_screenies
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 28 09:06:08 EDT 2010
Author: dassau
Date: 2010-07-28 13:06:08 +0000 (Wed, 28 Jul 2010)
New Revision: 13975
   docs/trunk/english_us/user_guide/print_composer.tex
   docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_blank.png
   docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_complete.png
   docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_manager.png
finished print composer section
Modified: docs/trunk/english_us/user_guide/print_composer.tex
--- docs/trunk/english_us/user_guide/print_composer.tex	2010-07-28 11:01:11 UTC (rev 13974)
+++ docs/trunk/english_us/user_guide/print_composer.tex	2010-07-28 13:06:08 UTC (rev 13975)
@@ -163,6 +163,10 @@
 activating the \checkbox{Lock layers for map item} checkbox in the Map dialog
 of the Map Item tab.
+\textbf{Note:} QGIS \CURRENT is now able to show labels from the new labeling
+plugin also in the map composer, but it is not yet scaled correctly. So it
+might be necessary to switch back to the standard labeling in some cases.
 \subsection{Map item tab - Map and Extents dialog}
 \begin{figure}[ht]
@@ -377,7 +381,9 @@
 \item The legend items window lists all legend items and allows to change
 item order, edit layer names, remove and restore items of the list. After
 changing the symbology in the QGIS main window you can click on update to
-adapt the changes in the legend element of the print composer.
+adapt the changes in the legend element of the print composer. The item oder
+can be changed using the Up and Down buttons or with Drag and Drop
+functionality.
 \end{itemize}
 \minisec{Item options dialog}
@@ -475,14 +481,13 @@
 \section{Add attribute table values}
-It is possible to add parts of an attribute table of a vector layer to the
-print composer canvas.
+It is possible to add parts of a vector attribute table to the print composer canvas.
 \begin{figure}[ht]
 \centering
-\subfloat[table dialog]{\label{subfig:tabledialog1}\includegraphics[clip=true, width=0.4\textwidth]{print_composer_attribute1}}
+\subfloat[table dialog]{\label{subfig:tabledialog1}\includegraphics[clip=true, width=0.38\textwidth]{print_composer_attribute1}}
 \hspace{1cm}
-\subfloat[general options dialog]{\label{subfig:tabledialog2}\includegraphics[clip=true, width=0.4\textwidth]{print_composer_attribute2}}
+\subfloat[general options dialog]{\label{subfig:tabledialog2}\includegraphics[clip=true, width=0.38\textwidth]{print_composer_attribute2}}
 \caption{Print composer attribute table item tab - Table and General options dialog \nixcaption}\label{fig:attrcomp}
 \end{figure}
@@ -492,7 +497,11 @@
 functionalities (see Figure \ref{fig:attrcomp}a)):
 \begin{itemize}[label=--]
-\item The \textbf{Table} dialog allows to draw an ellipse, rectangle, or
+\item The \textbf{Table} dialog allows to select the vector layer and columns of
+the attribute table. You can define the maximum number of rows to be displayed
+and if attributes are only shown for visible features of the current composer
+canvas. Additionally you can define the grid characteristics of the table and
+the header and content font.
 \end{itemize}
 \minisec{General options dialog}
Modified: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_blank.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_complete.png
Modified: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_manager.png
More information about the QGIS-commit mailing list
