[QGIS Commit] r13976 - in docs/trunk/english_us/user_guide: . working_with_vector_screenies
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 28 11:00:55 EDT 2010
Author: dassau
Date: 2010-07-28 15:00:55 +0000 (Wed, 28 Jul 2010)
New Revision: 13976
Added:
   docs/trunk/english_us/user_guide/working_with_vector_screenies/editNewSpatialite.png
   docs/trunk/english_us/user_guide/plugins_ftools.tex
   docs/trunk/english_us/user_guide/working_with_projections.tex
   docs/trunk/english_us/user_guide/working_with_vector.tex
more manual updates
Modified: docs/trunk/english_us/user_guide/plugins_ftools.tex
--- docs/trunk/english_us/user_guide/plugins_ftools.tex	2010-07-28 13:06:08 UTC (rev 13975)
+++ docs/trunk/english_us/user_guide/plugins_ftools.tex	2010-07-28 15:00:55 UTC (rev 13976)
@@ -149,9 +149,9 @@
  \hline \includegraphics[width=0.7cm]{define_projection} & Define projection &
 Specify the CRS for shapefiles whose CRS has not been defined. \\
  \hline \includegraphics[width=0.7cm]{join_attributes} & Join attributes & Join
-additional attributes to vector layer attribute table and output results
-to a new shapefile. Additional attributes can be from a vector layer or
-stand-alone dbf table. \\
+additional attributes to vector layer attribute table based on a dbf or csv file
+and output results to a new shapefile. Additional attributes can be from a
+vector layer or stand-alone dbf table. \\
  \hline \includegraphics[width=0.7cm]{join_location} & Join attributes by
 location & Join additional attributes to vector layer based on spatial
 relationship. Attributes from one vector layer are appended to the attribute
Modified: docs/trunk/english_us/user_guide/working_with_projections.tex
--- docs/trunk/english_us/user_guide/working_with_projections.tex	2010-07-28 13:06:08 UTC (rev 13975)
+++ docs/trunk/english_us/user_guide/working_with_projections.tex	2010-07-28 15:00:55 UTC (rev 13976)
@@ -38,6 +38,12 @@
 shapefile named \filename{alaska.shp} would have a corresponding projection
 file named \filename{alaska.prj}.
+Whenever you select a new CRS, the used layer units will automatically be
+changed in the \tab{General} tab of the
+\dropmenuopttwo{mActionOptions}{Project Properties} dialog under the
+\mainmenuopt{Edit} (Gnome, OSX) or \mainmenuopt{Settings} (KDE, Windows)
+menu.
 \section{Specifying a Projection}
 \index{Projections!specifying}
 \label{sec:projection-specifying}
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex	2010-07-28 13:06:08 UTC (rev 13975)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex	2010-07-28 15:00:55 UTC (rev 13976)
@@ -1726,18 +1726,18 @@
 \textbf{Note}: If you hold the \keystroke{Ctrl} key pressed, the rotation will be done
 in 15 degree steps.
-\subsection{Creating a New Layer}\label{sec:create shape}\index{editing!creating a new layer}
+\subsection{Creating a new Shape layer}\label{sec:create shape}\index{editing!creating a new shape layer}
-To create a new layer for editing, choose \toolbtntwo{mActionNewVectorLayer}{New Vector Layer} from the
-\mainmenuopt{Layer} menu.
-The \dialog{New Vector Layer} dialog will be displayed as
-shown in Figure \ref{fig:newvectorlayer}. Choose the type of layer (point,
-line or polygon).
+To create a new Shape layer for editing, choose \button{new} >
+\toolbtntwo{mActionNewVectorLayer}{New Shapefile Layer} from the
+\mainmenuopt{Layer} menu. The \dialog{New Vector Layer} dialog will be
+displayed as shown in Figure \ref{fig:newvectorlayer}. Choose the type of
+layer (point, line or polygon).
 \begin{figure}[ht]
    \centering
    \includegraphics[clip=true, width=8cm]{editNewVector}
-   \caption{Creating a New Vector Dialog \nixcaption}\label{fig:newvectorlayer}
+   \caption{Creating a new Shapefile layer Dialog \nixcaption}\label{fig:newvectorlayer}
 \end{figure}
 Note that \qg does not yet support creation of 2.5D
@@ -1745,11 +1745,7 @@
 time, only shapefiles can be created. In a future version of \qg, creation of
 any OGR or PostgreSQL layer type will be supported.
-Creation of GRASS-layers is supported within the GRASS-plugin. Please refer to section
-\ref{sec:creating_new_grass_vectors} for more information on creating GRASS vector
-layers.
-To complete the creation of the new layer, add the desired attributes by
+To complete the creation of the new Shapefile layer, add the desired attributes by
 clicking on the \button{Add} button and specifying a name and type for the
 attribute. Only \selectstring{Type}{real}, \selectstring{Type}{integer}, and
 \selectstring{Type}{string} attributes are supported. Additionally and
@@ -1760,6 +1756,36 @@
 the layer has been created, it will be added to the map and you can edit it in
 the same way as described in Section \ref{sec:edit_existing_layer} above.
+\subsection{Creating a new SpatiaLite layer}\label{sec:create spatialite}\index{editing!creating a new spatialite layer}
+To create a new SpatiaLite layer for editing, choose \button{new} >
+\toolbtntwo{mActionNewVectorLayer}{New SpatiaLite Layer} from the
+\mainmenuopt{Layer} menu. The \dialog{New SpatiaLite Layer} dialog will be
+displayed as shown in Figure \ref{fig:newspatialitelayer}.
+\begin{figure}[ht]
+   \centering
+   \includegraphics[clip=true, width=8cm]{editNewSpatialite}
+   \caption{Creating a New Spatialite layer Dialog \nixcaption}\label{fig:newspatialitelayer}
+\end{figure}
+First step is to select an existing Spatialite database or to create a new
+Spatialite database. This can be done with the browse \button{...} button
+to the right of the database field. Then add a name for the new layer and
+define the layer type and the EPSG SRID. If desired you can select to
+\checkbox{create an autoincrementing primary key}.
+To define an attribute table for the new Spatialite layer, add the names
+of the attribute columns you want to create with the according column type
+and click on the \button{Add to attribute list} button. Once you are happy
+with the attributes, click \button{OK}. \qg will automatically add the new
+layer to the legend and you can edit it in the same way as described in
+Section \ref{sec:edit_existing_layer} above.
+\textbf{Note:} Creation of a new GRASS layer is supported within the GRASS-plugin.
+Please refer to section \ref{sec:creating_new_grass_vectors} for more
+information on creating GRASS vector layers.
 \subsection{Working with the Attribute Table}\label{sec:attribute table}\index{editing!working with the attribute table}
 The attribute table displays features of a selected layer. Each row in the table
@@ -1772,7 +1798,8 @@
 from the menu. It is also possible to rightlick on the layer and
 choose \dropmenuopttwo{mActionOpenTable}{Open Attribute Table} from the
 dropdown menu. This will open a new window which displays the attributes for
-every feature in the layer (figure \ref{fig:attributetable}).
+every feature in the layer (figure \ref{fig:attributetable}). The number of features
+are shown in the attribute table title.
 \begin{figure}[ht]
    \centering
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/editNewSpatialite.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/editNewSpatialite.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
More information about the QGIS-commit mailing list
