[QGIS Commit] r12996 - trunk/qgis/src/plugins/grass/modules-common
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Mar 3 15:00:59 EST 2010
Author: rblazek
Date: 2010-03-03 15:00:59 -0500 (Wed, 03 Mar 2010)
New Revision: 12996
   trunk/qgis/src/plugins/grass/modules-common/v.surf.idw.qgm
   trunk/qgis/src/plugins/grass/modules-common/v.surf.rst.qgm
patches #2438 by lutra
Modified: trunk/qgis/src/plugins/grass/modules-common/v.surf.idw.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.surf.idw.qgm	2010-03-03 19:17:30 UTC (rev 12995)
+++ trunk/qgis/src/plugins/grass/modules-common/v.surf.idw.qgm	2010-03-03 20:00:59 UTC (rev 12996)
@@ -3,7 +3,7 @@
 <qgisgrassmodule label="Inverse distance squared weighting raster interpolation based on vector points" module="v.surf.idw">
 	<option key="input" layeroption="layer" typemask="point,line" id="input" />
-	<field key="column" layerid="input" type="integer,double" label="Attribute field (interpolated values)" />
+	<field key="column" layer="input" type="integer,double" label="Attribute field (interpolated values)" />
 	<option key="npoints" />
 	<option key="output" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules-common/v.surf.rst.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.surf.rst.qgm	2010-03-03 19:17:30 UTC (rev 12995)
+++ trunk/qgis/src/plugins/grass/modules-common/v.surf.rst.qgm	2010-03-03 20:00:59 UTC (rev 12996)
@@ -3,7 +3,7 @@
 <qgisgrassmodule label="Regularized spline with tension raster interpolation based on vector points" module="v.surf.rst">
-	<field key="zcolumn" layerid="input" type="integer,double" label="Attribute field (interpolated values)" />
+	<field key="zcolumn" layer="input" type="integer,double" label="Attribute field (interpolated values)" />
 	<option key="tension" />
 	<!--option key="smooth" /-->
 	<option key="elev" />
More information about the QGIS-commit mailing list
