[QGIS Commit] r12997 - in trunk/qgis/src: app gui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Mar 4 03:56:14 EST 2010
Author: mhugent
Date: 2010-03-04 03:56:07 -0500 (Thu, 04 Mar 2010)
New Revision: 12997
Added:
   trunk/qgis/src/gui/qgsattributeeditor.cpp
   trunk/qgis/src/gui/qgsattributeeditor.h
Removed:
   trunk/qgis/src/app/qgsattributeeditor.cpp
   trunk/qgis/src/app/qgsattributeeditor.h
   trunk/qgis/src/app/CMakeLists.txt
   trunk/qgis/src/gui/CMakeLists.txt
move attribute editor class from app to gui
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt	2010-03-03 20:00:59 UTC (rev 12996)
+++ trunk/qgis/src/app/CMakeLists.txt	2010-03-04 08:56:07 UTC (rev 12997)
@@ -6,7 +6,6 @@
   qgsaddattrdialog.cpp
   qgsattributeactiondialog.cpp
   qgsattributedialog.cpp
-  qgsattributeeditor.cpp
   qgsattributetypedialog.cpp
   qgsattributetypeloaddialog.cpp
   qgsavoidintersectionsdialog.cpp
@@ -123,7 +122,6 @@
   qgsaddattrdialog.h
   qgsattributeactiondialog.h
   qgsattributedialog.h
-  qgsattributeeditor.h
   qgsattributetypedialog.h
   qgsattributetypeloaddialog.h
   qgsavoidintersectionsdialog.h
Deleted: trunk/qgis/src/app/qgsattributeeditor.cpp
--- trunk/qgis/src/app/qgsattributeeditor.cpp	2010-03-03 20:00:59 UTC (rev 12996)
+++ trunk/qgis/src/app/qgsattributeeditor.cpp	2010-03-04 08:56:07 UTC (rev 12997)
@@ -1,660 +0,0 @@
-                         qgsattributeeditor.cpp  -  description
-    begin                : July 2009
-    copyright            : (C) 2009 by Jürgen E. Fischer
-    email                : jef at norbit.de
- *   This program is free software; you can redistribute it and/or modify  *
- *   it under the terms of the GNU General Public License as published by  *
- *   the Free Software Foundation; either version 2 of the License, or     *
- *   (at your option) any later version.                                   *
-/* $Id$ */
-#include "qgsattributeeditor.h"
-#include <qgsvectorlayer.h>
-#include <qgsvectordataprovider.h>
-#include <qgsuniquevaluerenderer.h>
-#include <qgscategorizedsymbolrendererv2.h>
-#include <qgssymbol.h>
-#include <QPushButton>
-#include <QLineEdit>
-#include <QTextEdit>
-#include <QFileDialog>
-#include <QComboBox>
-#include <QCheckBox>
-#include <QSpinBox>
-#include <QCompleter>
-#include <QHBoxLayout>
-#if QT_VERSION >= 0x040400
-#include <QPlainTextEdit>
-#endif
-void QgsAttributeEditor::selectFileName( void )
-  QPushButton *pb = qobject_cast<QPushButton *>( sender() );
-  if ( !pb )
-    return;
-  QWidget *hbox = qobject_cast<QWidget *>( pb->parent() );
-  if ( !hbox )
-    return;
-  QLineEdit *le = hbox->findChild<QLineEdit *>();
-  if ( !le )
-    return;
-  QString fileName = QFileDialog::getOpenFileName( 0 , tr( "Select a file" ) );
-  if ( fileName.isNull() )
-    return;
-  le->setText( fileName );
-QComboBox *QgsAttributeEditor::comboBox( QWidget *editor, QWidget *parent )
-  QComboBox *cb = NULL;
-  if ( editor )
-    cb = qobject_cast<QComboBox *>( editor );
-  else
-    cb = new QComboBox( parent );
-  return cb;
-QWidget *QgsAttributeEditor::createAttributeEditor( QWidget *parent, QWidget *editor, QgsVectorLayer *vl, int idx, const QVariant &value )
-  if ( !vl )
-    return NULL;
-  QWidget *myWidget = NULL;
-  QgsVectorLayer::EditType editType = vl->editType( idx );
-  const QgsField &field = vl->pendingFields()[idx];
-  QVariant::Type myFieldType = field.type();
-  switch ( editType )
-    case QgsVectorLayer::UniqueValues:
-      QList<QVariant> values;
-      vl->dataProvider()->uniqueValues( idx, values );
-      QComboBox *cb = comboBox( editor, parent );
-      if ( cb )
-        cb->setEditable( false );
-        for ( QList<QVariant>::iterator it = values.begin(); it != values.end(); it++ )
-          cb->addItem( it->toString(), it->toString() );
-        myWidget = cb;
-    break;
-    case QgsVectorLayer::Enumeration:
-      QStringList enumValues;
-      vl->dataProvider()->enumValues( idx, enumValues );
-      if ( cb )
-        QStringList::const_iterator s_it = enumValues.constBegin();
-        for ( ; s_it != enumValues.constEnd(); ++s_it )
-          cb->addItem( *s_it, *s_it );
-        myWidget = cb;
-    break;
-    case QgsVectorLayer::ValueMap:
-      const QMap<QString, QVariant> &map = vl->valueMap( idx );
-      if ( cb )
-        for ( QMap<QString, QVariant>::const_iterator it = map.begin(); it != map.end(); it++ )
-          cb->addItem( it.key(), it.value() );
-        myWidget = cb;
-    break;
-    case QgsVectorLayer::Classification:
-      QMap<QString, QString> classes;
-      const QgsUniqueValueRenderer *uvr = dynamic_cast<const QgsUniqueValueRenderer *>( vl->renderer() );
-      if ( uvr )
-        const QList<QgsSymbol *> symbols = uvr->symbols();
-        for ( int i = 0; i < symbols.size(); i++ )
-          QString label = symbols[i]->label();
-          QString name = symbols[i]->lowerValue();
-          if ( label == "" )
-            label = name;
-          classes.insert( name, label );
-      const QgsCategorizedSymbolRendererV2 *csr = dynamic_cast<const QgsCategorizedSymbolRendererV2 *>( vl->rendererV2() );
-      if ( csr )
-        const QgsCategoryList &categories = (( QgsCategorizedSymbolRendererV2 * )csr )->categories(); // FIXME: QgsCategorizedSymbolRendererV2::categories() should be const
-        for ( int i = 0; i < categories.size(); i++ )
-          QString label = categories[i].label();
-          QString value = categories[i].value().toString();
-          if ( label.isEmpty() )
-            label = value;
-          classes.insert( label, value );
-      if ( cb )
-        for ( QMap<QString, QString>::const_iterator it = classes.begin(); it != classes.end(); it++ )
-          cb->addItem( it.value(), it.key() );
-        myWidget = cb;
-    break;
-    case QgsVectorLayer::SliderRange:
-    case QgsVectorLayer::EditRange:
-      if ( myFieldType == QVariant::Int )
-        int min = vl->range( idx ).mMin.toInt();
-        int max = vl->range( idx ).mMax.toInt();
-        int step = vl->range( idx ).mStep.toInt();
-        if ( editType == QgsVectorLayer::EditRange )
-          QSpinBox *sb = NULL;
-          if ( editor )
-            sb = qobject_cast<QSpinBox *>( editor );
-          else
-            sb = new QSpinBox( parent );
-          if ( sb )
-            sb->setRange( min, max );
-            sb->setSingleStep( step );
-            myWidget = sb;
-        else
-          QSlider *sl = NULL;
-          if ( editor )
-            sl = qobject_cast<QSlider*>( editor );
-          else
-            sl = new QSlider( Qt::Horizontal, parent );
-          if ( sl )
-            sl->setRange( min, max );
-            sl->setSingleStep( step );
-            myWidget = sl;
-        break;
-      else if ( myFieldType == QVariant::Double )
-        QDoubleSpinBox *dsb = NULL;
-        if ( editor )
-          dsb = qobject_cast<QDoubleSpinBox*>( editor );
-        else
-          dsb = new QDoubleSpinBox( parent );
-        if ( dsb )
-          double min = vl->range( idx ).mMin.toDouble();
-          double max = vl->range( idx ).mMax.toDouble();
-          double step = vl->range( idx ).mStep.toDouble();
-          dsb->setRange( min, max );
-          dsb->setSingleStep( step );
-          myWidget = dsb;
-        break;
-    case QgsVectorLayer::CheckBox:
-      QCheckBox *cb = NULL;
-      if ( editor )
-        cb = qobject_cast<QCheckBox*>( editor );
-      else
-        cb = new QCheckBox( parent );
-      if ( cb )
-        myWidget = cb;
-        break;
-    // fall-through
-    case QgsVectorLayer::LineEdit:
-    case QgsVectorLayer::TextEdit:
-    case QgsVectorLayer::UniqueValuesEditable:
-      QLineEdit *le = NULL;
-      QTextEdit *te = NULL;
-      QPlainTextEdit *pte = NULL;
-#endif
-      if ( editor )
-        le = qobject_cast<QLineEdit *>( editor );
-        te = qobject_cast<QTextEdit *>( editor );
-        pte = qobject_cast<QPlainTextEdit *>( editor );
-#endif
-      else if ( editType == QgsVectorLayer::TextEdit )
-        pte = new QPlainTextEdit( parent );
-#else
-        te = new QTextEdit( parent );
-        te->setAcceptRichText( false );
-#endif
-      else
-        le = new QLineEdit( parent );
-      if ( le )
-        if ( editType == QgsVectorLayer::UniqueValuesEditable )
-          QStringList svalues;
-          for ( QList<QVariant>::const_iterator it = values.begin(); it != values.end(); it++ )
-            svalues << it->toString();
-          QCompleter *c = new QCompleter( svalues );
-          c->setCompletionMode( QCompleter::PopupCompletion );
-          le->setCompleter( c );
-          le->setValidator( new QIntValidator( le ) );
-          le->setValidator( new QDoubleValidator( le ) );
-        myWidget = le;
-      if ( te )
-        te->setAcceptRichText( true );
-#endif
-        myWidget = te;
-      if ( pte )
-        myWidget = pte;
-#endif
-    break;
-    case QgsVectorLayer::Hidden:
-      myWidget = NULL;
-      break;
-    case QgsVectorLayer::FileName:
-      QPushButton *pb = NULL;
-      QLineEdit *le = qobject_cast<QLineEdit *>( editor );
-      if ( le )
-        if ( le )
-          myWidget = le;
-        if ( editor->parent() )
-          pb = editor->parent()->findChild<QPushButton *>();
-      else
-        le = new QLineEdit();
-        pb = new QPushButton( tr( "..." ) );
-        QHBoxLayout *hbl = new QHBoxLayout();
-        hbl->addWidget( le );
-        hbl->addWidget( pb );
-        myWidget = new QWidget( parent );
-        myWidget->setBackgroundRole( QPalette::Window );
-        myWidget->setAutoFillBackground( true );
-        myWidget->setLayout( hbl );
-      if ( pb )
-        connect( pb, SIGNAL( clicked() ), new QgsAttributeEditor( pb ), SLOT( selectFileName() ) );
-    break;
-    case QgsVectorLayer::Immutable:
-      return NULL;
-  if ( editType == QgsVectorLayer::Immutable )
-    myWidget->setEnabled( false );
-  setValue( myWidget, vl, idx, value );
-  return myWidget;
-bool QgsAttributeEditor::retrieveValue( QWidget *widget, QgsVectorLayer *vl, int idx, QVariant &value )
-  if ( !widget )
-    return false;
-  const QgsField &theField = vl->pendingFields()[idx];
-  bool modified = false;
-  QString text;
-  QLineEdit *le = qobject_cast<QLineEdit *>( widget );
-  if ( le )
-    text = le->text();
-    modified = le->isModified();
-    if ( text == "NULL" )
-      text = QString::null;
-  QTextEdit *te = qobject_cast<QTextEdit *>( widget );
-  if ( te )
-    text = te->toHtml();
-#else
-    text = te->toPlainText();
-#endif
-    modified = te->document()->isModified();
-  QPlainTextEdit *pte = qobject_cast<QPlainTextEdit *>( widget );
-  if ( pte )
-    text = pte->toPlainText();
-    modified = pte->document()->isModified();
-#endif
-  QComboBox *cb = qobject_cast<QComboBox *>( widget );
-  if ( cb )
-    if ( editType == QgsVectorLayer::UniqueValues ||
-         editType == QgsVectorLayer::ValueMap ||
-         editType == QgsVectorLayer::Classification )
-      text = cb->itemData( cb->currentIndex() ).toString();
-    else
-      text = cb->currentText();
-  QSpinBox *sb = qobject_cast<QSpinBox *>( widget );
-  if ( sb )
-    text = QString::number( sb->value() );
-  QSlider *slider = qobject_cast<QSlider *>( widget );
-  if ( slider )
-    text = QString::number( slider->value() );
-  QDoubleSpinBox *dsb = qobject_cast<QDoubleSpinBox *>( widget );
-  if ( dsb )
-    text = QString::number( dsb->value() );
-  QCheckBox *ckb = qobject_cast<QCheckBox *>( widget );
-  if ( ckb )
-    QPair<QString, QString> states = vl->checkedState( idx );
-    text = ckb->isChecked() ? states.first : states.second;
-  le = widget->findChild<QLineEdit *>();
-  if ( le )
-  switch ( theField.type() )
-    case QVariant::Int:
-      bool ok;
-      int myIntValue = text.toInt( &ok );
-      if ( ok && !text.isEmpty() )
-        value = QVariant( myIntValue );
-        modified = true;
-      else if ( modified )
-        value = QVariant( theField.type() );
-    break;
-    case QVariant::Double:
-      bool ok;
-      double myDblValue = text.toDouble( &ok );
-        value = QVariant( myDblValue );
-        modified = true;
-    break;
-    default: //string
-      modified = true;
-      value = QVariant( text );
-      break;
-  return modified;
-bool QgsAttributeEditor::setValue( QWidget *editor, QgsVectorLayer *vl, int idx, const QVariant &value )
-  if ( !editor )
-    return false;
-      QComboBox *cb = qobject_cast<QComboBox *>( editor );
-      if ( cb == NULL )
-        return false;
-      int idx = cb->findData( value );
-      if ( idx < 0 )
-        return false;
-      cb->setCurrentIndex( idx );
-    break;
-          QSpinBox *sb = qobject_cast<QSpinBox *>( editor );
-          if ( sb == NULL )
-            return false;
-          sb->setValue( value.toInt() );
-        else
-          QSlider *sl = qobject_cast<QSlider *>( editor );
-          if ( sl == NULL )
-            return false;
-          sl->setValue( value.toInt() );
-        break;
-        QDoubleSpinBox *dsb = qobject_cast<QDoubleSpinBox *>( editor );
-        if ( dsb == NULL )
-          return false;
-        dsb->setValue( value.toDouble() );
-      QCheckBox *cb = qobject_cast<QCheckBox *>( editor );
-      if ( cb )
-        cb->setChecked( value == states.first );
-        break;
-    // fall-through
-    default:
-      QTextEdit *te = qobject_cast<QTextEdit *>( editor );
-      QPlainTextEdit *pte = qobject_cast<QPlainTextEdit *>( editor );
-      if ( !le && !te && !pte )
-        return false;
-#else
-      if ( !le && !te )
-        return false;
-#endif
-      QString text;
-      if ( value.isNull() )
-        if ( myFieldType == QVariant::Int || myFieldType == QVariant::Double )
-          text = "";
-        else
-          text = "NULL";
-      else
-        text = value.toString();
-      if ( le )
-        le->setText( text );
-      if ( te )
-        te->setHtml( text );
-      if ( pte )
-        pte->setPlainText( text );
-#else
-      if ( te )
-        te->setPlainText( text );
-#endif
-    break;
-      QLineEdit *le = editor->findChild<QLineEdit *>();
-      if ( le == NULL )
-        return false;
-      le->setText( value.toString() );
-    break;
-  return true;
Deleted: trunk/qgis/src/app/qgsattributeeditor.h
--- trunk/qgis/src/app/qgsattributeeditor.h	2010-03-03 20:00:59 UTC (rev 12996)
+++ trunk/qgis/src/app/qgsattributeeditor.h	2010-03-04 08:56:07 UTC (rev 12997)
@@ -1,46 +0,0 @@
-                         qgsattributeeditor.h  -  description
-    begin                : July 2009
-/* $Id$ */
-#ifndef QGSATTRIBUTEEDITOR_H
-#define QGSATTRIBUTEEDITOR_H
-#include <QVariant>
-class QObject;
-class QWidget;
-class QgsVectorLayer;
-class QComboBox;
-class QgsAttributeEditor : public QObject
-    Q_OBJECT
-  public:
-    QgsAttributeEditor( QObject *parent ) : QObject( parent ) {}
-    static QWidget *createAttributeEditor( QWidget *parent, QWidget *editor, QgsVectorLayer *vl, int idx, const QVariant &value );
-    static bool retrieveValue( QWidget *widget, QgsVectorLayer *vl, int idx, QVariant &value );
-    static bool setValue( QWidget *widget, QgsVectorLayer *vl, int idx, const QVariant &value );
-  private:
-    static QComboBox *comboBox( QWidget *editor, QWidget *parent );
-  public slots:
-    void selectFileName( void );
-#endif
Modified: trunk/qgis/src/gui/CMakeLists.txt
--- trunk/qgis/src/gui/CMakeLists.txt	2010-03-03 20:00:59 UTC (rev 12996)
+++ trunk/qgis/src/gui/CMakeLists.txt	2010-03-04 08:56:07 UTC (rev 12997)
@@ -21,6 +21,7 @@
 qgisgui.cpp
 qgisinterface.cpp
+qgsattributeeditor.cpp
 qgslegendinterface.cpp
 qgscolorbutton.cpp
 qgscomposerview.cpp
@@ -68,6 +69,7 @@
 symbology-ng/qgsvectorcolorbrewercolorrampv2dialog.h
 symbology-ng/characterwidget.h
+qgsattributeeditor.h
 qgscomposerview.h
 qgsdetaileditemdelegate.h
 qgsdetaileditemwidget.h
Copied: trunk/qgis/src/gui/qgsattributeeditor.cpp (from rev 12960, trunk/qgis/src/app/qgsattributeeditor.cpp)
--- trunk/qgis/src/gui/qgsattributeeditor.cpp	                        (rev 0)
+++ trunk/qgis/src/gui/qgsattributeeditor.cpp	2010-03-04 08:56:07 UTC (rev 12997)
@@ -0,0 +1,660 @@
+                         qgsattributeeditor.cpp  -  description
+    begin                : July 2009
+    copyright            : (C) 2009 by Jürgen E. Fischer
+    email                : jef at norbit.de
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+/* $Id$ */
+#include "qgsattributeeditor.h"
+#include <qgsvectorlayer.h>
+#include <qgsvectordataprovider.h>
+#include <qgsuniquevaluerenderer.h>
+#include <qgscategorizedsymbolrendererv2.h>
+#include <qgssymbol.h>
+#include <QPushButton>
+#include <QLineEdit>
+#include <QTextEdit>
+#include <QFileDialog>
+#include <QComboBox>
+#include <QCheckBox>
+#include <QSpinBox>
+#include <QCompleter>
+#include <QHBoxLayout>
+#if QT_VERSION >= 0x040400
+#include <QPlainTextEdit>
+#endif
+void QgsAttributeEditor::selectFileName( void )
+  QPushButton *pb = qobject_cast<QPushButton *>( sender() );
+  if ( !pb )
+    return;
+  QWidget *hbox = qobject_cast<QWidget *>( pb->parent() );
+  if ( !hbox )
+    return;
+  QLineEdit *le = hbox->findChild<QLineEdit *>();
+  if ( !le )
+    return;
+  QString fileName = QFileDialog::getOpenFileName( 0 , tr( "Select a file" ) );
+  if ( fileName.isNull() )
+    return;
+  le->setText( fileName );
+QComboBox *QgsAttributeEditor::comboBox( QWidget *editor, QWidget *parent )
+  QComboBox *cb = NULL;
+  if ( editor )
+    cb = qobject_cast<QComboBox *>( editor );
+  else
+    cb = new QComboBox( parent );
+  return cb;
+QWidget *QgsAttributeEditor::createAttributeEditor( QWidget *parent, QWidget *editor, QgsVectorLayer *vl, int idx, const QVariant &value )
+  if ( !vl )
+    return NULL;
+  QWidget *myWidget = NULL;
+  QgsVectorLayer::EditType editType = vl->editType( idx );
+  const QgsField &field = vl->pendingFields()[idx];
+  QVariant::Type myFieldType = field.type();
+  switch ( editType )
+    case QgsVectorLayer::UniqueValues:
+      QList<QVariant> values;
+      vl->dataProvider()->uniqueValues( idx, values );
+      QComboBox *cb = comboBox( editor, parent );
+      if ( cb )
+        cb->setEditable( false );
+        for ( QList<QVariant>::iterator it = values.begin(); it != values.end(); it++ )
+          cb->addItem( it->toString(), it->toString() );
+        myWidget = cb;
+    break;
+    case QgsVectorLayer::Enumeration:
+      QStringList enumValues;
+      vl->dataProvider()->enumValues( idx, enumValues );
+      if ( cb )
+        QStringList::const_iterator s_it = enumValues.constBegin();
+        for ( ; s_it != enumValues.constEnd(); ++s_it )
+          cb->addItem( *s_it, *s_it );
+        myWidget = cb;
+    break;
+    case QgsVectorLayer::ValueMap:
+      const QMap<QString, QVariant> &map = vl->valueMap( idx );
+      if ( cb )
+        for ( QMap<QString, QVariant>::const_iterator it = map.begin(); it != map.end(); it++ )
+          cb->addItem( it.key(), it.value() );
+        myWidget = cb;
+    break;
+    case QgsVectorLayer::Classification:
+      QMap<QString, QString> classes;
+      const QgsUniqueValueRenderer *uvr = dynamic_cast<const QgsUniqueValueRenderer *>( vl->renderer() );
+      if ( uvr )
+        const QList<QgsSymbol *> symbols = uvr->symbols();
+        for ( int i = 0; i < symbols.size(); i++ )
+          QString label = symbols[i]->label();
+          QString name = symbols[i]->lowerValue();
+          if ( label == "" )
+            label = name;
+          classes.insert( name, label );
+      const QgsCategorizedSymbolRendererV2 *csr = dynamic_cast<const QgsCategorizedSymbolRendererV2 *>( vl->rendererV2() );
+      if ( csr )
+        const QgsCategoryList &categories = (( QgsCategorizedSymbolRendererV2 * )csr )->categories(); // FIXME: QgsCategorizedSymbolRendererV2::categories() should be const
+        for ( int i = 0; i < categories.size(); i++ )
+          QString label = categories[i].label();
+          QString value = categories[i].value().toString();
+          if ( label.isEmpty() )
+            label = value;
+          classes.insert( label, value );
+      if ( cb )
+        for ( QMap<QString, QString>::const_iterator it = classes.begin(); it != classes.end(); it++ )
+          cb->addItem( it.value(), it.key() );
+        myWidget = cb;
+    break;
+    case QgsVectorLayer::SliderRange:
+    case QgsVectorLayer::EditRange:
+      if ( myFieldType == QVariant::Int )
+        int min = vl->range( idx ).mMin.toInt();
+        int max = vl->range( idx ).mMax.toInt();
+        int step = vl->range( idx ).mStep.toInt();
+        if ( editType == QgsVectorLayer::EditRange )
+          QSpinBox *sb = NULL;
+          if ( editor )
+            sb = qobject_cast<QSpinBox *>( editor );
+          else
+            sb = new QSpinBox( parent );
+          if ( sb )
+            sb->setRange( min, max );
+            sb->setSingleStep( step );
+            myWidget = sb;
+        else
+          QSlider *sl = NULL;
+          if ( editor )
+            sl = qobject_cast<QSlider*>( editor );
+          else
+            sl = new QSlider( Qt::Horizontal, parent );
+          if ( sl )
+            sl->setRange( min, max );
+            sl->setSingleStep( step );
+            myWidget = sl;
+        break;
+      else if ( myFieldType == QVariant::Double )
+        QDoubleSpinBox *dsb = NULL;
+        if ( editor )
+          dsb = qobject_cast<QDoubleSpinBox*>( editor );
+        else
+          dsb = new QDoubleSpinBox( parent );
+        if ( dsb )
+          double min = vl->range( idx ).mMin.toDouble();
+          double max = vl->range( idx ).mMax.toDouble();
+          double step = vl->range( idx ).mStep.toDouble();
+          dsb->setRange( min, max );
+          dsb->setSingleStep( step );
+          myWidget = dsb;
+        break;
+    case QgsVectorLayer::CheckBox:
+      QCheckBox *cb = NULL;
+      if ( editor )
+        cb = qobject_cast<QCheckBox*>( editor );
+      else
+        cb = new QCheckBox( parent );
+      if ( cb )
+        myWidget = cb;
+        break;
+    // fall-through
+    case QgsVectorLayer::LineEdit:
+    case QgsVectorLayer::TextEdit:
+    case QgsVectorLayer::UniqueValuesEditable:
+      QLineEdit *le = NULL;
+      QTextEdit *te = NULL;
+      QPlainTextEdit *pte = NULL;
+#endif
+      if ( editor )
+        le = qobject_cast<QLineEdit *>( editor );
+        te = qobject_cast<QTextEdit *>( editor );
+        pte = qobject_cast<QPlainTextEdit *>( editor );
+#endif
+      else if ( editType == QgsVectorLayer::TextEdit )
+        pte = new QPlainTextEdit( parent );
+#else
+        te = new QTextEdit( parent );
+        te->setAcceptRichText( false );
+#endif
+      else
+        le = new QLineEdit( parent );
+      if ( le )
+        if ( editType == QgsVectorLayer::UniqueValuesEditable )
+          QStringList svalues;
+          for ( QList<QVariant>::const_iterator it = values.begin(); it != values.end(); it++ )
+            svalues << it->toString();
+          QCompleter *c = new QCompleter( svalues );
+          c->setCompletionMode( QCompleter::PopupCompletion );
+          le->setCompleter( c );
+          le->setValidator( new QIntValidator( le ) );
+          le->setValidator( new QDoubleValidator( le ) );
+        myWidget = le;
+      if ( te )
+        te->setAcceptRichText( true );
+#endif
+        myWidget = te;
+      if ( pte )
+        myWidget = pte;
+#endif
+    break;
+    case QgsVectorLayer::Hidden:
+      myWidget = NULL;
+      break;
+    case QgsVectorLayer::FileName:
+      QPushButton *pb = NULL;
+      QLineEdit *le = qobject_cast<QLineEdit *>( editor );
+      if ( le )
+        if ( le )
+          myWidget = le;
+        if ( editor->parent() )
+          pb = editor->parent()->findChild<QPushButton *>();
+      else
+        le = new QLineEdit();
+        pb = new QPushButton( tr( "..." ) );
+        QHBoxLayout *hbl = new QHBoxLayout();
+        hbl->addWidget( le );
+        hbl->addWidget( pb );
+        myWidget = new QWidget( parent );
+        myWidget->setBackgroundRole( QPalette::Window );
+        myWidget->setAutoFillBackground( true );
+        myWidget->setLayout( hbl );
+      if ( pb )
+        connect( pb, SIGNAL( clicked() ), new QgsAttributeEditor( pb ), SLOT( selectFileName() ) );
+    break;
+    case QgsVectorLayer::Immutable:
+      return NULL;
+  if ( editType == QgsVectorLayer::Immutable )
+    myWidget->setEnabled( false );
+  setValue( myWidget, vl, idx, value );
+  return myWidget;
+bool QgsAttributeEditor::retrieveValue( QWidget *widget, QgsVectorLayer *vl, int idx, QVariant &value )
+  if ( !widget )
+    return false;
+  const QgsField &theField = vl->pendingFields()[idx];
+  bool modified = false;
+  QString text;
+  QLineEdit *le = qobject_cast<QLineEdit *>( widget );
+  if ( le )
+    text = le->text();
+    modified = le->isModified();
+    if ( text == "NULL" )
+      text = QString::null;
+  QTextEdit *te = qobject_cast<QTextEdit *>( widget );
+  if ( te )
+    text = te->toHtml();
+#else
+    text = te->toPlainText();
+#endif
+    modified = te->document()->isModified();
+  QPlainTextEdit *pte = qobject_cast<QPlainTextEdit *>( widget );
+  if ( pte )
+    text = pte->toPlainText();
+    modified = pte->document()->isModified();
+#endif
+  QComboBox *cb = qobject_cast<QComboBox *>( widget );
+  if ( cb )
+    if ( editType == QgsVectorLayer::UniqueValues ||
+         editType == QgsVectorLayer::ValueMap ||
+         editType == QgsVectorLayer::Classification )
+      text = cb->itemData( cb->currentIndex() ).toString();
+    else
+      text = cb->currentText();
+  QSpinBox *sb = qobject_cast<QSpinBox *>( widget );
+  if ( sb )
+    text = QString::number( sb->value() );
+  QSlider *slider = qobject_cast<QSlider *>( widget );
+  if ( slider )
+    text = QString::number( slider->value() );
+  QDoubleSpinBox *dsb = qobject_cast<QDoubleSpinBox *>( widget );
+  if ( dsb )
+    text = QString::number( dsb->value() );
+  QCheckBox *ckb = qobject_cast<QCheckBox *>( widget );
+  if ( ckb )
+    QPair<QString, QString> states = vl->checkedState( idx );
+    text = ckb->isChecked() ? states.first : states.second;
+  le = widget->findChild<QLineEdit *>();
+  if ( le )
+  switch ( theField.type() )
+    case QVariant::Int:
+      bool ok;
+      int myIntValue = text.toInt( &ok );
+      if ( ok && !text.isEmpty() )
+        value = QVariant( myIntValue );
+        modified = true;
+      else if ( modified )
+        value = QVariant( theField.type() );
+    break;
+    case QVariant::Double:
+      bool ok;
+      double myDblValue = text.toDouble( &ok );
+        value = QVariant( myDblValue );
+        modified = true;
+    break;
+    default: //string
+      modified = true;
+      value = QVariant( text );
+      break;
+  return modified;
+bool QgsAttributeEditor::setValue( QWidget *editor, QgsVectorLayer *vl, int idx, const QVariant &value )
+  if ( !editor )
+    return false;
+      QComboBox *cb = qobject_cast<QComboBox *>( editor );
+      if ( cb == NULL )
+        return false;
+      int idx = cb->findData( value );
+      if ( idx < 0 )
+        return false;
+      cb->setCurrentIndex( idx );
+    break;
+          QSpinBox *sb = qobject_cast<QSpinBox *>( editor );
+          if ( sb == NULL )
+            return false;
+          sb->setValue( value.toInt() );
+        else
+          QSlider *sl = qobject_cast<QSlider *>( editor );
+          if ( sl == NULL )
+            return false;
+          sl->setValue( value.toInt() );
+        break;
+        QDoubleSpinBox *dsb = qobject_cast<QDoubleSpinBox *>( editor );
+        if ( dsb == NULL )
+          return false;
+        dsb->setValue( value.toDouble() );
+      QCheckBox *cb = qobject_cast<QCheckBox *>( editor );
+      if ( cb )
+        cb->setChecked( value == states.first );
+        break;
+    // fall-through
+    default:
+      QTextEdit *te = qobject_cast<QTextEdit *>( editor );
+      QPlainTextEdit *pte = qobject_cast<QPlainTextEdit *>( editor );
+      if ( !le && !te && !pte )
+        return false;
+#else
+      if ( !le && !te )
+        return false;
+#endif
+      QString text;
+      if ( value.isNull() )
+        if ( myFieldType == QVariant::Int || myFieldType == QVariant::Double )
+          text = "";
+        else
+          text = "NULL";
+      else
+        text = value.toString();
+      if ( le )
+        le->setText( text );
+      if ( te )
+        te->setHtml( text );
+      if ( pte )
+        pte->setPlainText( text );
+#else
+      if ( te )
+        te->setPlainText( text );
+#endif
+    break;
+      QLineEdit *le = editor->findChild<QLineEdit *>();
+      if ( le == NULL )
+        return false;
+      le->setText( value.toString() );
+    break;
+  return true;
Copied: trunk/qgis/src/gui/qgsattributeeditor.h (from rev 12960, trunk/qgis/src/app/qgsattributeeditor.h)
--- trunk/qgis/src/gui/qgsattributeeditor.h	                        (rev 0)
+++ trunk/qgis/src/gui/qgsattributeeditor.h	2010-03-04 08:56:07 UTC (rev 12997)
@@ -0,0 +1,46 @@
+                         qgsattributeeditor.h  -  description
+    begin                : July 2009
+/* $Id$ */
+#ifndef QGSATTRIBUTEEDITOR_H
+#define QGSATTRIBUTEEDITOR_H
+#include <QVariant>
+class QObject;
+class QWidget;
+class QgsVectorLayer;
+class QComboBox;
+class QgsAttributeEditor : public QObject
+    Q_OBJECT
+  public:
+    QgsAttributeEditor( QObject *parent ) : QObject( parent ) {}
+    static QWidget *createAttributeEditor( QWidget *parent, QWidget *editor, QgsVectorLayer *vl, int idx, const QVariant &value );
+    static bool retrieveValue( QWidget *widget, QgsVectorLayer *vl, int idx, QVariant &value );
+    static bool setValue( QWidget *widget, QgsVectorLayer *vl, int idx, const QVariant &value );
+  private:
+    static QComboBox *comboBox( QWidget *editor, QWidget *parent );
+  public slots:
+    void selectFileName( void );
+#endif
More information about the QGIS-commit mailing list
