[QGIS Commit] r13173 - in trunk/qgis/mac/xcode: . Qgis.xcodeproj
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Mar 27 12:51:25 EDT 2010
Author: kyngchaos
Date: 2010-03-27 12:51:24 -0400 (Sat, 27 Mar 2010)
New Revision: 13173
   trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
   trunk/qgis/mac/xcode/qgis_settings.xcconfig
   trunk/qgis/mac/xcode/qgis_user-template.xcconfig
conditionalize some Qt settings on version
Modified: trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
--- trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj	2010-03-27 16:39:31 UTC (rev 13172)
+++ trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj	2010-03-27 16:51:24 UTC (rev 13173)
@@ -19578,7 +19578,7 @@
 				COPY_PHASE_STRIP = NO;
 				GCC_GENERATE_DEBUGGING_SYMBOLS = YES;
 				GCC_OPTIMIZATION_LEVEL = 0;
-				QGIS_VERSION_BUILD = 13169;
+				QGIS_VERSION_BUILD = 13172;
 				STRIP_INSTALLED_PRODUCT = NO;
 			name = Debug;
@@ -19589,7 +19589,7 @@
 			buildSettings = {
 				COPY_PHASE_STRIP = YES;
 				GCC_GENERATE_DEBUGGING_SYMBOLS = NO;
 				STRIP_INSTALLED_PRODUCT = YES;
 			name = Release;
Modified: trunk/qgis/mac/xcode/qgis_settings.xcconfig
--- trunk/qgis/mac/xcode/qgis_settings.xcconfig	2010-03-27 16:39:31 UTC (rev 13172)
+++ trunk/qgis/mac/xcode/qgis_settings.xcconfig	2010-03-27 16:51:24 UTC (rev 13173)
@@ -29,7 +29,7 @@
 // ***TODO*** - detect current version, only used in bundle script
 QT_MVER = $(QT_VER_MAJOR) // keep for now so I don't have to change all scripts and deps
 QT_VER_MAJOR = 4 // the install_name/major version
-QT_VER_MINOR = 5 // minor version
+QT_VER_MINOR = 6 // minor version
 QT_FWVER = $(QT_VER_MAJOR) // the Versions/ folder name, normally same as Qt ver
 QT_DIR = /usr
@@ -51,7 +51,7 @@
 SIP_INC = /usr/local/include
 // from pyqtconfig.py
 PYQT_SIP_DIR = /usr/local/share/sip/PyQt4
-PYQT_SIP_FLAGS = -x VendorID -t WS_MACX -x PyQt_NoPrintRangeBug -t Qt_4_5_0 -x Py_v3 -g
+PYQT_SIP_FLAGS = -x VendorID -t WS_MACX -x PyQt_NoPrintRangeBug -t Qt_$(QT_VER_MAJOR)_$(QT_VER_MINOR)_0 -x Py_v3 -g
 BISON = /usr/bin/bison
 GPSBABEL = /usr/local/bin/gpsbabel
@@ -232,13 +232,20 @@
 QT_LIB_SVG = -framework QtSvg
 QT_LIB_SQL = -framework QtSql
 QT_LIB_WEBKIT = -framework QtWebKit
-QT_LIB_DBUS = -framework QtDBus
 QT_LIB_PHONON = -framework phonon
 QT_LIB_UITOOLS = -L$(QT_DIR_SDK)/lib -lQtUiTools
+// needed by webkit starting in Qt 4.5
+QT_LIB_DBUS_4_4 =
+QT_LIB_DBUS_4_5 = -framework QtDBus
+QT_LIB_DBUS_4_6 = -framework QtDBus
+QT_LIB_DBUS = $(QT_LIB_DBUS_$(QT_VER_MAJOR)_$(QT_VER_MINOR))
 // convenience for all Qt:
 QT_LIB = $(QT_LIB_CORE) $(QT_LIB_GUI) $(QT_LIB_NET) $(QT_LIB_XML) $(QT_LIB_SVG) $(QT_LIB_SQL)
 // list of Qt frameworks used
-QTLISTQG = QtCore QtGui QtNetwork QtSql QtSvg QtXml QtWebKit QtDBus phonon
+QT_USE_4_4 =
+QT_USE_4_5 = QtDBus
+QT_USE_4_6 = QtDBus
+QTLISTQG = QtCore QtGui QtNetwork QtSql QtSvg QtXml QtWebKit $(QT_USE_$(QT_VER_MAJOR)_$(QT_VER_MINOR)) phonon
 // list of PyQt modules used
 PYQTLIST = Qt QtCore QtGui QtNetwork QtSql QtSvg QtXml QtWebKit phonon
Modified: trunk/qgis/mac/xcode/qgis_user-template.xcconfig
--- trunk/qgis/mac/xcode/qgis_user-template.xcconfig	2010-03-27 16:39:31 UTC (rev 13172)
+++ trunk/qgis/mac/xcode/qgis_user-template.xcconfig	2010-03-27 16:51:24 UTC (rev 13173)
@@ -22,7 +22,7 @@
 //QT_MVER = $(QT_VER_MAJOR)
 //QT_VER_MAJOR = 4 // the install_name/major version
-//QT_VER_MINOR = 5 // minor version, currently unused
+//QT_VER_MINOR = 6 // minor version, currently unused
 //QT_FWVER = $(QT_VER_MAJOR) // the Versions/ folder name, normally same as Qt ver
 //QT_DIR = /usr
@@ -34,7 +34,7 @@
 //QTBIN = /Developer/Tools/Qt // bin dir
 //SIP_INC = /usr/local/include
 //PYQT_SIP_DIR = /usr/local/share/sip/PyQt4
-//PYQT_SIP_FLAGS = -x VendorID -t WS_MACX -x PyQt_NoPrintRangeBug -t Qt_4_5_0 -x Py_v3 -g
+//PYQT_SIP_FLAGS = -x VendorID -t WS_MACX -x PyQt_NoPrintRangeBug -t Qt_$(QT_VER_MAJOR)_$(QT_VER_MINOR)_0 -x Py_v3 -g
 //BISON = /usr/bin/bison // Tiger requires user-installed bison 2.3
 //GPSBABEL = /usr/local/bin/gpsbabel
More information about the QGIS-commit mailing list
