[QGIS Commit] r13561 - trunk/qgis/src/plugins/georeferencer
svn_qgis at osgeo.org
Mon May 24 08:43:04 EDT 2010
Author: mmassing
Date: 2010-05-24 08:43:04 -0400 (Mon, 24 May 2010)
New Revision: 13561
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h
georeferencer: fix closeEvent handling for dock widget.
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-05-24 12:42:54 UTC (rev 13560)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-05-24 12:43:04 UTC (rev 13561)
@@ -62,20 +62,22 @@
#include "qgsgeorefplugingui.h"
-class QgsGeorefDockWidget : public QDockWidget
+QgsGeorefDockWidget::QgsGeorefDockWidget( const QString & title, QWidget * parent, Qt::WindowFlags flags )
+ : QDockWidget( title, parent, flags )
- public:
- QgsGeorefDockWidget( const QString & title, QWidget * parent = 0, Qt::WindowFlags flags = 0 )
- : QDockWidget( title, parent, flags )
- setObjectName( "GeorefDockWidget" ); // set object name so the position can be saved
+ setObjectName( "GeorefDockWidget" ); // set object name so the position can be saved
- virtual void closeEvent( QCloseEvent * ev )
- deleteLater();
+void QgsGeorefDockWidget::closeEvent( QCloseEvent * ev )
+ if (widget() && !widget()->close())
+ ev->ignore();
+ return;
+ deleteLater();
QgsGeorefPluginGui::QgsGeorefPluginGui( QgisInterface* theQgisInterface, QWidget* parent, Qt::WFlags fl )
: QMainWindow( parent, fl )
@@ -130,7 +132,6 @@
mDock = new QgsGeorefDockWidget( tr( "Georeferencer" ), mIface->mainWindow() );
mDock->setWidget( this );
- connect( this, SIGNAL( destroyed() ), mDock, SLOT( close() ) );
mIface->addDockWidget( Qt::BottomDockWidgetArea, mDock );
@@ -151,6 +152,7 @@
delete mToolAddPoint;
delete mToolDeletePoint;
delete mToolMovePoint;
// ----------------------------- protected --------------------------------- //
@@ -929,8 +931,8 @@
dockWidgetGCPpoints->setWidget( mGCPListWidget );
connect( mGCPListWidget, SIGNAL( jumpToGCP( uint ) ), this, SLOT( jumpToGCP( uint ) ) );
- connect( mGCPListWidget, SIGNAL( replaceDataPoint( QgsGeorefDataPoint*, int ) ),
- this, SLOT( replaceDataPoint( QgsGeorefDataPoint*, int ) ) );
+ /*connect( mGCPListWidget, SIGNAL( replaceDataPoint( QgsGeorefDataPoint*, int ) ),
+ this, SLOT( replaceDataPoint( QgsGeorefDataPoint*, int ) ) );*/
connect( mGCPListWidget, SIGNAL( deleteDataPoint( int ) ),
this, SLOT( deleteDataPoint( int ) ) );
connect( mGCPListWidget, SIGNAL( pointEnabled( QgsGeorefDataPoint*, int ) ), this, SLOT( updateGeorefTransform() ) );
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h 2010-05-24 12:42:54 UTC (rev 13560)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h 2010-05-24 12:43:04 UTC (rev 13561)
@@ -225,4 +225,13 @@
QDockWidget* mDock;
+class QgsGeorefDockWidget : public QDockWidget
+ Q_OBJECT
+ public:
+ QgsGeorefDockWidget( const QString & title, QWidget * parent = 0, Qt::WindowFlags flags = 0 );
+ virtual void closeEvent( QCloseEvent * ev );
#endif
