[QGIS Commit] r13562 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon May 24 08:54:11 EDT 2010
Author: macho
Date: 2010-05-24 08:54:10 -0400 (Mon, 24 May 2010)
New Revision: 13562
   trunk/qgis/i18n/qgis_cs_CZ.ts
translation update: czech by Jan
Modified: trunk/qgis/i18n/qgis_cs_CZ.ts
--- trunk/qgis/i18n/qgis_cs_CZ.ts	2010-05-24 12:43:04 UTC (rev 13561)
+++ trunk/qgis/i18n/qgis_cs_CZ.ts	2010-05-24 12:54:10 UTC (rev 13562)
@@ -582,6 +582,12 @@
 Chcte přidat novou vrstvu do aktuálního mapového okna?</translation>
     </message>
     <message>
+        <source>No output will be created.
+Following field names are longer than 10 characters:
+%1</source>
+        <translation type="unfinished"></translation>
+    </message>
+    <message>
         <source>Export to new projection</source>
         <translation>Exportovat do nové projekce</translation>
     </message>
@@ -590,12 +596,6 @@
         <translation>Vstupní vrstva nebyla určena</translation>
     </message>
     <message>
-        <source>No output will be created.
-Following field names are longer than 10 characters:
-%1</source>
-        <translation type="unfinished"></translation>
-    </message>
-    <message>
         <source>Define current projection</source>
         <translation>Definovat aktuální projekci</translation>
     </message>
@@ -5750,6 +5750,11 @@
         <translation>Nastavit možnosti aktuální vrstvy</translation>
     </message>
     <message>
+        <location filename="../src/app/qgisapp.cpp" line="1058"/>
+        <source>Query...</source>
+    </message>
+    <message>
         <location filename="../src/app/qgisapp.cpp" line="1060"/>
         <source>Set subset query of the current layer</source>
@@ -6114,11 +6119,6 @@
         <translation>Zobrazit posuvník měřítka dlaždic</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="1058"/>
-        <source>Query...</source>
-    </message>
-    <message>
         <location filename="../src/app/qgisapp.cpp" line="2611"/>
         <source>%1 is not a valid or recognized data source</source>
         <translation>%1 není platný nebo rozpoznaný zdroj dat</translation>
@@ -6770,22 +6770,22 @@
 <context>
     <name>QgsAttributeDialog</name>
     <message>
-        <location filename="../src/app/qgsattributedialog.cpp" line="139"/>
+        <location filename="../src/app/qgsattributedialog.cpp" line="140"/>
         <source> (int)</source>
         <translation>(int)</translation>
     </message>
     <message>
-        <location filename="../src/app/qgsattributedialog.cpp" line="143"/>
+        <location filename="../src/app/qgsattributedialog.cpp" line="144"/>
         <source> (dbl)</source>
         <translation>(dbl)</translation>
     </message>
     <message>
-        <location filename="../src/app/qgsattributedialog.cpp" line="148"/>
+        <location filename="../src/app/qgsattributedialog.cpp" line="149"/>
         <source> (txt)</source>
         <translation>(txt)</translation>
     </message>
     <message>
-        <location filename="../src/app/qgsattributedialog.cpp" line="189"/>
+        <location filename="../src/app/qgsattributedialog.cpp" line="190"/>
         <source>Attributes - %1</source>
         <translation>Atributy - %1</translation>
     </message>
@@ -6869,28 +6869,28 @@
 <context>
     <name>QgsAttributeTableDialog</name>
     <message>
-        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="525"/>
+        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="541"/>
         <source>Search string parsing error</source>
         <translation>Chyba při kontrole hledaného řetězce</translation>
     </message>
     <message>
-        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="532"/>
+        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="548"/>
         <source>Search results</source>
         <translation>Výsledek hledání</translation>
     </message>
     <message>
         <source>You&apos;ve supplied an empty search string.</source>
         <translation>Zadal jste prázdný řetězec pro hledání.</translation>
     </message>
     <message>
-        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="576"/>
+        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="592"/>
         <source>Error during search</source>
         <translation>Chyba během hledání</translation>
     </message>
     <message numerus="yes">
-        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="78"/>
-        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="85"/>
+        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="77"/>
+        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="84"/>
         <source>Attribute table - %1 (%n Feature(s))</source>
         <comment>feature count</comment>
         <translation>
@@ -6900,7 +6900,7 @@
         </translation>
     </message>
-        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="591"/>
+        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="607"/>
         <source>Attribute table - %1 (%n matching features)</source>
         <comment>matching features</comment>
         <translation>
@@ -6910,33 +6910,33 @@
         </translation>
     </message>
     <message>
-        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="595"/>
+        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="611"/>
         <source>Attribute table - %1 (No matching features)</source>
         <translation>Atributová tabulka - %1 (žádné odpovídající prvky)</translation>
     </message>
     <message>
-        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="686"/>
+        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="702"/>
         <source>Attribute added</source>
         <translation>Atribut přidán</translation>
     </message>
     <message>
-        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="693"/>
-        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="734"/>
+        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="709"/>
+        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="750"/>
         <source>Attribute Error</source>
         <translation>Chyba atributu</translation>
     </message>
     <message>
         <source>The attribute could not be added to the layer</source>
         <translation>Atribut nemohl být přidán do vrstvy</translation>
     </message>
     <message>
-        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="717"/>
+        <location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="733"/>
         <source>Deleted attribute</source>
         <translation>Smazán atribut</translation>
     </message>
     <message>
         <source>The attribute(s) could not be deleted</source>
         <translation>Atribut(y) nemohl(y) být smazán(y)</translation>
     </message>
@@ -7069,7 +7069,7 @@
 <context>
     <name>QgsAttributeTableModel</name>
     <message>
-        <location filename="../src/app/attributetable/qgsattributetablemodel.cpp" line="429"/>
+        <location filename="../src/app/attributetable/qgsattributetablemodel.cpp" line="449"/>
         <source>Attribute changed</source>
         <translation>Atribut změněn</translation>
     </message>
@@ -7445,28 +7445,28 @@
 <context>
     <name>QgsComposer</name>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="579"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="580"/>
         <source>Big image</source>
         <translation>Veliký obrázek</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="212"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="213"/>
         <source>Map 1</source>
         <translation>Mapa 1</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="708"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="709"/>
         <source>SVG warning</source>
         <translation>SVG varování</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="709"/>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="1442"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="710"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="1443"/>
         <source>Don&apos;t show this message again</source>
         <translation>Tuto zprávu přístě nezobrazovat</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="728"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="729"/>
         <source>SVG Format</source>
         <translation>SVG formát</translation>
     </message>
@@ -7481,104 +7481,104 @@
         <translation>Soubor</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="145"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="146"/>
         <source>View</source>
         <translation>Pohled</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="152"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="153"/>
         <source>Layout</source>
         <translation>Rozvržení</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="464"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="465"/>
         <source>PDF Format</source>
         <translation>PDF formát</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="632"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="633"/>
         <source>Choose a file name to save the map image as</source>
         <translation>Vyber jméno souboru do kterého se má uložit obrázek</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="463"/>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="727"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="464"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="728"/>
         <source>Choose a file name to save the map as</source>
         <translation>Vyberte jméno souboru do kterého se má uložit mapa</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="1113"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="1114"/>
         <source>Composer</source>
         <translation>Tvorba mapy</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="1440"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="1441"/>
         <source>Project contains WMS layers</source>
         <translation>Projekt obsahuje vrstvy WMS</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="1441"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="1442"/>
         <source>Some WMS servers (e.g. UMN mapserver) have a limit for the WIDTH and HEIGHT parameter. Printing layers from such servers may exceed this limit. If this is the case, the WMS layer will not be printed</source>
         <translation>Některé WMS servery (např. UMN mapserver) mají limity pro paramtery šířky a výšky. Tiskové plochy z takových serverů mohou tento limit překročit . V takovém případě nebude WMS vrstva vytištěna</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="580"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="581"/>
         <source>To create image %1 x %2 requires circa %3 MB of memory</source>
         <translation>Vytvoření obrázku %1 x %2 vyžaduje cca %3 MB paměti</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="608"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="609"/>
         <source>%1 format (*.%2 *.%3)</source>
         <translation>%1 formát (*.%2 *.%3)</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="713"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="714"/>
         <source>&lt;p&gt;The SVG export function in Qgis has several problems due to bugs and deficiencies in the </source>
         <translation>&lt;p&gt;SVG export Qgisu trpí několika problémy nedostatky v </translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="715"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="716"/>
         <source>Qt4 svg code. In particular, there are problems with layers not being clipped to the map bounding box.&lt;/p&gt;</source>
         <translation>Qt4 svg kódu. Především jsou pak problémy s vrstvami, které  nejsou oříznuty ohraničením mapy.&lt;/p&gt;</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="718"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="719"/>
         <source>If you require a vector-based output file from Qgis it is suggested that you try printing to PostScript if the SVG output is not satisfactory.&lt;/p&gt;</source>
         <translation>Pokud potřebujete vektorový výstup z QGISu, doporučujeme vyzkoušet tisknutí do PostScriptu, pokud SVG výstup není uspokojující.&lt;/p&gt;</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="846"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="847"/>
         <source>save template</source>
         <translation>uložit šablonu</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="872"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="873"/>
         <source>Save error</source>
         <translation>Chyba ukládání</translation>
     </message>
     <message>
         <source>Error, could not save file</source>
         <translation>Chyba, nemohu uložit soubor</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="880"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="881"/>
         <source>Load template</source>
         <translation>Načíst šablonu</translation>
     </message>
     <message>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="893"/>
-        <location filename="../src/app/composer/qgscomposer.cpp" line="900"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="894"/>
+        <location filename="../src/app/composer/qgscomposer.cpp" line="901"/>
         <source>Read error</source>
         <translation>Chyba čtení</translation>
     </message>
     <message>
         <source>Error, could not read file</source>
         <translation>Chybam nemohu přečíst soubor</translation>
     </message>
     <message>
         <source>Content of template file is not valid</source>
         <translation>Obsah šablony je neplatný</translation>
     </message>
@@ -7963,6 +7963,11 @@
         <source>Adds attribute table</source>
         <translation>Přidá atributovou tabulku</translation>
     </message>
+    <message>
+        <location filename="../src/ui/qgscomposerbase.ui" line="479"/>
+        <source>Page Setup</source>
+    </message>
 </context>
 <context>
     <name>QgsComposerItemWidgetBase</name>
@@ -10503,14 +10508,27 @@
     </message>
 </context>
 <context>
+    <name>QgsGCPListModel</name>
+    <message>
+        <location filename="../src/plugins/georeferencer/qgsgcplistmodel.cpp" line="115"/>
+        <source>map units</source>
+        <translation type="unfinished">mapových jednotek</translation>
+    </message>
+    <message>
+        <source>pixels</source>
+        <translation type="unfinished">pixelů</translation>
+    </message>
+</context>
+<context>
     <name>QgsGCPListWidget</name>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgcplistwidget.cpp" line="176"/>
+        <location filename="../src/plugins/georeferencer/qgsgcplistwidget.cpp" line="175"/>
         <source>Recenter</source>
         <translation>Nedávný</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgcplistwidget.cpp" line="180"/>
+        <location filename="../src/plugins/georeferencer/qgsgcplistwidget.cpp" line="179"/>
         <source>Remove</source>
         <translation>Odebrat</translation>
     </message>
@@ -11384,6 +11402,11 @@
         <source>Show coords</source>
         <translation>Zobrazit souřadnice</translation>
     </message>
+    <message>
+        <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="43"/>
+        <source>Show Georeferencer window docked</source>
+    </message>
 </context>
 <context>
     <name>QgsGeorefDescriptionDialogBase</name>
@@ -11426,281 +11449,307 @@
 <context>
     <name>QgsGeorefPluginGui</name>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="180"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="210"/>
         <source>All other files (*)</source>
         <translation>Všechny ostatní soubory (*)</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="187"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="217"/>
         <source>Open raster</source>
         <translation>Otevřít rastr</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="196"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="226"/>
         <source>%1 is not a supported raster data source</source>
         <translation>%1 je nepodporovaný zdroj rastrových dat</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="201"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="231"/>
         <source>Unsupported Data Source</source>
         <translation>Nepodporovaný datový zdroj</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="210"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="240"/>
         <source>Raster loaded: %1</source>
         <translation>Rastr načten: %1</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="211"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="241"/>
         <source>Georeferencer - %1</source>
         <translation>Georeferencování - %1</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="289"/>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="918"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="319"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="952"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1466"/>
         <source>Transform: </source>
         <translation>Transformovat:</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="342"/>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="533"/>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="560"/>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1027"/>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1075"/>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1117"/>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1516"/>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1525"/>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1535"/>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1544"/>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1558"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="373"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="567"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="594"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1073"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1121"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1163"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1597"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1606"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1616"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1625"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1639"/>
         <source>Info</source>
         <translation>Informace</translation>
     </message>
     <message>
         <source>GDAL scripting is not supported for %1 transformation</source>
         <translation>GDAL skriptování není podporováno pro transformaci %1</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="521"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="555"/>
         <source>Load GCP points</source>
         <translation>Načíst GCP body</translation>
     </message>
     <message>
         <source>No GCP points to save</source>
         <translation>Žádné GCP body k uložení</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="538"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="572"/>
         <source>Save GCP points</source>
         <translation>Uložit GCP body</translation>
     </message>
     <message>
         <source>Please load raster to be georeferenced</source>
         <translation>Načtěte prosím rastr ke georeferencování</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="764"/>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="874"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="809"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="919"/>
         <source>Help</source>
         <translation>Nápověda</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="851"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="896"/>
         <source>Panels</source>
         <translation>Panely</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="855"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="900"/>
         <source>Toolbars</source>
         <translation>Nástrojové lišty</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="907"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="964"/>
         <source>Coordinate: </source>
         <translation>Souřadnice:</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="908"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="965"/>
         <source>Current map coordinate</source>
         <translation>Aktuální souřadnice na mapě</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="919"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="953"/>
         <source>Current transform parametrisation</source>
         <translation>Parametrizace aktuální transformace</translation>
     </message>
     <message>
         <source>Unable to open GCP points file %1</source>
         <translation>Nemohu otevřít soubor s GCP body %1</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1146"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1192"/>
         <source>Could not write to %1</source>
         <translation>Nemohu zapisovat do %1</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1041"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1087"/>
         <source>Save GCPs</source>
         <translation>Uložit GCP</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1042"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="133"/>
+        <source>Georeferencer</source>
+        <translation type="unfinished">Georeferencování</translation>
+    </message>
+    <message>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1088"/>
         <source>Save GCP points?</source>
         <translation>Uložit GCP body?</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1076"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1122"/>
         <source>Failed to get linear transform parameters</source>
         <translation>Selhalo získání parametrů lineární transformace</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1087"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1133"/>
         <source>&lt;p&gt;The selected file already seems to have a world file! Do you want to replace it with the new world file?&lt;/p&gt;</source>
         <translation>&lt;p&gt;Vybraný soubor již zřejmě má soubor s georeferencí (world file)! Chcete ho přepsat novým souborem?&lt;/p&gt;</translation>
     </message>
     <message>
         <source>Failed to compute GCP transform: Transform is not solvable</source>
         <translation>Výpočet GCP transformace selhal: Transformace není řešitelná</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1145"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1191"/>
         <source>Error</source>
         <translation>Chyba</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1240"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1340"/>
         <source>Transformation parameters</source>
         <translation>Parametry transformace</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1295"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1357"/>
         <source>Translation x</source>
         <translation>Přepočet X</translation>
     </message>
     <message>
         <source>Translation y</source>
         <translation>Přepočet Y</translation>
     </message>
     <message>
         <source>Scale x</source>
         <translation>Měřítko X</translation>
     </message>
     <message>
         <source>Scale y</source>
         <translation>Měřítko Y</translation>
     </message>
     <message>
         <source>Rotation [degrees]</source>
         <translation>Rotace [stupně]</translation>
     </message>
     <message>
         <source>Mean error [map units]</source>
         <translation>Průměrná chyba [mapové jednotky]</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1314"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1376"/>
         <source>Residuals</source>
         <translation>Rezidua</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1339"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1401"/>
         <translation>mapových jednotek</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1343"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1405"/>
         <translation>pixelů</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1372"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1424"/>
         <source>yes</source>
         <translation>ano</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1376"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1428"/>
         <source>no</source>
         <translation>ne</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1422"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1473"/>
+        <source>Translation (%1, %2)</source>
+    </message>
+    <message>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1474"/>
+        <source>Scale (%1, %2)</source>
+    </message>
+    <message>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1475"/>
+        <source>Rotation: %1</source>
+    </message>
+    <message>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1482"/>
+        <source>Mean error: %1</source>
+    </message>
+    <message>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1503"/>
         <source>Copy in clipboard</source>
         <translation>Kopírovat do schránky</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1428"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1509"/>
         <source>%1</source>
         <translation>%1</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1435"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1516"/>
         <source>GDAL script</source>
         <translation>GDAL skript</translation>
     </message>
     <message>
         <source>Please set transformation type</source>
         <translation>Nastavte prosím typ transformace</translation>
     </message>
     <message>
         <source>Please set output raster name</source>
         <translation>Nastavte prosím název výstupního rastru</translation>
     </message>
     <message>
         <source>%1 requires at least %2 GCPs. Please define more</source>
         <translation>%1 vyžaduje alespoň %2 GCP bodů. Určete jich prosím víc</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1631"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1710"/>
         <source>Linear</source>
         <translation>Lineární</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1633"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1712"/>
         <source>Helmert</source>
         <translation>Helmertova</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1635"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1714"/>
         <source>Polynomial 1</source>
         <translation>Polynomiální 1</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1637"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1716"/>
         <source>Polynomial 2</source>
         <translation>Polynomiální 2</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1639"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1718"/>
         <source>Polynomial 3</source>
         <translation>Polynomiální 3</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1641"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1720"/>
         <source>Thin plate spline (TPS)</source>
         <translation>Thin plate spline (TPS)</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1643"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1722"/>
         <source>Not set</source>
         <translation>Nenastaveno</translation>
     </message>
     <message>
-        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1086"/>
+        <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1132"/>
         <source>World file exists</source>
         <translation>Soubor s georeferencí existuje</translation>
     </message>
@@ -17793,34 +17842,34 @@
 <context>
     <name>QgsOptions</name>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="312"/>
         <location filename="../src/app/qgsoptions.cpp" line="319"/>
-        <location filename="../src/app/qgsoptions.cpp" line="614"/>
+        <location filename="../src/app/qgsoptions.cpp" line="326"/>
+        <location filename="../src/app/qgsoptions.cpp" line="622"/>
         <source>Semi transparent circle</source>
         <translation>Částečně průhledný kruh</translation>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="313"/>
-        <location filename="../src/app/qgsoptions.cpp" line="323"/>
-        <location filename="../src/app/qgsoptions.cpp" line="618"/>
+        <location filename="../src/app/qgsoptions.cpp" line="320"/>
+        <location filename="../src/app/qgsoptions.cpp" line="330"/>
+        <location filename="../src/app/qgsoptions.cpp" line="626"/>
         <source>Cross</source>
         <translation>Kříž</translation>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="262"/>
+        <location filename="../src/app/qgsoptions.cpp" line="269"/>
         <source>Detected active locale on your system: %1</source>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="314"/>
-        <location filename="../src/app/qgsoptions.cpp" line="327"/>
-        <location filename="../src/app/qgsoptions.cpp" line="622"/>
+        <location filename="../src/app/qgsoptions.cpp" line="321"/>
+        <location filename="../src/app/qgsoptions.cpp" line="334"/>
+        <location filename="../src/app/qgsoptions.cpp" line="630"/>
         <source>None</source>
         <translation type="unfinished">Žádná</translation>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="292"/>
-        <location filename="../src/app/qgsoptions.cpp" line="301"/>
+        <location filename="../src/app/qgsoptions.cpp" line="299"/>
+        <location filename="../src/app/qgsoptions.cpp" line="308"/>
     </message>
@@ -17840,54 +17889,69 @@
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="282"/>
+        <location filename="../src/app/qgsoptions.cpp" line="147"/>
+        <source>Show all features</source>
+    </message>
+    <message>
+        <location filename="../src/app/qgsoptions.cpp" line="148"/>
+        <source>Show selected features</source>
+    </message>
+    <message>
+        <location filename="../src/app/qgsoptions.cpp" line="149"/>
+        <source>Show features in current canvas</source>
+    </message>
+    <message>
+        <location filename="../src/app/qgsoptions.cpp" line="289"/>
         <source>To vertex</source>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="283"/>
+        <location filename="../src/app/qgsoptions.cpp" line="290"/>
         <source>To segment</source>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="284"/>
+        <location filename="../src/app/qgsoptions.cpp" line="291"/>
         <source>To vertex and segment</source>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="296"/>
-        <location filename="../src/app/qgsoptions.cpp" line="305"/>
+        <location filename="../src/app/qgsoptions.cpp" line="303"/>
+        <location filename="../src/app/qgsoptions.cpp" line="312"/>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="338"/>
+        <location filename="../src/app/qgsoptions.cpp" line="345"/>
         <source>Central point (fastest)</source>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="339"/>
+        <location filename="../src/app/qgsoptions.cpp" line="346"/>
         <source>Chain (fast)</source>
         <translation type="unfinished">Chain (rychlý)</translation>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="340"/>
+        <location filename="../src/app/qgsoptions.cpp" line="347"/>
         <source>Popmusic tabu chain (slow)</source>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="341"/>
+        <location filename="../src/app/qgsoptions.cpp" line="348"/>
         <source>Popmusic tabu (slow)</source>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="342"/>
+        <location filename="../src/app/qgsoptions.cpp" line="349"/>
         <source>Popmusic chain (very slow)</source>
     </message>
     <message>
-        <location filename="../src/app/qgsoptions.cpp" line="819"/>
-        <location filename="../src/app/qgsoptions.cpp" line="861"/>
+        <location filename="../src/app/qgsoptions.cpp" line="827"/>
+        <location filename="../src/app/qgsoptions.cpp" line="869"/>
         <source>Choose a directory</source>
         <translation type="unfinished">Vybrat adresář</translation>
     </message>
@@ -17900,77 +17964,77 @@
         <translation>Při startu skrýt úvodní obrazovku</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="460"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="502"/>
         <source>Map display will be updated (drawn) after this many features have been read from the data source</source>
         <translation>Zobrazení mapy bude aktualizováno (vykreslené) potom, co bude daný počet objektů načten z datového zdroje</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1453"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1495"/>
         <source>...</source>
         <translation type="unfinished">...</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1217"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1259"/>
         <source>Select Global Default ...</source>
         <translation>Vybrat všeobecný standard ...</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="499"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="541"/>
         <source>Make lines appear less jagged at the expense of some drawing performance</source>
         <translation>Linie bude vykreslena jako méně roztřepená, nicméně na úkor rychlosti vykreslování</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="647"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="689"/>
         <source>Measure tool</source>
         <translation>Nástoj pro měření</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="446"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="488"/>
         <source>By default new la&amp;yers added to the map should be displayed</source>
         <translation>Zobrazení vrstvy nově přidané do mapy</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="509"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="551"/>
         <source>Fix problems with incorrectly filled polygons</source>
         <translation>Opravit nesprávně vyplněné polygony</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="611"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="653"/>
         <source>%</source>
         <translation>%</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="748"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="790"/>
         <source>Panning and zooming</source>
         <translation>Posouvat a zvětšovat</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="758"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="800"/>
         <source>Zoom</source>
         <translation>Zvětšit</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="763"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="805"/>
         <source>Zoom and recenter</source>
         <translation>Zvětšit a vycentrovat</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="773"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="815"/>
         <source>Nothing</source>
         <translation>Nic</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="946"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="988"/>
         <source>Default snapping tolerance</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="963"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1005"/>
         <source>Search radius for vertex edits</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1112"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1154"/>
         <source>Marker size</source>
         <translation type="unfinished">Velikost značky</translation>
     </message>
@@ -18000,42 +18064,42 @@
         <translation>Lokalizace</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1250"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1292"/>
         <source>Locale to use instead</source>
         <translation>Použít jinou lokalizaci</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1273"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1315"/>
         <source>Additional Info</source>
         <translation>Další info</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1279"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1321"/>
         <source>Detected active locale on your system:</source>
         <translation>Na vašem systému byla zjištěna aktivní lokalizace:</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="506"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="548"/>
         <source>Selecting this will unselect the &apos;make lines less&apos; jagged toggle</source>
         <translation>Zaškrtnutím nebude zvolena možnost &quot;tvorba méně roztřepených linií&quot; </translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="877"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="919"/>
         <source>Rubberband</source>
         <translation>Gumička</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="890"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="932"/>
         <source>Line width in pixels</source>
         <translation>Šířka linie v pixelech</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="923"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="965"/>
         <source>Snapping</source>
         <translation>Uchycení</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="768"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="810"/>
         <source>Zoom to mouse cursor</source>
         <translation>Zvětšit na kurzor myši</translation>
     </message>
@@ -18110,137 +18174,142 @@
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="440"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="428"/>
+        <source>Attribute table behaviour</source>
+    </message>
+    <message>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="482"/>
         <source>Rendering behavior</source>
         <translation>Chování vykreslování</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="453"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="495"/>
         <source>Number of features to draw before updating the display</source>
         <translation>Počet vykreslených objektů před aktualizací zobrazení</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="473"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="515"/>
         <source>&lt;b&gt;Note:&lt;/b&gt; Use zero to prevent display updates until all features have been rendered</source>
         <translation>&lt;b&gt;Poznámka:&lt;/b&gt; Nula se používá k zamezení zobrazení aktualizací dokud nebudou vykresleny všechny objekty</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="480"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="522"/>
         <source>Use render caching where possible to speed up redraws</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="490"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="532"/>
         <source>Rendering quality</source>
         <translation>Kvalita vykreslování</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="535"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="577"/>
         <source>SVG paths</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="541"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="583"/>
         <source>Path(s) to search for Scalable Vector Graphic (SVG) symbols</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="519"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="561"/>
         <source>Compatibility</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="525"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="567"/>
         <source>Use new generation symbology for rendering</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="717"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="759"/>
         <source>Preferred angle units</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="724"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="766"/>
         <source>Degrees</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="731"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="773"/>
         <source>Radians</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="738"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="780"/>
         <source>Gon</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="781"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="823"/>
         <source>Zoom factor</source>
         <translation>Zvětšovací faktor</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="788"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="830"/>
         <source>Mouse wheel action</source>
         <translation>Akce kolečka myši</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1437"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1479"/>
         <source>Cache settings</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1443"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1485"/>
         <source>Directory</source>
         <translation type="unfinished">Adresář</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1460"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1502"/>
         <source>Size</source>
         <translation type="unfinished">Velikost</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1470"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1512"/>
         <source>Clear</source>
         <translation type="unfinished">Vyčistit</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1482"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1524"/>
         <source>WMS search address</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="637"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="679"/>
         <source>Open feature form, if a single feature is identified</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="663"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="705"/>
         <source>Rubberband color</source>
         <translation>Barva pravítka</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="653"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="695"/>
         <source>Ellipsoid for distance calculations</source>
         <translation>Elipsoid pro výpočty vzdáleností</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="696"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="738"/>
         <source>Preferred measurements units</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="703"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="745"/>
         <source>Meters</source>
         <translation type="unfinished">Metry</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="710"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="752"/>
         <source>Feet</source>
         <translation type="unfinished">Stopy</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="900"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="942"/>
         <source>Line color</source>
         <translation type="unfinished">Barva čáry</translation>
     </message>
@@ -18250,98 +18319,98 @@
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="585"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="627"/>
         <source>Identify</source>
         <translation type="unfinished">Identifikovat</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="594"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="636"/>
         <source>&lt;b&gt;Note:&lt;/b&gt; Specify the search radius as a percentage of the map width</source>
         <translation>&lt;b&gt;Poznámka:&lt;/b&gt; Upřesnit poloměr hledání procentem z šířky mapy</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="604"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="646"/>
         <source>Search radius for identifying features and displaying map tips</source>
         <translation>Vyhledávací poloměr pro identifikaci objektů a zobrazení mapových tipů</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="630"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="672"/>
         <source>Mode</source>
         <translation type="unfinished">Mód</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="883"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="925"/>
         <source>Line width</source>
         <translation>Šířka linie</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="929"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="971"/>
         <source>Default snap mode</source>
         <translation>Výchozí mód úchopu</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1171"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1213"/>
         <source>Default Coordinate Reference System</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1392"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1434"/>
         <source>Exclude URLs (starting with):</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1056"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1098"/>
         <source>Vertex markers</source>
         <translation>Symboly lomových bodů</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1062"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1104"/>
         <source>Show markers only for selected features</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1069"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1111"/>
         <source>Marker style</source>
         <translation>Styl symbolu</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1241"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1283"/>
         <source>Override system locale</source>
         <translation>Potlačit lokalizaci systému</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1260"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1302"/>
         <source>&lt;b&gt;Note:&lt;/b&gt; Enabling / changing overide on local requires an application restart</source>
         <translation>&lt;b&gt;Poznámka:&lt;/b&gt; Povolení / změnění vyžaduje restart aplikace</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1306"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1348"/>
         <source>Use proxy for web access</source>
         <translation>Použít proxy pro přístup na web</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1318"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1360"/>
         <source>Host</source>
         <translation>Hostitel</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1328"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1370"/>
         <source>Port</source>
         <translation>Port</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1338"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1380"/>
         <source>User</source>
         <translation>Uživatel</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1345"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1359"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1387"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1401"/>
         <source>Leave this blank if no proxy username / password are required</source>
         <translation>Nevyplňujte pokud není vyžadováno uživatelské jméno / heslo proxy</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1352"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1394"/>
         <source>Password</source>
         <translation>Heslo</translation>
     </message>
@@ -18356,54 +18425,54 @@
         <translation>SRS</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1190"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1232"/>
         <source>Prompt for CRS</source>
         <translation>Dotaz na SRS</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1197"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1239"/>
         <source>Project wide default CRS will be used</source>
         <translation type="unfinished">Bude použito výchozí SRS projektu</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1204"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1246"/>
         <source>Global default CRS displa&amp;yed below will be used</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1135"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1177"/>
         <source>Enter attribute values</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1141"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1183"/>
         <source>Suppress attributes pop-up windows after each created feature</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1180"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1222"/>
         <source>When a new layer is created, or when a layer is loaded that has no coordinate reference system (CRS)</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1512"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1554"/>
         <source>Timeout for network requests (ms):</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1369"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1411"/>
         <source>Proxy type</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="561"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1408"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="603"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1450"/>
         <source>Add</source>
         <translation type="unfinished">Přidat</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="568"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1401"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="610"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1443"/>
         <translation type="unfinished">Odebrat</translation>
     </message>
@@ -18413,24 +18482,24 @@
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="828"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="870"/>
         <source>Position</source>
         <translation type="unfinished">Umístění</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="834"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="876"/>
         <source>Placement algorithm:</source>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="987"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1001"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1029"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1043"/>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="992"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1006"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1034"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1048"/>
     </message>
@@ -19983,18 +20052,18 @@
 <context>
     <name>QgsPostgresProvider</name>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="961"/>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="993"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="957"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="989"/>
         <source>Unable to access relation</source>
         <translation>Nelze přistoupit k relaci</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1084"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1080"/>
         <source>Unable execute the query</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1085"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1081"/>
         <source>Unable to execute the query.
 The error message from the database was:
 %1.
@@ -20002,12 +20071,12 @@
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1188"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1184"/>
         <source>No suitable key column in table</source>
         <translation>Žádný vhodný sloupec s klíčem v tabulce </translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1189"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1185"/>
         <source>The table has no column suitable for use as a key.
 Quantum GIS requires that the table either has a column of type
@@ -20018,110 +20087,110 @@
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1264"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1260"/>
         <source>The unique index on column &apos;%1&apos; is unsuitable because Quantum GIS does not currently support non-int4 type columns as a key into the table.
 </source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1289"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1285"/>
         <source>and </source>
         <translation> a</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1295"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1291"/>
         <source>The unique index based on columns %1 is unsuitable because Quantum GIS does not currently support multiple columns as a key into the table.
 </source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1338"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1334"/>
         <source>Unable to find a key column</source>
         <translation>Nelze nalézt sloupec s klíčem</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1480"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1476"/>
         <source>and is suitable.</source>
         <translation>a je vhodný.</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1486"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1482"/>
         <source> and has a suitable constraint)</source>
         <translation> a má vhodné omezení)</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1488"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1484"/>
         <source> and does not have a suitable constraint)</source>
         <translation> a nemá vhodné omezení)</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1583"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1579"/>
         <source>The view &apos;%1.%2&apos; has no column suitable for use as a unique key.
 Quantum GIS requires that the view has a column that can be used as a unique key. Such a column should be derived from a table column of type int4 and be a primary key, have a unique constraint on it, or be a PostgreSQL oid column. To improve performance the column should also be indexed.
 The view you selected has the following columns, none of which satisfy the above conditions:</source>
         <translation type="unfinished"></translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1591"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1587"/>
         <source>No suitable key column in view</source>
         <translation>Žádný vhodný klíč v pohledu</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3152"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3148"/>
         <source>Unknown geometry type</source>
         <translation>Neznámý typ geometrie</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3153"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3149"/>
         <source>Column %1 in %2 has a geometry type of %3, which Quantum GIS does not currently support.</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3160"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3156"/>
         <source>Quantum GIS was unable to determine the type and srid of column %1 in %2. The database communication log was:
 %3</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3164"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3160"/>
         <source>Unable to get feature type and srid</source>
         <translation>Nelze získat typ objektu a srid</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3284"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3280"/>
         <source>Query failed</source>
         <translation type="unfinished">Dotaz selhal</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3285"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3281"/>
         <source>%1 cursor states lost.
 SQL: %2
 Result: %3 (%4)</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2386"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2382"/>
         <source>Error while adding features</source>
         <translation>Chyba při přidávání prvků</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="282"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="278"/>
         <source>No PostGIS Support!</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="283"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="279"/>
         <source>Your database has no working PostGIS support.
 </source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="297"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="293"/>
         <source>No GEOS Support!</source>
         <translation type="unfinished">Bez podpory GEOS!</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="298"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="294"/>
         <source>Your PostGIS installation has no GEOS support.
 Feature selection and identification will not work properly.
 Please install PostGIS with GEOS support (http://geos.refractions.net)</source>
@@ -20130,84 +20199,84 @@
 Prosím nainstalujte PostGIS s podporou GEOS (http://geos.refractions.net)</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="935"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="931"/>
         <source>Ambiguous field!</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="936"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="932"/>
         <source>Duplicate field %1 found
 </source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2429"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2425"/>
         <source>Error while deleting features</source>
         <translation>Chyba při mazání prvků</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2492"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2488"/>
         <source>Error while adding attributes</source>
         <translation>Chyba při přidávání atributů</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2540"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2536"/>
         <source>Error while deleting attributes</source>
         <translation>Chyba při mazání atributů</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2611"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2607"/>
         <source>Error while changing attributes</source>
         <translation>Chyba při změně atributů</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2700"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2696"/>
         <source>Error while changing geometry values</source>
         <translation>Chyba při změnách geometrie</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.h" line="526"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.h" line="517"/>
         <source>unexpected PostgreSQL error</source>
         <translation>neočekávaný PostgreSQL error</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="167"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="163"/>
         <source>Whole number (integer - 32bit)</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="168"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="164"/>
         <source>Whole number (integer - 64bit)</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="178"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="174"/>
         <source>Text, limited variable length (varchar)</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="179"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="175"/>
         <source>Text, unlimited length (text)</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1476"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1472"/>
         <source>&apos;%1&apos; derives from &apos;%2.%3.%4&apos; </source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1484"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1480"/>
         <source>and is not suitable (type is %1)</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1572"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1568"/>
         <source>Note: &apos;%1&apos; initially appeared suitable but does not contain unique data, so is not suitable.
 </source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="962"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="958"/>
         <source>Unable to access the %1 relation.
 %2.
@@ -20215,7 +20284,7 @@
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="994"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="990"/>
         <source>Unable to determine table access privileges for the %1 relation.
 %2.
@@ -20223,32 +20292,32 @@
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="166"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="162"/>
         <source>Whole number (smallint - 16bit)</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="169"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="165"/>
         <source>Decimal number (numeric)</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="170"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="166"/>
         <source>Decimal number (decimal)</source>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="173"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="169"/>
         <source>Decimal number (real)</source>
         <translation type="unfinished">Desetinné číslo (real)</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="174"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="170"/>
         <source>Decimal number (double)</source>
         <translation type="unfinished">Desetinné číslo (double)</translation>
     </message>
     <message>
-        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="177"/>
+        <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="173"/>
         <source>Text, fixed length (char)</source>
     </message>
@@ -24570,42 +24639,42 @@
 <context>
     <name>QgsVectorLayer</name>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3185"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3184"/>
         <source>ERROR: no provider</source>
         <translation>CHYBA: žádný poskytovatel</translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3191"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3190"/>
         <source>ERROR: layer not editable</source>
         <translation>CHYBA: vrstva není editovatelná</translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3274"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3273"/>
         <source>SUCCESS: attribute %1 was added.</source>
         <translation>ÚSPĚCH:atribut %1 byl přidán.</translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3281"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3280"/>
         <source>ERROR: attribute %1 not added</source>
         <translation>CHYBA:atribut %1 nebyl přidán</translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="2690"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="2689"/>
         <source>No renderer object</source>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="2694"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="2693"/>
         <source>Classification field not found</source>
         <translation>Klasifikační pole nebylo nalezeno</translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="2684"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="2683"/>
         <source>Unknown renderer</source>
         <translation>Neznámý vykreslovač</translation>
     </message>
     <message numerus="yes">
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3205"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3204"/>
         <source>SUCCESS: %n attribute(s) deleted.</source>
         <comment>deleted attributes count</comment>
@@ -24617,7 +24686,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3211"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3210"/>
         <source>ERROR: %n attribute(s) not deleted.</source>
         <comment>not deleted attributes count</comment>
@@ -24629,7 +24698,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3227"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3226"/>
         <source>SUCCESS: %n attribute(s) added.</source>
         <comment>added attributes count</comment>
@@ -24641,7 +24710,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3233"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3232"/>
         <source>ERROR: %n new attribute(s) not added</source>
         <comment>not added attributes count</comment>
@@ -24653,7 +24722,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3343"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3342"/>
         <source>SUCCESS: %n attribute value(s) changed.</source>
         <comment>changed attribute values count</comment>
@@ -24665,7 +24734,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3348"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3347"/>
         <source>ERROR: %n attribute value change(s) not applied.</source>
         <comment>not changed attribute values count</comment>
@@ -24677,7 +24746,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3381"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3380"/>
         <source>SUCCESS: %n feature(s) added.</source>
         <comment>added features count</comment>
@@ -24689,7 +24758,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3386"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3385"/>
         <source>ERROR: %n feature(s) not added.</source>
         <comment>not added features count</comment>
@@ -24701,7 +24770,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3399"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3398"/>
         <source>SUCCESS: %n geometries were changed.</source>
         <comment>changed geometries count</comment>
@@ -24713,7 +24782,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3404"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3403"/>
         <source>ERROR: %n geometries not changed.</source>
         <comment>not changed geometries count</comment>
@@ -24725,7 +24794,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3416"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3415"/>
         <source>SUCCESS: %n feature(s) deleted.</source>
         <comment>deleted features count</comment>
@@ -24737,7 +24806,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3426"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3425"/>
         <source>ERROR: %n feature(s) not deleted.</source>
         <comment>not deleted features count</comment>
More information about the QGIS-commit mailing list
