[QGIS Commit] r13563 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon May 24 12:45:40 EDT 2010
Author: macho
Date: 2010-05-24 12:45:39 -0400 (Mon, 24 May 2010)
New Revision: 13563
   trunk/qgis/i18n/qgis_de.ts
translation update: bring german to 100% ;)
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts	2010-05-24 12:54:10 UTC (rev 13562)
+++ trunk/qgis/i18n/qgis_de.ts	2010-05-24 16:45:39 UTC (rev 13563)
@@ -29481,17 +29481,17 @@
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="336"/>
         <source>Remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed</source>
-        <translation type="unfinished"></translation>
+        <translation>Entferne Knoten in den Schwellenwert von Linien und Grenzen, Grenze wird nur beschnitten wenn Topologie nicht beschädigt ist (neue Kreuzung, veränderte Aufhängung der Schwerpunktes), erstes und letztes Segment der Grenze wird nie geändert</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="337"/>
         <source>Rename column in attribute table</source>
+        <translation>Umbenennen von Spalte in Attributtabelle</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="338"/>
         <source>Report and statistics</source>
+        <translation>Bericht und Statistik</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="339"/>
@@ -29506,187 +29506,188 @@
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="341"/>
         <source>Reproject raster from another Location</source>
+        <translation>Reprojiziere Raster von einem anderen Standort</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="342"/>
         <source>Reproject vector from another Location</source>
+        <translation>Reprojiziere Vektor von einem anderen Standort</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="343"/>
         <source>Resample raster using aggregation</source>
+        <translation>Neuberechnen von Raster mit Hilfe von Aggregation</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="344"/>
         <source>Resample raster using interpolation</source>
+        <translation>Neuberechnen von Raster mit Hilfe von Interpolation</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="345"/>
         <source>Resample raster. Set new resolution first</source>
+        <translation>Neuberechnen von Raster. Auflösung zuerst setzen</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="346"/>
         <source>Rescale the range of category values in raster</source>
+        <translation>Ändere den Maßstabsbereich der Kategoriewerte im Raster</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="347"/>
         <source>Sample raster at site locations</source>
+        <translation>Beispielraster auf Standorten</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="348"/>
         <source>Save the current region as a named region</source>
+        <translation>Speichere aktuelle Region als benannte Region</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="349"/>
         <source>Select features by attributes</source>
+        <translation>Wähle Eigenschaften nach Attributen</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="350"/>
         <source>Select features overlapped by features in another map</source>
+        <translation>Wähle Eigenschaften nach Eigenschaften einer anderen Karte</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="351"/>
         <source>Set PostgreSQL DB connection</source>
+        <translation>Setze PostgreSQL DB Verbindung</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="352"/>
         <source>Set boundary definitions by edge (n-s-e-w)</source>
+        <translation>Setze Grenzedefinitionen nach Kante (n-s-e-w)</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="353"/>
         <source>Set boundary definitions for raster</source>
+        <translation>Setze Grenzdefinitionen für Raster</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="354"/>
         <source>Set boundary definitions from raster</source>
+        <translation>Setze Grenzdefinitionen aus Raster</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="355"/>
         <source>Set boundary definitions from vector</source>
+        <translation>Setze Grenzdefinitionen aus Vektor</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="356"/>
         <source>Set boundary definitions to current or default region</source>
+        <translation>Setze Grenzdefinitionen nach aktueller oder default Region</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="357"/>
         <source>Set color rules based on stddev from a map&apos;s mean value</source>
+        <translation>Setze Farbregeln basierend auf Standardabweichung des Mittelwerts einer Karte</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="358"/>
         <source>Set general DB connection</source>
+        <translation>Setze allgemeine DB Verbindung</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="359"/>
         <source>Set general DB connection with a schema (PostgreSQL only)</source>
+        <translation>Setze Allgemeine DB Verbindung nach Schema (nur PostgreSQL)</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="360"/>
         <source>Set raster color table</source>
+        <translation>Setze Raster Farbtabelle</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="361"/>
         <source>Set raster color table from existing raster</source>
+        <translation>Setze Rasterfarbtabelle aus existierendem Raster</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="362"/>
         <source>Set raster color table from setted tables</source>
+        <translation>Setze Rasterfarbtabelle aus gesetzten Tabellen</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="363"/>
         <source>Set raster color table from user-defined rules</source>
+        <translation>Setze Rasterfarbtabelle aus benutzerdefinierten Regeln</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="364"/>
         <source>Set region to align to raster</source>
+        <translation>Setze Region ausgerichtet am Raster</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="365"/>
         <source>Set the region to match multiple rasters</source>
+        <translation>Setze Region entsprechend mehreren Rastern</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="366"/>
         <source>Set the region to match multiple vectors</source>
+        <translation>Setze Region entsprechend mehreren Vektoren</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="367"/>
         <source>Set user/password for driver/database</source>
+        <translation>Setze Benutzer/Passwort für Treiber/Datenbank</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="368"/>
         <source>Set/Show database connection for vector</source>
+        <translation>Setze/Zeige Datenbankverbindung für Vektor</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="369"/>
         <source>Sets the boundary definitions for a raster map</source>
+        <translation>Setzt die Grenzdefinitionen für eine Rasterkarte</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="370"/>
         <source>Shrink current region until it meets non-NULL data from raster</source>
+        <translation>Verkleinere aktuelle Region, bis Nicht-NULL-Daten von Rasterdaten erfüllt werden</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="371"/>
         <source>Simple map algebra</source>
+        <translation>Einfache Kartenalgebra</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="372"/>
         <source>Simplify vector</source>
+        <translation>Vereinfache Vektor</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="373"/>
         <source>Snap lines to vertex in threshold</source>
+        <translatorcomment>vertex in threshold? -&gt; Scheitelschwelle? Schwellenscheitel?</translatorcomment>
+        <translation>Fange Linien auf Schwellenscheitel</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="374"/>
         <source>Solar and irradiation model</source>
+        <translation>Solar und Bestrahlungsmodell</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="375"/>
         <source>Spatial analysis</source>
+        <translation>Räumliche Analysen</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="376"/>
         <source>Spatial models</source>
+        <translation>Räumliche Modelle</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="377"/>
         <source>Split lines to shorter segments</source>
+        <translation>Trenne Linien zu kürzeren Segmenten</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="378"/>
@@ -29711,32 +29712,32 @@
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="382"/>
         <source>Tabulate mutual occurrence (coincidence) of categories for two rasters</source>
+        <translation>Tabelliere gemeinsames Auftreten (Koinzidenz) der Klassen für zwei Raster</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="383"/>
         <source>Take vector stream data, transform it to raster, and subtract depth from the output DEM</source>
+        <translation>Nimm Vektordaten, wandle sie in Rasterdaten-und subtrahiere Tiefe aus der Ausgabe DEM</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="384"/>
         <source>Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM 4 raster</source>
+        <translation>Tasseled Cap (Thomas Kauth) Transformation für LANDSAT-TM 4 Raster</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="385"/>
         <source>Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM 5 raster</source>
+        <translation>Tasseled Cap (Thomas Kauth) Transformation für LANDSAT-TM 5 Raster</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="386"/>
         <source>Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM 7 raster</source>
+        <translation>Tasseled Cap (Thomas Kauth) Transformation für LANDSAT-TM 7 Raster</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="387"/>
         <source>Tassled cap vegetation index</source>
+        <translation>Tasseled Cap Vegetationsindex</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="388"/>
@@ -29746,7 +29747,7 @@
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="389"/>
         <source>Tests of normality on vector points</source>
+        <translation>Tests der Normalität auf Vektor-Punkten</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="390"/>
@@ -29756,12 +29757,12 @@
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="391"/>
         <source>Thin no-zero cells that denote line features</source>
+        <translation>Dünne nicht-Null-Zellen die Linieneigenschaften bezeichnen</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="392"/>
         <source>Toolset for cleaning topology of vector map</source>
+        <translation>Werkzeugsatz für die Bereinigung der Topologie einer Vektorkarte</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="393"/>
@@ -29771,57 +29772,58 @@
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="394"/>
         <source>Trace a flow through an elevation model</source>
+        <translation>Verfolge eine Strömung durch ein Höhenmodell</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="395"/>
         <source>Transform cells with value in null cells</source>
+        <translatorcomment>??</translatorcomment>
+        <translation>Transformiere-Zellen mit Wert in null Zellen</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="396"/>
         <source>Transform features</source>
+        <translation>Transformiere Funktionen</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="397"/>
         <source>Transform image</source>
+        <translation>Transformiere Bild</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="398"/>
         <source>Transform null cells in value cells</source>
+        <translation>Transformiere NULL-Zellen in Werte-Zellen</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="399"/>
         <source>Transform value cells in null cells</source>
+        <translation>Transformiere Werte-Zellen in NULL-Zellen</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="400"/>
         <source>Type in map names separated by a comma</source>
+        <translation>Geben Sie Kartennamen durch ein Komma getrennt ein</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="401"/>
         <source>Update raster statistics</source>
+        <translation>Aktualisiere Rasterstatistik</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="402"/>
         <source>Update vector map metadata</source>
+        <translation>Aktualisiere Vektorkarten Metadaten</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="403"/>
         <source>Upload raster values at positions of vector points to the table</source>
+        <translation>Lade Rasterwerte an den Positionen von Vektorpunkten in die Tabelle</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="404"/>
         <source>Upload vector values at positions of vector points</source>
+        <translation>Lade Vektorwerte an Positionen von Vektorpunkten</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="405"/>
@@ -29886,7 +29888,7 @@
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="419"/>
         <source>Zero-crossing edge detection raster function for image processing</source>
+        <translation>Nulldurchgangs Kantendetektions Rasterfunktion für die Bildverarbeitung</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="417"/>
More information about the QGIS-commit mailing list
