[QGIS Commit] r13598 - in trunk/qgis/src: app core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat May 29 18:10:56 EDT 2010
Author: mhugent
Date: 2010-05-29 18:10:55 -0400 (Sat, 29 May 2010)
New Revision: 13598
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgisapp.h
   trunk/qgis/src/core/qgsprojectfiletransform.cpp
   trunk/qgis/src/core/qgsprojectfiletransform.h
Project file transform from 1.4 to 1.5. Improved project loading for composers and annotation items to use the modified dom, not the original file. Fixes ticket #2751
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2010-05-29 18:41:56 UTC (rev 13597)
+++ trunk/qgis/src/app/qgisapp.cpp	2010-05-29 22:10:55 UTC (rev 13598)
@@ -1989,6 +1989,9 @@
   connect( QgsProject::instance(), SIGNAL( writeProject( QDomDocument& ) ),
            this, SLOT( writeAnnotationItemsToProject( QDomDocument& ) ) );
+  connect( QgsProject::instance(), SIGNAL( readProject( const QDomDocument & ) ), this, SLOT( loadComposersFromProject( const QDomDocument& ) ) );
+  connect( QgsProject::instance(), SIGNAL( readProject( const QDomDocument & ) ), this, SLOT( loadAnnotationItemsFromProject( const QDomDocument& ) ) );
   // Do we really need this ??? - its already connected to the esc key...TS
@@ -3145,10 +3148,6 @@
     // project so that they can check any project
     // specific plug-in state
-    //load the composers in the project
-    loadComposersFromProject( fullPath );
-    loadAnnotationItemsFromProject( fullPath );
     // add this to the list of recently used project files
     saveRecentProjectPath( fullPath, settings );
@@ -3203,9 +3202,6 @@
-  loadComposersFromProject( projectFile );
-  loadAnnotationItemsFromProject( projectFile );
   QSettings settings;
   saveRecentProjectPath( projectFile, settings );
@@ -4019,28 +4015,20 @@
   delete c;
-bool QgisApp::loadComposersFromProject( const QString& projectFilePath )
+bool QgisApp::loadComposersFromProject( const QDomDocument& doc )
-  //create dom document from file
-  QDomDocument projectDom;
-  QFile projectFile( projectFilePath );
-  if ( !projectFile.open( QIODevice::ReadOnly ) )
+  if ( doc.isNull() )
     return false;
-  if ( !projectDom.setContent( &projectFile, false ) )
-    return false;
   //restore each composer
-  QDomNodeList composerNodes = projectDom.elementsByTagName( "Composer" );
+  QDomNodeList composerNodes = doc.elementsByTagName( "Composer" );
   for ( int i = 0; i < composerNodes.size(); ++i )
     ++mLastComposerId;
     QgsComposer* composer = new QgsComposer( this, tr( "Composer %1" ).arg( mLastComposerId ) );
-    composer->readXML( composerNodes.at( i ).toElement(), projectDom );
+    composer->readXML( composerNodes.at( i ).toElement(), doc );
     mPrintComposers.insert( composer );
     mPrintComposersMenu->addAction( composer->windowAction() );
 #ifndef Q_OS_MACX
@@ -4068,21 +4056,8 @@
   mLastComposerId = 0;
-bool QgisApp::loadAnnotationItemsFromProject( const QString& projectFilePath )
+bool QgisApp::loadAnnotationItemsFromProject( const QDomDocument& doc )
-  QDomDocument doc;
-    return false;
-  if ( !doc.setContent( &projectFile, false ) )
-    return false;
   if ( !mMapCanvas )
     return false;
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h	2010-05-29 18:41:56 UTC (rev 13597)
+++ trunk/qgis/src/app/qgisapp.h	2010-05-29 22:10:55 UTC (rev 13598)
@@ -500,10 +500,10 @@
     void fileNew( bool thePromptToSaveFlag );
     //! Create a new empty vector layer
     void newVectorLayer();
-    #ifdef HAVE_SPATIALITE
+#ifdef HAVE_SPATIALITE
     //! Create a new empty spatialite layer
     void newSpatialiteLayer();
-    #endif
+#endif
     //! Print the current map view frame
     void newPrintComposer();
     void showComposerManager();
@@ -694,6 +694,11 @@
     void writeAnnotationItemsToProject( QDomDocument& doc );
+    /**Creates the composer instances in a project file and adds them to the menu*/
+    bool loadComposersFromProject( const QDomDocument& doc );
+    bool loadAnnotationItemsFromProject( const QDomDocument& doc );
   signals:
     /** emitted when a key is pressed and we want non widget sublasses to be able
       to pick up on this (e.g. maplayer) */
@@ -762,9 +767,8 @@
     /**Deletes all the composer objects and clears mPrintComposers*/
     void deletePrintComposers();
-    /**Creates the composer instances in a project file and adds them to the menu*/
-    bool loadComposersFromProject( const QString& projectFilePath );
     void saveAsVectorFileGeneral( bool saveOnlySelection );
     /**Returns all annotation items in the canvas*/
@@ -772,8 +776,6 @@
     /**Removes annotation items in the canvas*/
     void removeAnnotationItems();
-    bool loadAnnotationItemsFromProject( const QString& projectFilePath );
     /// QgisApp aren't copyable
     QgisApp( QgisApp const & );
Modified: trunk/qgis/src/core/qgsprojectfiletransform.cpp
--- trunk/qgis/src/core/qgsprojectfiletransform.cpp	2010-05-29 18:41:56 UTC (rev 13597)
+++ trunk/qgis/src/core/qgsprojectfiletransform.cpp	2010-05-29 22:10:55 UTC (rev 13598)
@@ -43,6 +43,9 @@
   {PFV( 1, 0, 0 ), PFV( 1, 1, 0 ), &QgsProjectFileTransform::transformNull},
   {PFV( 1, 0, 2 ), PFV( 1, 1, 0 ), &QgsProjectFileTransform::transformNull},
   {PFV( 1, 1, 0 ), PFV( 1, 2, 0 ), &QgsProjectFileTransform::transform1100to1200},
+  {PFV( 1, 2, 0 ), PFV( 1, 3, 0 ), &QgsProjectFileTransform::transformNull},
+  {PFV( 1, 3, 0 ), PFV( 1, 4, 0 ), &QgsProjectFileTransform::transformNull},
+  {PFV( 1, 4, 0 ), PFV( 1, 5, 0 ), &QgsProjectFileTransform::transform1400to1500},
 bool QgsProjectFileTransform::updateRevision( QgsProjectVersion newVersion )
@@ -384,3 +387,64 @@
   QgsPropertyValue value( units );
   value.writeXML( "LayerSnappingToleranceUnitList", digitizing, mDom );
+void QgsProjectFileTransform::transform1400to1500()
+  //Adapt the XML description of the composer legend model to version 1.5
+  if ( mDom.isNull() )
+    return;
+  //Add layer id to <VectorClassificationItem>
+  QDomNodeList layerItemList = mDom.elementsByTagName( "LayerItem" );
+  QDomElement currentLayerItemElem;
+  QString currentLayerId;
+  for ( int i = 0; i < layerItemList.size(); ++i )
+    currentLayerItemElem = layerItemList.at( i ).toElement();
+    if ( currentLayerItemElem.isNull() )
+      continue;
+    currentLayerId = currentLayerItemElem.attribute( "layerId" );
+    QDomNodeList vectorClassificationList = currentLayerItemElem.elementsByTagName( "VectorClassificationItem" );
+    QDomElement currentClassificationElem;
+    for ( int j = 0; j < vectorClassificationList.size(); ++j )
+      currentClassificationElem = vectorClassificationList.at( j ).toElement();
+      if ( !currentClassificationElem.isNull() )
+        currentClassificationElem.setAttribute( "layerId", currentLayerId );
+    //replace the text items with VectorClassification or RasterClassification items
+    QDomNodeList textItemList = currentLayerItemElem.elementsByTagName( "TextItem" );
+    QDomElement currentTextItem;
+    for ( int j = 0; j < textItemList.size(); ++j )
+      currentTextItem = textItemList.at( j ).toElement();
+      if ( currentTextItem.isNull() )
+        continue;
+      QDomElement classificationElement;
+      if ( vectorClassificationList.size() > 0 ) //we guess it is a vector layer
+        classificationElement = mDom.createElement( "VectorClassificationItem" );
+      else
+        classificationElement = mDom.createElement( "RasterClassificationItem" );
+      classificationElement.setAttribute( "layerId", currentLayerId );
+      classificationElement.setAttribute( "text", currentTextItem.attribute( "text" ) );
+      currentLayerItemElem.replaceChild( classificationElement, currentTextItem );
Modified: trunk/qgis/src/core/qgsprojectfiletransform.h
--- trunk/qgis/src/core/qgsprojectfiletransform.h	2010-05-29 18:41:56 UTC (rev 13597)
+++ trunk/qgis/src/core/qgsprojectfiletransform.h	2010-05-29 22:10:55 UTC (rev 13598)
@@ -81,6 +81,7 @@
     void transform0100to0110();
     void transform0110to1000();
     void transform1100to1200();
+    void transform1400to1500();
More information about the QGIS-commit mailing list
