[QGIS Commit] r13599 - trunk/qgis/src/plugins/labeling
svn_qgis at osgeo.org
Sat May 29 18:56:40 EDT 2010
Author: wonder
Date: 2010-05-29 18:56:39 -0400 (Sat, 29 May 2010)
New Revision: 13599
trunk/qgis/src/plugins/labeling/labelinggui.cpp
trunk/qgis/src/plugins/labeling/labelingguibase.ui
trunk/qgis/src/plugins/labeling/labelpreview.cpp
trunk/qgis/src/plugins/labeling/labelpreview.h
trunk/qgis/src/plugins/labeling/pallabeling.cpp
trunk/qgis/src/plugins/labeling/pallabeling.h
Applied patch #2739 from Marco - correct scaling of labeling from the labeling plugin in composer.
Includes few tweaks and improvements, additionally the buffer is not considered for the label frame.
Modified: trunk/qgis/src/plugins/labeling/labelinggui.cpp
--- trunk/qgis/src/plugins/labeling/labelinggui.cpp 2010-05-29 22:10:55 UTC (rev 13598)
+++ trunk/qgis/src/plugins/labeling/labelinggui.cpp 2010-05-29 22:56:39 UTC (rev 13599)
@@ -41,7 +41,7 @@
connect( btnChangeFont, SIGNAL( clicked() ), this, SLOT( changeTextFont() ) );
connect( chkBuffer, SIGNAL( toggled( bool ) ), this, SLOT( updatePreview() ) );
connect( btnBufferColor, SIGNAL( clicked() ), this, SLOT( changeBufferColor() ) );
- connect( spinBufferSize, SIGNAL( valueChanged( int ) ), this, SLOT( updatePreview() ) );
+ connect( spinBufferSize, SIGNAL( valueChanged( double ) ), this, SLOT( updatePreview() ) );
connect( btnEngineSettings, SIGNAL( clicked() ), this, SLOT( showEngineConfigDialog() ) );
// set placement methods page based on geometry type
Modified: trunk/qgis/src/plugins/labeling/labelingguibase.ui
--- trunk/qgis/src/plugins/labeling/labelingguibase.ui 2010-05-29 22:10:55 UTC (rev 13598)
+++ trunk/qgis/src/plugins/labeling/labelingguibase.ui 2010-05-29 22:56:39 UTC (rev 13599)
@@ -206,7 +206,7 @@
<item row="0" column="2">
<widget class="QLabel" name="label_9">
<property name="text">
- <string>pixels</string>
+ <string>mm</string>
</property>
</widget>
</item>
@@ -312,7 +312,7 @@
<item>
<widget class="QLabel" name="label_15">
</property>
</widget>
</item>
@@ -472,9 +472,9 @@
</widget>
</item>
<item>
- <widget class="QSpinBox" name="spinBufferSize">
- <property name="minimum">
- <number>1</number>
+ <widget class="QDoubleSpinBox" name="spinBufferSize">
+ <property name="suffix">
+ <string> mm</string>
</property>
</widget>
</item>
@@ -771,7 +771,6 @@
<tabstop>btnChangeFont</tabstop>
<tabstop>btnTextColor</tabstop>
<tabstop>chkBuffer</tabstop>
- <tabstop>spinBufferSize</tabstop>
<tabstop>btnBufferColor</tabstop>
<tabstop>sliderPriority</tabstop>
<tabstop>chkScaleBasedVisibility</tabstop>
Modified: trunk/qgis/src/plugins/labeling/labelpreview.cpp
--- trunk/qgis/src/plugins/labeling/labelpreview.cpp 2010-05-29 22:10:55 UTC (rev 13598)
+++ trunk/qgis/src/plugins/labeling/labelpreview.cpp 2010-05-29 22:56:39 UTC (rev 13599)
@@ -15,9 +15,9 @@
update();
-void LabelPreview::setBuffer( int size, QColor color )
+void LabelPreview::setBuffer( double size, QColor color )
- mBufferSize = size;
+ mBufferSize = size * 88 / 25.4; //assume standard dpi for preview
mBufferColor = color;
update();
Modified: trunk/qgis/src/plugins/labeling/labelpreview.h
--- trunk/qgis/src/plugins/labeling/labelpreview.h 2010-05-29 22:10:55 UTC (rev 13598)
+++ trunk/qgis/src/plugins/labeling/labelpreview.h 2010-05-29 22:56:39 UTC (rev 13599)
@@ -10,7 +10,7 @@
void setTextColor( QColor color );
- void setBuffer( int size, QColor color );
+ void setBuffer( double size, QColor color );
void paintEvent( QPaintEvent* e );
Modified: trunk/qgis/src/plugins/labeling/pallabeling.cpp
--- trunk/qgis/src/plugins/labeling/pallabeling.cpp 2010-05-29 22:10:55 UTC (rev 13598)
+++ trunk/qgis/src/plugins/labeling/pallabeling.cpp 2010-05-29 22:56:39 UTC (rev 13599)
@@ -60,19 +60,19 @@
const char* strId() { return mStrId.data(); }
QString text() { return mText; }
- pal::LabelInfo* info( QFontMetrics* fm, const QgsMapToPixel* xform )
+ pal::LabelInfo* info( QFontMetrics* fm, const QgsMapToPixel* xform, double fontScale )
if ( mInfo ) return mInfo;
// create label info!
QgsPoint ptZero = xform->toMapCoordinates( 0, 0 );
- QgsPoint ptSize = xform->toMapCoordinates( 0, -fm->height() );
+ QgsPoint ptSize = xform->toMapCoordinates( 0, ( int )( -fm->height() / fontScale ) );
mInfo = new pal::LabelInfo( mText.count(), ptSize.y() - ptZero.y() );
for ( int i = 0; i < mText.count(); i++ )
mInfo->char_info[i].chr = mText[i].unicode();
- ptSize = xform->toMapCoordinates( fm->width( mText[i] ), 0 );
+ ptSize = xform->toMapCoordinates(( int )( fm->width( mText[i] ) / fontScale ) , 0 );
mInfo->char_info[i].width = ptSize.x() - ptZero.x();
return mInfo;
@@ -106,6 +106,8 @@
labelPerPart = false;
mergeLines = false;
minFeatureSize = 0.0;
+ vectorScaleFactor = 1.0;
+ rasterCompressFactor = 1.0;
LayerSettings::LayerSettings( const LayerSettings& s )
@@ -127,6 +129,8 @@
labelPerPart = s.labelPerPart;
mergeLines = s.mergeLines;
minFeatureSize = s.minFeatureSize;
+ vectorScaleFactor = s.vectorScaleFactor;
+ rasterCompressFactor = s.rasterCompressFactor;
fontMetrics = NULL;
ct = NULL;
@@ -251,11 +255,12 @@
void LayerSettings::calculateLabelSize( QString text, double& labelX, double& labelY )
- //QFontMetrics fontMetrics(textFont);
- QRect labelRect = /*QRect(0,0,20,20);*/ fontMetrics->boundingRect( text );
+ QRectF labelRect = fontMetrics->boundingRect( text );
+ double w = labelRect.width() / rasterCompressFactor;
+ double h = labelRect.height() / rasterCompressFactor;
- // 2px border...
- QgsPoint ptSize = xform->toMapCoordinates( labelRect.width() + 2, labelRect.height() + 2 );
+ QgsPoint ptSize = xform->toMapCoordinates( w, h );
labelX = fabs( ptSize.x() - ptZero.x() );
labelY = fabs( ptSize.y() - ptZero.y() );
@@ -295,11 +300,11 @@
// TODO: only for placement which needs character info
pal::Feature* feat = palLayer->getFeature( lbl->strId() );
- feat->setLabelInfo( lbl->info( fontMetrics, xform ) );
+ feat->setLabelInfo( lbl->info( fontMetrics, xform, rasterCompressFactor ) );
// TODO: allow layer-wide feature dist in PAL...?
if ( dist != 0 )
- feat->setDistLabel( fabs( ptOne.x() - ptZero.x() )* dist );
+ feat->setDistLabel( fabs( ptOne.x() - ptZero.x() )* dist * vectorScaleFactor );
@@ -402,14 +407,19 @@
l->setMergeConnectedLines( lyr.mergeLines );
// set font size from points to output size
- double size = 0.3527 * lyr.textFont.pointSizeF() * ctx.scaleFactor(); //* ctx.rasterScaleFactor();
- lyr.textFont.setPixelSize(( int )size );
+ double size = 0.3527 * lyr.textFont.pointSizeF() * ctx.scaleFactor();
+ // request larger font and then scale down painter (to avoid Qt font scale bug)
+ lyr.textFont.setPixelSize(( int )( size*ctx.rasterScaleFactor() + 0.5 ) );
+ //raster and vector scale factors
+ lyr.vectorScaleFactor = ctx.scaleFactor();
+ lyr.rasterCompressFactor = ctx.rasterScaleFactor();
// save the pal layer to our layer context (with some additional info)
lyr.palLayer = l;
lyr.fieldIndex = fldIndex;
lyr.fontMetrics = new QFontMetrics( lyr.textFont );
- lyr.fontBaseline = lyr.fontMetrics->boundingRect( "X" ).bottom(); // dummy text to find out how many pixels of the text are below the baseline
lyr.xform = mMapRenderer->coordinateTransform();
if ( mMapRenderer->hasCrsTransformEnabled() )
lyr.ct = new QgsCoordinateTransform( layer->srs(), mMapRenderer->destinationSrs() );
@@ -623,16 +633,20 @@
//QgsDebugMsg( "drawLabel " + QString::number( drawBuffer ) + " " + txt );
- // shift by one as we have 2px border
painter->save();
painter->translate( QPointF( outPt.x(), outPt.y() ) );
painter->rotate( -label->getAlpha() * 180 / M_PI );
- painter->translate( QPointF( 1, -1 - lyr.fontBaseline ) );
+ // scale down painter: the font size has been multiplied by raster scale factor
+ // to workaround a Qt font scaling bug with small font sizes
+ painter->scale( 1.0 / lyr.rasterCompressFactor, 1.0 / lyr.rasterCompressFactor );
+ painter->translate( QPointF( 0, - lyr.fontMetrics->descent() ) );
if ( drawBuffer )
// we're drawing buffer
- drawLabelBuffer( painter, txt, lyr.textFont, lyr.bufferSize, lyr.bufferColor );
+ drawLabelBuffer( painter, txt, lyr.textFont, lyr.bufferSize * lyr.vectorScaleFactor * lyr.rasterCompressFactor , lyr.bufferColor );
else
@@ -654,7 +668,7 @@
-void PalLabeling::drawLabelBuffer( QPainter* p, QString text, const QFont& font, int size, QColor color )
+void PalLabeling::drawLabelBuffer( QPainter* p, QString text, const QFont& font, double size, QColor color )
p->setFont( font );
@@ -666,7 +680,9 @@
QPainterPath path;
path.addText( 0, 0, font, text );
- p->setPen( QPen( color, size ) );
+ QPen pen( color );
+ pen.setWidthF( size );
+ p->setPen( pen );
p->setBrush( color );
p->drawPath( path );
Modified: trunk/qgis/src/plugins/labeling/pallabeling.h
--- trunk/qgis/src/plugins/labeling/pallabeling.h 2010-05-29 22:10:55 UTC (rev 13598)
+++ trunk/qgis/src/plugins/labeling/pallabeling.h 2010-05-29 22:56:39 UTC (rev 13599)
@@ -60,9 +60,11 @@
bool enabled;
int priority; // 0 = low, 10 = high
bool obstacle; // whether it's an obstacle
- double dist; // distance from the feature (in pixels)
+ double dist; // distance from the feature (in mm)
+ double vectorScaleFactor; //scale factor painter units->pixels
+ double rasterCompressFactor; //pixel resolution scale factor
int scaleMin, scaleMax; // disabled if both are zero
- int bufferSize;
+ double bufferSize; //buffer size (in mm)
QColor bufferColor;
bool labelPerPart; // whether to label every feature's part or only the biggest one
bool mergeLines;
@@ -81,7 +83,6 @@
pal::Layer* palLayer;
int fieldIndex;
QFontMetrics* fontMetrics;
- int fontBaseline;
const QgsMapToPixel* xform;
const QgsCoordinateTransform* ct;
QgsPoint ptZero, ptOne;
@@ -145,7 +146,7 @@
void drawLabelCandidateRect( pal::LabelPosition* lp, QPainter* painter, const QgsMapToPixel* xform );
void drawLabel( pal::LabelPosition* label, QPainter* painter, const QgsMapToPixel* xform, bool drawBuffer = false );
- static void drawLabelBuffer( QPainter* p, QString text, const QFont& font, int size, QColor color );
+ static void drawLabelBuffer( QPainter* p, QString text, const QFont& font, double size, QColor color );
protected:
