[QGIS Commit] r14362 - trunk/qgis/src/gui/symbology-ng
svn_qgis at osgeo.org
Sun Oct 10 13:38:57 EDT 2010
Author: wonder
Date: 2010-10-10 10:38:57 -0700 (Sun, 10 Oct 2010)
New Revision: 14362
trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h
symbology-ng: Improved loading speed of the symbol properties dialog.
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
--- trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp 2010-10-10 16:29:14 UTC (rev 14361)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp 2010-10-10 17:38:57 UTC (rev 14362)
@@ -436,31 +436,58 @@
connect( spinOffsetY, SIGNAL( valueChanged( double ) ), this, SLOT( setOffset() ) );
-void QgsSvgMarkerSymbolLayerV2Widget::populateList()
+#include <QTime>
+#include <QAbstractListModel>
+class QgsSvgListModel : public QAbstractListModel
- QStandardItemModel* m = new QStandardItemModel( viewImages );
- viewImages->setModel( m );
+ public:
+ QgsSvgListModel( QObject* parent ) : QAbstractListModel( parent )
+ mSvgFiles = QgsSvgMarkerSymbolLayerV2::listSvgFiles();
- QSvgRenderer renderer;
- QPainter painter;
+ int rowCount( const QModelIndex & parent = QModelIndex() ) const
+ return mSvgFiles.count();
- foreach( QString entry, QgsSvgMarkerSymbolLayerV2::listSvgFiles() )
- // render SVG file
- renderer.load( entry );
- QPixmap pixmap( renderer.defaultSize() );
- pixmap.fill();
- painter.begin( &pixmap );
- renderer.render( &painter );
- painter.end();
+ QVariant data( const QModelIndex & index, int role = Qt::DisplayRole ) const
+ QString entry = mSvgFiles.at( index.row() );
- // add item
- QStandardItem* item = new QStandardItem( QIcon( pixmap ), QString() );
- item->setData( entry, Qt::UserRole );
- item->setToolTip( entry );
- m->appendRow( item );
+ if ( role == Qt::DecorationRole ) // icon
+ QSvgRenderer renderer;
+ QPainter painter;
+ // render SVG file
+ renderer.load( entry );
+ QPixmap pixmap( QSize( 24, 24 ) );
+ pixmap.fill();
+ painter.begin( &pixmap );
+ renderer.render( &painter );
+ painter.end();
+ return pixmap;
+ else if ( role == Qt::UserRole || role == Qt::ToolTipRole )
+ return entry;
+ return QVariant();
+ protected:
+ QStringList mSvgFiles;
+void QgsSvgMarkerSymbolLayerV2Widget::populateList()
+ QgsSvgListModel* m = new QgsSvgListModel( viewImages );
+ viewImages->setModel( m );
@@ -474,19 +501,21 @@
// set values
- QStandardItemModel* m = static_cast<QStandardItemModel*>( viewImages->model() );
+ QAbstractItemModel* m = viewImages->model();
+ QItemSelectionModel* selModel = viewImages->selectionModel();
for ( int i = 0; i < m->rowCount(); i++ )
- QStandardItem* item = m->item( i, 0 );
- if ( item->data( Qt::UserRole ).toString() == mLayer->path() )
+ QModelIndex idx( m->index( i, 0 ) );
+ if ( m->data( idx ).toString() == mLayer->path() )
- viewImages->selectionModel()->select( item->index(), QItemSelectionModel::SelectCurrent );
- viewImages->selectionModel()->setCurrentIndex( item->index(), QItemSelectionModel::SelectCurrent );
+ selModel->select( idx, QItemSelectionModel::SelectCurrent );
+ selModel->setCurrentIndex( idx, QItemSelectionModel::SelectCurrent );
break;
spinSize->setValue( mLayer->size() );
spinAngle->setValue( mLayer->angle() );
@@ -578,6 +607,8 @@
setupUi( this );
insertIcons();
updateOutlineIcon();
+ connect( mSvgListView->selectionModel(), SIGNAL( currentChanged( const QModelIndex&, const QModelIndex& ) ), this, SLOT( setFile( const QModelIndex& ) ) );
void QgsSVGFillSymbolLayerWidget::setSymbolLayer( QgsSymbolLayerV2* layer )
@@ -642,34 +673,15 @@
emit changed();
-void QgsSVGFillSymbolLayerWidget::on_mSvgListWidget_currentItemChanged( QListWidgetItem* item, QListWidgetItem* previous )
+void QgsSVGFillSymbolLayerWidget::setFile( const QModelIndex& item )
- mSVGLineEdit->setText( item->data( Qt::UserRole ).toString() );
+ mSVGLineEdit->setText( item.data( Qt::UserRole ).toString() );
void QgsSVGFillSymbolLayerWidget::insertIcons()
- mSvgListWidget->clear();
- QStringList svgFiles = QgsSvgMarkerSymbolLayerV2::listSvgFiles();
- QPainter painter;
- QStringList::const_iterator it = svgFiles.constBegin();
- for ( ; it != svgFiles.constEnd(); ++it )
- renderer.load( *it );
- pixmap.fill();
- painter.end();
- QListWidgetItem* item = new QListWidgetItem( mSvgListWidget );
- item->setData( Qt::UserRole, *it );
- item->setIcon( QIcon( pixmap ) );
- item->setToolTip( *it );
+ QgsSvgListModel* m = new QgsSvgListModel( mSvgListView );
+ mSvgListView->setModel( m );
void QgsSVGFillSymbolLayerWidget::on_mChangeOutlinePushButton_clicked()
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h
--- trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h 2010-10-10 16:29:14 UTC (rev 14361)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h 2010-10-10 17:38:57 UTC (rev 14362)
@@ -243,7 +243,7 @@
void on_mBrowseToolButton_clicked();
void on_mTextureWidthSpinBox_valueChanged( double d );
void on_mSVGLineEdit_textChanged( const QString & text );
- void on_mSvgListWidget_currentItemChanged( QListWidgetItem* item, QListWidgetItem* previous );
+ void setFile( const QModelIndex& item );
void on_mChangeOutlinePushButton_clicked();
