[QGIS Commit] r14363 - trunk/qgis/src/plugins/grass/modules-6.4
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Oct 11 02:38:38 EDT 2010
Author: pcav
Date: 2010-10-10 23:38:37 -0700 (Sun, 10 Oct 2010)
New Revision: 14363
Added:
   trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.1.png
   trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.2.png
   trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.qgm
   trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
New GRASS command. Applied patch from #3104 by Markus Neteler, with modifications
Modified: trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2010-10-10 17:38:57 UTC (rev 14362)
+++ trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2010-10-11 06:38:37 UTC (rev 14363)
@@ -5,6 +5,11 @@
 <section label="GRASS MODULES">
 	<grass name="shell"/>
+        <section label="Create new location">
+ 				<grass name="g.proj.wkt"/>
+ 	</section>
 	<section label="File">
 		<section label="Import">
 			<section label="Import raster">
Added: trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.1.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.1.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.2.png
Added: trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.qgm
--- trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.qgm	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-6.4/g.proj.wkt.qgm	2010-10-11 06:38:37 UTC (rev 14363)
@@ -0,0 +1,8 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Create new location from .prj (WKT) file" module="g.proj">
+	<flag key="c" answer="on" hidden="yes" />
+	<file key="wkt"/>
+	<file key="location"/>
+</qgisgrassmodule>
More information about the QGIS-commit mailing list
