[QGIS Commit] r15779 - in trunk/qgiswebclient: . wsgi
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Apr 20 12:34:03 EDT 2011
Author: neumann
Date: 2011-04-20 09:34:03 -0700 (Wed, 20 Apr 2011)
New Revision: 15779
Added:
   trunk/qgiswebclient/wsgi/
   trunk/qgiswebclient/wsgi/getSearchGeom.wsgi
   trunk/qgiswebclient/wsgi/search.wsgi
added wsgi scripts for search support
Added: trunk/qgiswebclient/wsgi/getSearchGeom.wsgi
--- trunk/qgiswebclient/wsgi/getSearchGeom.wsgi	                        (rev 0)
+++ trunk/qgiswebclient/wsgi/getSearchGeom.wsgi	2011-04-20 16:34:03 UTC (rev 15779)
@@ -0,0 +1,43 @@
+#!/usr/bin/python
+# -*- coding: utf-8 -*-
+#http://localhost/wsgi/getSearchGeom.wsgi?searchtable=av_user.suchtabelle&displaytext=Oberlandautobahn (Strasse, Uster)
+import re #regular expression support
+import string #string manipulation support
+from webob import Request
+from webob import Response
+import psycopg2 #PostgreSQL DB Connection
+import psycopg2.extras #z.b. für named column indexes
+import sys #für Fehlerreporting
+def application(environ, start_response):
+  request = Request(environ)
+  searchtable = request.params["searchtable"]
+  displaytext = request.params["displaytext"]
+  sql = "SELECT ST_AsText(the_geom) AS geom FROM "+searchtable+" WHERE displaytext = %(displaytext)s;"
+  errorText = ''
+  try:
+    conn = psycopg2.connect("db='yourdb' port='5432' user='yourusername' password='yourpassword'")
+  except:
+    errorText += 'error: database connection failed.'
+  cur = conn.cursor(cursor_factory=psycopg2.extras.DictCursor)
+  try:
+    cur.execute(sql,{'displaytext':displaytext})
+  except:
+    exceptionType, exceptionValue, exceptionTraceback = sys.exc_info()
+    errorText += 'error: could not execute query: '+str(exceptionValue)
+  #result = sql;
+  #result += ";" + errorText;
+  row = cur.fetchone()
+  result = row['geom']
+  response = Response(result,"200 OK",[("Content-type","text/plain"),("Content-length", str(len(result)) )])
+  conn.close()
+  return response(environ, start_response)
Property changes on: trunk/qgiswebclient/wsgi/getSearchGeom.wsgi
___________________________________________________________________
Added: svn:executable
Added: trunk/qgiswebclient/wsgi/search.wsgi
--- trunk/qgiswebclient/wsgi/search.wsgi	                        (rev 0)
+++ trunk/qgiswebclient/wsgi/search.wsgi	2011-04-20 16:34:03 UTC (rev 15779)
@@ -0,0 +1,85 @@
+#!/usr/bin/python
+#sample queries
+#http://localhost/wsgi/search.wsgi?searchtables=abwasser.such§tabelle&query=1100&cb=bla
+#http://localhost/wsgi/search.wsgi?query=Oberlandstr&cb=bla
+import json
+  searchtables = ['av_user.suchtabelle'];
+  searchtablesstring = '';
+  if "searchtables" in request.params:
+    searchtablesstring = request.params["searchtables"]
+    if len(searchtablesstring) > 0:
+      searchtables.extend(searchtablesstring.split(','))
+  querystring = request.params["query"]
+  #strip away leading and trailing whitespaces
+  querystring = querystring.strip()
+  #split on whitespaces
+  regex = re.compile(r'\s+')
+  querystrings = regex.split(querystring)
+  searchtableLength = len(searchtables)
+  querystringsLength = len(querystrings)
+  sql = ""
+  #for each table
+  for i in range(searchtableLength):
+    sql += "SELECT displaytext, '"+searchtables[i]+r"' AS searchtable, search_category, substring(search_category from 4) AS searchcat_trimmed, '['||replace(regexp_replace(BOX2D(the_geom)::text,'BOX\(|\)','','g'),' ',',')||']'::text AS bbox FROM "+searchtables[i]+" WHERE "
+    #for each querystring
+    for j in range(0, querystringsLength):
+      sql += "searchstring::tsvector @@ lower('"+querystrings[j]+":*')::tsquery"
+      if j < querystringsLength - 1:
+        sql += " AND "
+    #union for next table
+    if i < searchtableLength - 1:
+      sql += " UNION "
+  sql += " ORDER BY search_category ASC, displaytext ASC;"
+  errorText = ''
+  try:
+  except:
+    errorText += 'error: database connection failed!'
+  try:
+    cur.execute(sql)
+  except:
+  rowData = [];
+  rows = cur.fetchall()
+  lastSearchCategory = '';
+  for row in rows:
+    if lastSearchCategory != row['search_category']:
+      rowData.append({"displaytext":row['searchcat_trimmed'],"searchtable":None,"bbox":None})
+      lastSearchCategory = row['search_category']
+    rowData.append({"displaytext":row['displaytext'],"searchtable":row['searchtable'],"bbox":row['bbox']})
+  resultString = '{"results": '+json.dumps(rowData)+'}'
+  resultString = string.replace(resultString,'"bbox": "[','"bbox": [')
+  resultString = string.replace(resultString,']"}',']}')
+  #we need to add the name of the callback function if the parameter was specified
+  if "cb" in request.params:
+    resultString = request.params["cb"] + '(' + resultString + ')'
+  response = Response(resultString,"200 OK",[("Content-type","application/json"),("Content-length", str(len(resultString)) )])
+  conn.close()
Property changes on: trunk/qgiswebclient/wsgi/search.wsgi
More information about the QGIS-commit mailing list
