[QGIS Commit] r15902 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Wed Aug 10 07:57:04 EDT 2011
Author: dassau
Date: 2011-08-10 04:57:04 -0700 (Wed, 10 Aug 2011)
New Revision: 15902
Added:
docs/trunk/english_us/user_guide/qgis_server.tex
docs/trunk/english_us/user_guide/qgis_server_images/
Removed:
docs/trunk/english_us/user_guide/qgis_mapserver.tex
docs/trunk/english_us/user_guide/qgis_mapserver_images/
docs/trunk/english_us/user_guide/Makefile
docs/trunk/english_us/user_guide/user_guide.tex
renamed qgis_mapserver files to qgis_server
Modified: docs/trunk/english_us/user_guide/Makefile
--- docs/trunk/english_us/user_guide/Makefile 2011-08-04 10:03:15 UTC (rev 15901)
+++ docs/trunk/english_us/user_guide/Makefile 2011-08-10 11:57:04 UTC (rev 15902)
@@ -10,7 +10,7 @@
APPENDIX = $(wildcard appendices/*.tex)
INCLUDES = conventions.tex \
core_plugins.tex \
- qgis_mapserver.tex \
+ qgis_server.tex \
features_at_a_glance.tex \
foreword.tex \
getting_started.tex \
Deleted: docs/trunk/english_us/user_guide/qgis_mapserver.tex
--- docs/trunk/english_us/user_guide/qgis_mapserver.tex 2011-08-04 10:03:15 UTC (rev 15901)
+++ docs/trunk/english_us/user_guide/qgis_mapserver.tex 2011-08-10 11:57:04 UTC (rev 15902)
@@ -1,47 +0,0 @@
-% !TeX root = user_guide.tex
-\chapter{QGIS Mapserver}\label{label_qgismapserver}
-\index{WMS!QGISmapserver}
-% when the revision of a section has been finalized,
-% comment out the following line:
-\updatedisclaimer
-% Ripped off working_with_ogc.tex (SH: 20110330)
-QGIS mapserver is an open source WMS 1.3 implementation which, in addition,
-implements advanced cartographic features for thematic mapping. The QGIS
-mapserver is a FastCGI/CGI (Common Gateway Interface) application written in
-C++ that works together with a webserver (e.g. Apache, Lighttpd).
-It uses QGIS as backend for the GIS logic and for map rendering. Furthermore the
-Qt library is used for graphics and for platform independent
-C++ programming. In contrast to other WMS software, the QGIS mapserver uses
-cartographic rules in SLD/SE as a configuration language, both for the server
-configuration and for the user-defined cartographic rules.
-Moreover, the QGIS mapserver project provides the “Publish to Web” plugin, a
-plugin for QGIS desktop which exports the current layers and symbology as a
-web project for QGIS mapserver (containing cartographic visualisation rules
-expressed in SLD).
-As QGIS desktop and QGIS mapserver use the same visualization libraries, the
-maps that are published on the web look the same as in desktop GIS. The
-Publish to Web plugin currently supports basic symbolization, with more complex
-cartographic visualisation rules introduced manually. As the configuration is
-performed with the SLD standard and its documented extensions, there is only
-one standardised language to learn, which greatly simplifies the complexity
-of creating maps for the Web.
-In one of the following manuals we will provide a sample configuration to
-set up a QGIS mapserver. But for now we recommend to read one of the following
-URLs to get more information:
-\begin{itemize}
-\item \url{http://karlinapp.ethz.ch/qgis\_wms/} \\
-\item \url{http://www.qgis.org/wiki/QGIS\_mapserver\_tutorial} \\
-\item \url{http://linfiniti.com/2010/08/qgis-mapserver-a-wms-server-for-the-masses/}
-\end{itemize}
-\FloatBarrier
Copied: docs/trunk/english_us/user_guide/qgis_server.tex (from rev 15901, docs/trunk/english_us/user_guide/qgis_mapserver.tex)
--- docs/trunk/english_us/user_guide/qgis_server.tex (rev 0)
+++ docs/trunk/english_us/user_guide/qgis_server.tex 2011-08-10 11:57:04 UTC (rev 15902)
@@ -0,0 +1,47 @@
+% !TeX root = user_guide.tex
+\chapter{QGIS Mapserver}\label{label_qgismapserver}
+\index{WMS!QGISmapserver}
+% when the revision of a section has been finalized,
+% comment out the following line:
+\updatedisclaimer
+% Ripped off working_with_ogc.tex (SH: 20110330)
+QGIS mapserver is an open source WMS 1.3 implementation which, in addition,
+implements advanced cartographic features for thematic mapping. The QGIS
+mapserver is a FastCGI/CGI (Common Gateway Interface) application written in
+C++ that works together with a webserver (e.g. Apache, Lighttpd).
+It uses QGIS as backend for the GIS logic and for map rendering. Furthermore the
+Qt library is used for graphics and for platform independent
+C++ programming. In contrast to other WMS software, the QGIS mapserver uses
+cartographic rules in SLD/SE as a configuration language, both for the server
+configuration and for the user-defined cartographic rules.
+Moreover, the QGIS mapserver project provides the “Publish to Web” plugin, a
+plugin for QGIS desktop which exports the current layers and symbology as a
+web project for QGIS mapserver (containing cartographic visualisation rules
+expressed in SLD).
+As QGIS desktop and QGIS mapserver use the same visualization libraries, the
+maps that are published on the web look the same as in desktop GIS. The
+Publish to Web plugin currently supports basic symbolization, with more complex
+cartographic visualisation rules introduced manually. As the configuration is
+performed with the SLD standard and its documented extensions, there is only
+one standardised language to learn, which greatly simplifies the complexity
+of creating maps for the Web.
+In one of the following manuals we will provide a sample configuration to
+set up a QGIS mapserver. But for now we recommend to read one of the following
+URLs to get more information:
+\begin{itemize}
+\item \url{http://karlinapp.ethz.ch/qgis\_wms/} \\
+\item \url{http://www.qgis.org/wiki/QGIS\_mapserver\_tutorial} \\
+\item \url{http://linfiniti.com/2010/08/qgis-mapserver-a-wms-server-for-the-masses/}
+\end{itemize}
+\FloatBarrier
Modified: docs/trunk/english_us/user_guide/user_guide.tex
--- docs/trunk/english_us/user_guide/user_guide.tex 2011-08-04 10:03:15 UTC (rev 15901)
+++ docs/trunk/english_us/user_guide/user_guide.tex 2011-08-10 11:57:04 UTC (rev 15902)
@@ -31,7 +31,7 @@
\input{working_with_vector}
\input{working_with_raster}
\input{working_with_ogc}
-\input{qgis_mapserver}
+\input{qgis_server}
\input{working_with_projections}
\input{grass_integration}
\input{print_composer}
