[QGIS Commit] r15903 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Wed Aug 10 08:02:27 EDT 2011
Author: dassau
Date: 2011-08-10 05:02:27 -0700 (Wed, 10 Aug 2011)
New Revision: 15903
docs/trunk/english_us/user_guide/qgis_server.tex
changed qgis mapserver to qgis server
Modified: docs/trunk/english_us/user_guide/qgis_server.tex
--- docs/trunk/english_us/user_guide/qgis_server.tex 2011-08-10 11:57:04 UTC (rev 15902)
+++ docs/trunk/english_us/user_guide/qgis_server.tex 2011-08-10 12:02:27 UTC (rev 15903)
@@ -1,31 +1,30 @@
% !TeX root = user_guide.tex
-\chapter{QGIS Mapserver}\label{label_qgismapserver}
-\index{WMS!QGISmapserver}
+\chapter{QGIS Server}\label{label_qgisserver}
+\index{WMS!QGIS Server}
% when the revision of a section has been finalized,
% comment out the following line:
\updatedisclaimer
% Ripped off working_with_ogc.tex (SH: 20110330)
-QGIS mapserver is an open source WMS 1.3 implementation which, in addition,
+QGIS Server is an open source WMS 1.3 implementation which, in addition,
implements advanced cartographic features for thematic mapping. The QGIS
-mapserver is a FastCGI/CGI (Common Gateway Interface) application written in
+Server is a FastCGI/CGI (Common Gateway Interface) application written in
C++ that works together with a webserver (e.g. Apache, Lighttpd).
It uses QGIS as backend for the GIS logic and for map rendering. Furthermore the
Qt library is used for graphics and for platform independent
-C++ programming. In contrast to other WMS software, the QGIS mapserver uses
+C++ programming. In contrast to other WMS software, the QGIS Server uses
cartographic rules in SLD/SE as a configuration language, both for the server
configuration and for the user-defined cartographic rules.
-Moreover, the QGIS mapserver project provides the “Publish to Web” plugin, a
+Moreover, the QGIS Server project provides the “Publish to Web” plugin, a
plugin for QGIS desktop which exports the current layers and symbology as a
-web project for QGIS mapserver (containing cartographic visualisation rules
+web project for QGIS Server (containing cartographic visualisation rules
expressed in SLD).
-As QGIS desktop and QGIS mapserver use the same visualization libraries, the
+As QGIS desktop and QGIS Server use the same visualization libraries, the
maps that are published on the web look the same as in desktop GIS. The
Publish to Web plugin currently supports basic symbolization, with more complex
cartographic visualisation rules introduced manually. As the configuration is
@@ -34,7 +33,7 @@
of creating maps for the Web.
In one of the following manuals we will provide a sample configuration to
-set up a QGIS mapserver. But for now we recommend to read one of the following
+set up a QGIS Server. But for now we recommend to read one of the following
URLs to get more information:
\begin{itemize}
