[QGIS Commit] r15126 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Feb 4 05:28:05 EST 2011
Author: timlinux
Date: 2011-02-04 02:28:05 -0800 (Fri, 04 Feb 2011)
New Revision: 15126
   trunk/qgis/src/app/qgisapp.cpp
Revert "Applied patch from #3447. Button group for add layer"
This reverts commit d1dfeae396b244bcb76076ef9ab80bfc42d05587.
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2011-02-03 23:18:42 UTC (rev 15125)
+++ trunk/qgis/src/app/qgisapp.cpp	2011-02-04 10:28:05 UTC (rev 15126)
@@ -1682,47 +1682,15 @@
   mLayerToolBar = addToolBar( tr( "Manage Layers" ) );
   mLayerToolBar->setIconSize( myIconSize );
   mLayerToolBar->setObjectName( "LayerToolBar" );
-  QToolButton *bt = new QToolButton( mLayerToolBar );
-  bt->setObjectName( "AddLayer" );
-  bt->setPopupMode( QToolButton::MenuButtonPopup );
-  bt->addAction( mActionAddOgrLayer );
-  bt->addAction( mActionAddRasterLayer );
+  mLayerToolBar->addAction( mActionAddOgrLayer );
+  mLayerToolBar->addAction( mActionAddRasterLayer );
 #ifdef HAVE_POSTGRESQL
-  bt->addAction( mActionAddPgLayer );
+  mLayerToolBar->addAction( mActionAddPgLayer );
 #endif
 #ifdef HAVE_SPATIALITE
-  bt->addAction( mActionAddSpatiaLiteLayer );
+  mLayerToolBar->addAction( mActionAddSpatiaLiteLayer );
 #endif
-  bt->addAction( mActionAddWmsLayer );
-  QSettings settings;
-  switch ( settings.value( "/UI/addLayer", 0 ).toInt() )
-    default:
-    case 0:
-      bt->setDefaultAction( mActionAddOgrLayer );
-      break;
-    case 1:
-      bt->setDefaultAction( mActionAddRasterLayer );
-      break;
-    case 2:
-      bt->setDefaultAction( mActionAddPgLayer );
-      break;
-    case 3:
-      bt->setDefaultAction( mActionAddSpatiaLiteLayer );
-      break;
-    case 4:
-      bt->setDefaultAction( mActionAddWmsLayer );
-      break;
-  mLayerToolBar->addWidget( bt );
-  connect( bt, SIGNAL( triggered( QAction * ) ), this, SLOT( toolButtonActionTriggered( QAction * ) ) );
+  mLayerToolBar->addAction( mActionAddWmsLayer );
   mLayerToolBar->addAction( mActionNewVectorLayer );
   mLayerToolBar->addAction( mActionRemoveLayer );
   //commented out for QGIS 1.4 by Tim
@@ -1794,7 +1762,7 @@
   mAttributesToolBar->setObjectName( "Attributes" );
   mAttributesToolBar->addAction( mActionIdentify );
-  bt = new QToolButton( mAttributesToolBar );
+  QToolButton *bt = new QToolButton( mAttributesToolBar );
   bt->setObjectName( "SelectTool" );
   bt->addAction( mActionSelect );
@@ -1803,6 +1771,7 @@
   bt->addAction( mActionSelectFreehand );
   bt->addAction( mActionSelectRadius );
+  QSettings settings;
   switch ( settings.value( "/UI/selectTool", 0 ).toInt() )
     default:
@@ -7374,16 +7343,6 @@
     settings.setValue( "/UI/annotationTool", 1 );
   else if ( action == mActionAnnotation )
     settings.setValue( "/UI/annotationTool", 2 );
-  else if ( action == mActionAddOgrLayer )
-    settings.setValue( "/UI/addLayer", 0 );
-  else if ( action == mActionAddRasterLayer )
-    settings.setValue( "/UI/addLayer", 1 );
-  else if ( action == mActionAddPgLayer )
-    settings.setValue( "/UI/addLayer", 2 );
-  else if ( action == mActionAddSpatiaLiteLayer )
-    settings.setValue( "/UI/addLayer", 3 );
-  else if ( action == mActionAddWmsLayer )
-    settings.setValue( "/UI/addLayer", 4 );
   bt->setDefaultAction( action );
More information about the QGIS-commit mailing list
