[QGIS Commit] r15127 - in trunk/qgis/src: core/composer mapserver
svn_qgis at osgeo.org
Fri Feb 4 07:50:47 EST 2011
Author: mhugent
Date: 2011-02-04 04:50:47 -0800 (Fri, 04 Feb 2011)
New Revision: 15127
trunk/qgis/src/core/composer/qgscomposerlegenditem.cpp
trunk/qgis/src/core/composer/qgscomposerlegenditem.h
trunk/qgis/src/core/composer/qgslegendmodel.cpp
trunk/qgis/src/mapserver/qgsprojectparser.cpp
Read composer legend content from project file for WMS print (ignoring the possibility of dynamically added layers for now)
Modified: trunk/qgis/src/core/composer/qgscomposerlegenditem.cpp
--- trunk/qgis/src/core/composer/qgscomposerlegenditem.cpp 2011-02-04 10:28:05 UTC (rev 15126)
+++ trunk/qgis/src/core/composer/qgscomposerlegenditem.cpp 2011-02-04 12:50:47 UTC (rev 15127)
@@ -105,7 +105,7 @@
elem.appendChild( vectorClassElem );
-void QgsComposerSymbolItem::readXML( const QDomElement& itemElem )
+void QgsComposerSymbolItem::readXML( const QDomElement& itemElem, bool xServerAvailable )
if ( itemElem.isNull() )
@@ -123,6 +123,10 @@
QgsSymbol* symbol = new QgsSymbol( vLayer->geometryType() );
symbol->readXML( symbolElem, vLayer );
setSymbol( symbol );
+ if ( !xServerAvailable ) //don't read icon without GUI
+ return;
//add icon
switch ( symbol->type() )
@@ -193,7 +197,7 @@
-void QgsComposerSymbolV2Item::readXML( const QDomElement& itemElem )
+void QgsComposerSymbolV2Item::readXML( const QDomElement& itemElem, bool xServerAvailable )
@@ -213,7 +217,10 @@
if ( symbolNg )
setSymbolV2( symbolNg );
- setIcon( QgsSymbolLayerV2Utils::symbolPreviewIcon( symbolNg, QSize( 30, 30 ) ) );
+ if ( xServerAvailable )
+ setIcon( QgsSymbolLayerV2Utils::symbolPreviewIcon( symbolNg, QSize( 30, 30 ) ) );
@@ -259,7 +266,7 @@
elem.appendChild( rasterClassElem );
-void QgsComposerRasterSymbolItem::readXML( const QDomElement& itemElem )
+void QgsComposerRasterSymbolItem::readXML( const QDomElement& itemElem, bool xServerAvailable )
@@ -269,7 +276,7 @@
setLayerID( itemElem.attribute( "layerId", "" ) );
QgsRasterLayer* rLayer = qobject_cast<QgsRasterLayer*>( QgsMapLayerRegistry::instance()->mapLayer( mLayerID ) );
- if ( rLayer )
+ if ( rLayer && xServerAvailable )
setIcon( QIcon( rLayer->legendAsPixmap( true ) ) );
@@ -306,7 +313,7 @@
elem.appendChild( layerItemElem );
-void QgsComposerLayerItem::readXML( const QDomElement& itemElem )
+void QgsComposerLayerItem::readXML( const QDomElement& itemElem, bool xServerAvailable )
@@ -348,7 +355,7 @@
continue; //unsupported child type
- currentChildItem->readXML( currentElem );
+ currentChildItem->readXML( currentElem, xServerAvailable );
appendRow( currentChildItem );
@@ -382,7 +389,7 @@
elem.appendChild( layerGroupElem );
-void QgsComposerGroupItem::readXML( const QDomElement& itemElem )
+void QgsComposerGroupItem::readXML( const QDomElement& itemElem, bool xServerAvailable )
@@ -420,7 +427,7 @@
continue; //unsupported child item type
Modified: trunk/qgis/src/core/composer/qgscomposerlegenditem.h
--- trunk/qgis/src/core/composer/qgscomposerlegenditem.h 2011-02-04 10:28:05 UTC (rev 15126)
+++ trunk/qgis/src/core/composer/qgscomposerlegenditem.h 2011-02-04 12:50:47 UTC (rev 15127)
@@ -42,7 +42,9 @@
virtual void writeXML( QDomElement& elem, QDomDocument& doc ) const = 0;
- virtual void readXML( const QDomElement& itemElem ) = 0;
+ /**Read item content from xml
+ @param xServerAvailable Read item icons if true (QIcon needs x-server)*/
+ virtual void readXML( const QDomElement& itemElem, bool xServerAvailable = true ) = 0;
virtual ItemType itemType() const = 0;
virtual QStandardItem* clone() const = 0;
@@ -64,7 +66,7 @@
virtual QStandardItem* clone() const;
virtual void writeXML( QDomElement& elem, QDomDocument& doc ) const;
- virtual void readXML( const QDomElement& itemElem );
+ virtual void readXML( const QDomElement& itemElem, bool xServerAvailable = true );
/**Set symbol (takes ownership)*/
void setSymbol( QgsSymbol* s );
@@ -93,7 +95,7 @@
void setSymbolV2( QgsSymbolV2* s );
@@ -116,7 +118,7 @@
void setLayerID( const QString& id ) { mLayerID = id; }
QString layerID() const { return mLayerID; }
@@ -135,7 +137,7 @@
ItemType itemType() const { return LayerItem; }
@@ -155,7 +157,7 @@
ItemType itemType() const { return GroupItem; }
Modified: trunk/qgis/src/core/composer/qgslegendmodel.cpp
--- trunk/qgis/src/core/composer/qgslegendmodel.cpp 2011-02-04 10:28:05 UTC (rev 15126)
+++ trunk/qgis/src/core/composer/qgslegendmodel.cpp 2011-02-04 12:50:47 UTC (rev 15127)
@@ -507,7 +507,7 @@
currentItem = new QgsComposerGroupItem();
- currentItem->readXML( currentElem );
+ currentItem->readXML( currentElem, mHasTopLevelWindow );
appendRow( currentItem );
Modified: trunk/qgis/src/mapserver/qgsprojectparser.cpp
--- trunk/qgis/src/mapserver/qgsprojectparser.cpp 2011-02-04 10:28:05 UTC (rev 15126)
+++ trunk/qgis/src/mapserver/qgsprojectparser.cpp 2011-02-04 12:50:47 UTC (rev 15127)
@@ -904,9 +904,14 @@
//legend needs to be loaded indirectly to have generic content
//and to avoid usage of x-server with pixmap icons
+ //read full legend from xml
QgsComposerLegend* legend = new QgsComposerLegend( composition );
- legend->_readXML( currentElem.firstChildElement( "ComposerItem" ), *mXMLDoc );
- legend->updateLegend();
+ legend->readXML( currentElem, *mXMLDoc );
+ //dynamic legend (would be interesting in case of layers dynamically defined in SLD)
+ //legend->_readXML( currentElem.firstChildElement( "ComposerItem" ), *mXMLDoc );
+ //legend->updateLegend();
composition->addItem( legend );
else if ( elemName == "ComposerShape" )
