[QGIS Commit] r15147 - in trunk/qgis/src: core gui
svn_qgis at osgeo.org
Wed Feb 9 11:27:05 EST 2011
Author: jef
Date: 2011-02-09 08:27:05 -0800 (Wed, 09 Feb 2011)
New Revision: 15147
trunk/qgis/src/core/qgsclipper.h
trunk/qgis/src/core/qgsmaplayer.h
trunk/qgis/src/core/qgsproject.cpp
trunk/qgis/src/gui/qgisgui.h
trunk/qgis/src/gui/qgssearchquerybuilder.h
doxygen fixes
Modified: trunk/qgis/src/core/qgsclipper.h
--- trunk/qgis/src/core/qgsclipper.h 2011-02-09 08:33:10 UTC (rev 15146)
+++ trunk/qgis/src/core/qgsclipper.h 2011-02-09 16:27:05 UTC (rev 15147)
@@ -118,7 +118,7 @@
@param y1 y-coordinate of the second line start
@param clipRect clip rectangle
@param pts: in/out array of clipped points
- @param writePtr in/out: writing poisiton in the wkb array*/
static void connectSeparatedLines( double x0, double y0, double x1, double y1,
const QgsRectangle& clipRect, QPolygonF& pts );
Modified: trunk/qgis/src/core/qgsmaplayer.h
--- trunk/qgis/src/core/qgsmaplayer.h 2011-02-09 08:33:10 UTC (rev 15146)
+++ trunk/qgis/src/core/qgsmaplayer.h 2011-02-09 16:27:05 UTC (rev 15147)
@@ -374,7 +374,8 @@
/** Read custom properties from project file. Added in v1.4
- @param keyStartsWith reads only properties starting with the specified string (or all if the string is empty)*/
+ @param layerNode note to read from
+ @param keyStartsWith reads only properties starting with the specified string (or all if the string is empty)*/
void readCustomProperties( QDomNode & layerNode, const QString& keyStartsWith = "" );
/** Write custom properties to project file. Added in v1.4 */
Modified: trunk/qgis/src/core/qgsproject.cpp
--- trunk/qgis/src/core/qgsproject.cpp 2011-02-09 08:33:10 UTC (rev 15146)
+++ trunk/qgis/src/core/qgsproject.cpp 2011-02-09 16:27:05 UTC (rev 15147)
@@ -748,9 +748,9 @@
@note it's presumed that the caller has already reset the map canvas, map registry, and legend
bool QgsProject::read()
clearError();
Modified: trunk/qgis/src/gui/qgisgui.h
--- trunk/qgis/src/gui/qgisgui.h 2011-02-09 08:33:10 UTC (rev 15146)
+++ trunk/qgis/src/gui/qgisgui.h 2011-02-09 16:27:05 UTC (rev 15147)
@@ -78,8 +78,8 @@
/** A helper function to get an image name from the user. It will nicely
* provide filters with all available writable image formats.
- * @param QWidget - widget that should act as the parent for the file dialog
- * @param QString the message to display to the user
+ * @param theParent widget that should act as the parent for the file dialog
+ * @param theMessage the message to display to the user
* @return QPair<QString, QString> where first is the file name and second is
* the file type
* @note added in 1.6
Modified: trunk/qgis/src/gui/qgssearchquerybuilder.h
--- trunk/qgis/src/gui/qgssearchquerybuilder.h 2011-02-09 08:33:10 UTC (rev 15146)
+++ trunk/qgis/src/gui/qgssearchquerybuilder.h 2011-02-09 16:27:05 UTC (rev 15147)
@@ -73,7 +73,6 @@
/*! Test the constructed search string to see if it's correct.
* The number of rows that would be returned is displayed in a message box.
- * @param showResults If true, the results are displayed in a QMessageBox
void on_btnTest_clicked();
