[Qgis-community-team] Re: [QGIS Commit] r8972 -docs/trunk/english_us/user_guide/plugins_grass_module_images
Werner Macho werner.macho at gmail.com
Sat Aug 2 08:11:53 EDT 2008
hi!
ok i saw a lot of mistakes i made but i hope i can finish update to new
conventions this weekend .. still working on it.
Is there already any decision about screenshots? because in the plugins
section there are many screenshots referred.. So what to do with the
includegraphics?
do we make a screenshot session some time?
regards and nice weekend
Werner
Otto Dassau wrote:
> Hi Werner,
> just saw your commit log to the manual below:
> On Fri,  1 Aug 2008 18:27:58 -0400 (EDT)
> svn_qgis at osgeo.org wrote:
>> Author: macho
>> Date: 2008-08-01 18:27:58 -0400 (Fri, 01 Aug 2008)
>> New Revision: 8972
>> Added:
>>    docs/trunk/english_us/user_guide/plugins_grass_module_images/grasslogo.png
>> Log:
>> logo for grass toolbox .. is it allowed to add it here?
> the images folders contain images and icons from the qgis sources. We just added
> an updateicon option to the Makefile to update these folders automatically. But
> this option deletes all png files from the /images folders.
> So I moved your grasslogo.png to the /grass_integration_screenies folder. This
> prevents it from beeing removed during 'make updateicon'.
> Another note. You don't have to write the path to the png icons in the figure
> definition in latex, as you did in plugins.tex. All png images are converted to
> .eps format and copied to the folder ./finalpix. During compilation latex
> assumes all images are in that folder as .eps, so you only have to write down
> the image name without suffix .eps.
> wrong example:
> \includegraphics[width=0.7cm]{plugins_gps_images/gps_importer}
> correct exmaple:
> \includegraphics[width=0.7cm]{gps_importer}
>  regards,
>    otto
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
