[Qgis-community-team] Re: more latex questions
Otto Dassau otto.dassau at gmx.de
Wed Jun 4 16:59:28 EDT 2008
Hi Thomas,
Am Mittwoch, den 04.06.2008, 22:06 +0200 schrieb Thomas Becker:
> Hi Tara,
> I haven't got SVN access for now so I took the current branch (0.9.1)
> from the repository using wget.
please take the current english trunk with the conventions etc, the
translation branches are old, because that is what we will work with.
svn co https://svn.osgeo.org/qgis/docs/trunk/english_us/user_guide
regards,
  Otto
> Now I am sitting here trying to compile the user_guide.tex and it
> appears to me
> that there are several superseded versions of packages used within
> qgis_syle.sty. Your log file is giving already hints about several
> documentclasses that are obsolete, furthermore my advise while using the
> KOMA classes would be to use scrpage2 instead of fancyheadings.
> Another thing that bugs me is all the stuff about even and odd pages. At
> the beginning it is said that the document should be set as an article.
> This documentclass doesn't support even and odd pages per default.
> However we can turn it on by using the class option twoside.
> In qgis_style.sty the fancyheadings has a setup for even and odd pages.
> Should the documentation be set in oneside or twoside mode?
> If you dont mind I will have a look further into the qgis_style.sty to
> get a first run-trough of LaTeX.
> Cheers, Thomas
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
