[Qgis-community-team] Re: Timeline - manual conventions
Otto Dassau otto.dassau at gmx.de
Thu Jun 5 02:40:08 EDT 2008
Hi Stephan,
have you already created an account at osgeo and then written to Gary for svn
access with that account?
Thanks a lot for your quick work! Have you found any missing/useful style macros
in the text, or do you think, the current are enough?
regards,
 Otto
On Thu, 5 Jun 2008 08:11:53 +0200
Stephan Holl <stephan.holl at intevation.de> wrote:
> Hello Tara,
> Tara Athan <tara_athan at alt2is.com>, [20080604 - 09:56:46]
> > Stephan - thanks for your offer of assistance!  Once the qgis website
> > is back on track, I will post trac tickets for each of the sections,
> > and assign sections 4-7 to you.
> > Does June 15 seem like a reasonable date to get this conversion
> > completed?
> I am done with it and waiting to get it commited since my svn-account
> does not seem to work anymore after the merge to OSGeo-infrastructure.
> I will give it a try once more to test if my osgeo-id works though.
> > By that time, I plan to have a new dataset up on the
> > website, and then we would move on the next task, which is modifying
> > examples, or adding them, based on a consistent dataset.
> Best
> 	Stephan
> > PS - Community Team: we still need lots of help applying these
> > conventions to the other sections. This is a test - do we have enough
> > support from the community team to boost the quality of the manual?
> > Stephan Holl wrote:
> > > Hallo Tara,
> > > Tara Athan <tara_athan at alt2is.com>, [20080601 - 01:12:59]
> > >> I have added a subsection to the Forward (in the Manual) to define
> > >> style conventions, and implemented the styles in the Getting
> > >> Started section. The conventions are defined as macros, so that we
> > >> can easily change a convention and have it be uniformly applied
> > >> throughout the manual. Examples are Buttons, Menu Options, text
> > >> input by users and so on. Also included are macros that apply to
> > >> instructions that are platform-specific- see the Starting QGIS
> > >> section for a demonstration.
> > >> The actual styles are placeholders- we can modify them to provide
> > >> better visual cues to the reader. For example, we can add icons for
> > >> the platform-specific instructions. At present the \tab macro is
> > >> just a copy of the \button macro, but someone (with more latex
> > >> experience than I) might write a style that looks more like a tab.
> > >> * For this to work, we need all sections of the manual to be
> > >> updated to use these macros.
> > >> * Would anyone like to volunteer to update a section (4-13) or
> > >> appendix (A-H)?
> > > I volunteer to update section 4-7 to include the new macro-usage.
> > >> * We may find a need for additional macros as we go through the
> > >> rest of the sections- please let us know if you
> > >> * find a situation that doesn't fit into any of the existing macros
> > >> and we will add a new one to the list.
> > >> * Would anyone like to improve the macros? When I compile, (on
> > >> Windows) I have missing font problems so I can't really
> > >> * tell what it looks like. Ideally, the manual item should look
> > >> very similar to the GUI item.
> > > Do you have posted a timeline for updating the manuel so far?
> > > Best regards
> > > 	Stephan
More information about the Qgis-community-team mailing list
