[Qgis-community-team] conventions
Tara Athan tara_athan at alt2is.com
Thu Jun 5 10:46:11 EDT 2008
After looking at Otto's revision, I think I have not been clear about
which macros apply to which  GUI items.
\button  - I was thinking of this one to be used when the button has no
icon, just text. Save As Default is a button that appears in the Layer
Properties dialog. So to reproduce the appearance of the version 0.10
GUI, it would have text inside a box with slightly rounded corners, with
a shadow to indicate it is clickable. The fill is a gray gradient - I
don't know if this is reproducible in latex.
\toolbtn - I was thinking of this one for the icons that appear in the
toolbars. Per earlier e-mail, this should perhaps have 2 required
arguments, the icon and the label (tooltip). The icon would have the
shadow, since it is the clickable part, and the tooltip could have a
yellow fill. For this to work, we need to have all the GUI icons present
in the image folders. In a very quick check, I could not find, for
example, the print icon, unless it appears under another name.
\toolbox - This was intended for GRASS tools. In skimming through the
toolbox, I see that many tools are indicated by multiple icons, such as
the conversion tools. So perhaps this macro requires multiple versions
to accommodate different numbers of icons. The whole line is clickable,
so it would have a shadowbox around all the icons and label.
\menuopt - There are two kinds of menu options - the first level has no
icons (like File), the second level sometimes has icons  (like New
Project). Do we need a second menuopt macro (menuopt2 ?) that also
requires the icon? I am inclined to NOT include the shortcuts in the
macro, even though they appear in the GUI. We can leave it to the
writers choice whether to mention the shortcut, using the keystroke macros.
On a more general note, I am thinking that the appearance we should try
to reproduce is the non-hover version, because if a new user is scanning
the GUI for something that looks like what they see in the manual, it
would be misleading to show an appearance that would only match if they
were hovering on the right item already.  So I am thinking for a menu
option, such as File, we could have a shadowbox with gray fill and no
outline.
I haven't made any of these changes yet - please let me know what you
think. Also, it would be helpful to know if the appearance will be
dramatically different in the version 1.0 GUI (Tim?)
Tara
PS I haven't been able to figure out the syntax for \shadowsize - does
anyone have experience with the fancybox package to know how this works?
More information about the Qgis-community-team mailing list
