[Qgis-community-team] Re: conventions
Otto Dassau otto.dassau at gmx.de
Thu Jun 5 11:29:34 EDT 2008
Hi Tara,
Now it became a lot clearer to me, and it sounds very nice - almost see it in
the manual :). When you have finally decided which macros to apply to which GUI,
please add your notes as below to the convention.tex file and I will review and
update my chapters 8-10 according to your conventions.
thanks a lot for your work!
regards,
 Otto
On Thu, 05 Jun 2008 07:46:11 -0700
Tara Athan <tara_athan at alt2is.com> wrote:
> After looking at Otto's revision, I think I have not been clear about
> which macros apply to which  GUI items.
> \button  - I was thinking of this one to be used when the button has no
> icon, just text. Save As Default is a button that appears in the Layer
> Properties dialog. So to reproduce the appearance of the version 0.10
> GUI, it would have text inside a box with slightly rounded corners, with
> a shadow to indicate it is clickable. The fill is a gray gradient - I
> don't know if this is reproducible in latex.
> \toolbtn - I was thinking of this one for the icons that appear in the
> toolbars. Per earlier e-mail, this should perhaps have 2 required
> arguments, the icon and the label (tooltip). The icon would have the
> shadow, since it is the clickable part, and the tooltip could have a
> yellow fill. For this to work, we need to have all the GUI icons present
> in the image folders. In a very quick check, I could not find, for
> example, the print icon, unless it appears under another name.
> \toolbox - This was intended for GRASS tools. In skimming through the
> toolbox, I see that many tools are indicated by multiple icons, such as
> the conversion tools. So perhaps this macro requires multiple versions
> to accommodate different numbers of icons. The whole line is clickable,
> so it would have a shadowbox around all the icons and label.
> \menuopt - There are two kinds of menu options - the first level has no
> icons (like File), the second level sometimes has icons  (like New
> Project). Do we need a second menuopt macro (menuopt2 ?) that also
> requires the icon? I am inclined to NOT include the shortcuts in the
> macro, even though they appear in the GUI. We can leave it to the
> writers choice whether to mention the shortcut, using the keystroke macros.
> On a more general note, I am thinking that the appearance we should try
> to reproduce is the non-hover version, because if a new user is scanning
> the GUI for something that looks like what they see in the manual, it
> would be misleading to show an appearance that would only match if they
> were hovering on the right item already.  So I am thinking for a menu
> option, such as File, we could have a shadowbox with gray fill and no
> outline.
> I haven't made any of these changes yet - please let me know what you
> think. Also, it would be helpful to know if the appearance will be
> dramatically different in the version 1.0 GUI (Tim?)
> Tara
> PS I haven't been able to figure out the syntax for \shadowsize - does
> anyone have experience with the fancybox package to know how this works?
More information about the Qgis-community-team mailing list
