[Qgis-community-team] conventions
Tim Sutton tim at linfiniti.com
Thu Jun 5 16:43:22 EDT 2008
Hi Tara
One thing I would suggest is to always use the exact same icon names
as used in qgis/images/themes/default/ so that any future changes to
the icons can be sychronised to the manual simply by copying over the
icons from the source tree into the manual tree. Ditto for the grass
icons.
with regards to ui changes, I would suggest getting hold of a snapshot
of the code from trunk (perhaps Marco Pasetti can help you with a
snapshot build for win on an occasional basis). i have already made
many revisions to the ui for the upcoming 0.11.0 release - mainly with
an eye towards visual consistancy and general cleanups. Around about
the 15th of this month we will enter feature freeze and I will try as
much as possible to refrain from making further ui changes in the run
up to releasing 1.0. Where such changes are unavoidable (labelling and
composer will be two such cases) we will try to keep you informed as
to what needs updating.
best regards
Tim
On 6/5/08, Tara Athan <tara_athan at alt2is.com> wrote:
> After looking at Otto's revision, I think I have not been clear about
> which macros apply to which  GUI items.
> \button  - I was thinking of this one to be used when the button has no
> icon, just text. Save As Default is a button that appears in the Layer
> Properties dialog. So to reproduce the appearance of the version 0.10
> GUI, it would have text inside a box with slightly rounded corners, with
> a shadow to indicate it is clickable. The fill is a gray gradient - I
> don't know if this is reproducible in latex.
> \toolbtn - I was thinking of this one for the icons that appear in the
> toolbars. Per earlier e-mail, this should perhaps have 2 required
> arguments, the icon and the label (tooltip). The icon would have the
> shadow, since it is the clickable part, and the tooltip could have a
> yellow fill. For this to work, we need to have all the GUI icons present
> in the image folders. In a very quick check, I could not find, for
> example, the print icon, unless it appears under another name.
> \toolbox - This was intended for GRASS tools. In skimming through the
> toolbox, I see that many tools are indicated by multiple icons, such as
> the conversion tools. So perhaps this macro requires multiple versions
> to accommodate different numbers of icons. The whole line is clickable,
> so it would have a shadowbox around all the icons and label.
> \menuopt - There are two kinds of menu options - the first level has no
> icons (like File), the second level sometimes has icons  (like New
> Project). Do we need a second menuopt macro (menuopt2 ?) that also
> requires the icon? I am inclined to NOT include the shortcuts in the
> macro, even though they appear in the GUI. We can leave it to the
> writers choice whether to mention the shortcut, using the keystroke macros.
> On a more general note, I am thinking that the appearance we should try
> to reproduce is the non-hover version, because if a new user is scanning
> the GUI for something that looks like what they see in the manual, it
> would be misleading to show an appearance that would only match if they
> were hovering on the right item already.  So I am thinking for a menu
> option, such as File, we could have a shadowbox with gray fill and no
> outline.
> I haven't made any of these changes yet - please let me know what you
> think. Also, it would be helpful to know if the appearance will be
> dramatically different in the version 1.0 GUI (Tim?)
> Tara
> PS I haven't been able to figure out the syntax for \shadowsize - does
> anyone have experience with the fancybox package to know how this works?
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Sent from my mobile device
Tim Sutton
QGIS Project Steering Committee Member - Release  Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
More information about the Qgis-community-team mailing list
