[Qgis-community-team] Re: images
Tara Athan tara_athan at alt2is.com
Fri Jun 6 11:39:12 EDT 2008
Tim -I looked in
qgis/images/themes/default/
It does not seem to include all of the images that are needed (GRASS
tools?, addpostjgis?)
Is this collection still under development?
If so, I think we need to wait to switch to these icons - otherwise
there will be a mix of old/new or new/missing.
Tara
Tim Sutton wrote:
> Hi Tara
> One thing I would suggest is to always use the exact same icon names
> as used in qgis/images/themes/default/ so that any future changes to
> the icons can be sychronised to the manual simply by copying over the
> icons from the source tree into the manual tree. Ditto for the grass
> icons.
> with regards to ui changes, I would suggest getting hold of a snapshot
> of the code from trunk (perhaps Marco Pasetti can help you with a
> snapshot build for win on an occasional basis). i have already made
> many revisions to the ui for the upcoming 0.11.0 release - mainly with
> an eye towards visual consistancy and general cleanups. Around about
> the 15th of this month we will enter feature freeze and I will try as
> much as possible to refrain from making further ui changes in the run
> up to releasing 1.0. Where such changes are unavoidable (labelling and
> composer will be two such cases) we will try to keep you informed as
> to what needs updating.
> best regards
> Tim
> On 6/5/08, Tara Athan <tara_athan at alt2is.com> wrote:
>> After looking at Otto's revision, I think I have not been clear about
>> which macros apply to which  GUI items.
>> \button  - I was thinking of this one to be used when the button has no
>> icon, just text. Save As Default is a button that appears in the Layer
>> Properties dialog. So to reproduce the appearance of the version 0.10
>> GUI, it would have text inside a box with slightly rounded corners, with
>> a shadow to indicate it is clickable. The fill is a gray gradient - I
>> don't know if this is reproducible in latex.
>> \toolbtn - I was thinking of this one for the icons that appear in the
>> toolbars. Per earlier e-mail, this should perhaps have 2 required
>> arguments, the icon and the label (tooltip). The icon would have the
>> shadow, since it is the clickable part, and the tooltip could have a
>> yellow fill. For this to work, we need to have all the GUI icons present
>> in the image folders. In a very quick check, I could not find, for
>> example, the print icon, unless it appears under another name.
>> \toolbox - This was intended for GRASS tools. In skimming through the
>> toolbox, I see that many tools are indicated by multiple icons, such as
>> the conversion tools. So perhaps this macro requires multiple versions
>> to accommodate different numbers of icons. The whole line is clickable,
>> so it would have a shadowbox around all the icons and label.
>> \menuopt - There are two kinds of menu options - the first level has no
>> icons (like File), the second level sometimes has icons  (like New
>> Project). Do we need a second menuopt macro (menuopt2 ?) that also
>> requires the icon? I am inclined to NOT include the shortcuts in the
>> macro, even though they appear in the GUI. We can leave it to the
>> writers choice whether to mention the shortcut, using the keystroke macros.
>> On a more general note, I am thinking that the appearance we should try
>> to reproduce is the non-hover version, because if a new user is scanning
>> the GUI for something that looks like what they see in the manual, it
>> would be misleading to show an appearance that would only match if they
>> were hovering on the right item already.  So I am thinking for a menu
>> option, such as File, we could have a shadowbox with gray fill and no
>> outline.
>> I haven't made any of these changes yet - please let me know what you
>> think. Also, it would be helpful to know if the appearance will be
>> dramatically different in the version 1.0 GUI (Tim?)
>> Tara
>> PS I haven't been able to figure out the syntax for \shadowsize - does
>> anyone have experience with the fancybox package to know how this works?
>> Qgis-community-team mailing list
>> Qgis-community-team at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> No virus found in this incoming message.
> Checked by AVG.
> Version: 8.0.100 / Virus Database: 270.0.0/1485 - Release Date: 6/5/2008 10:07 AM
My e-mail delivery has been unreliable lately, so I am asking for
return receipts from all my email messages.
OK'ing the return receipt lets me know that my message was delivered.
Thank you.
Tara Athan
Principal, Alternatives to Invasive Species
tara_athan [AT] alt2is.com
707-485-1198
PO Box 415
Redwood Valley, CA 95470
More information about the Qgis-community-team mailing list
