[Qgis-community-team] Re: images
Tim Sutton tim at linfiniti.com
Fri Jun 6 11:50:58 EDT 2008
Hi
As I briefly mentioned:
>> icons from the source tree into the manual tree. Ditto for the grass
>> icons.
But to explain better, ther grass icons live under:
src/plugins/grass/modules/
Best regards
Tim
2008/6/6 Tara Athan <tara_athan at alt2is.com>:
> Tim -I looked in
> qgis/images/themes/default/
> It does not seem to include all of the images that are needed (GRASS tools?,
> addpostjgis?)
> Is this collection still under development?
> If so, I think we need to wait to switch to these icons - otherwise there
> will be a mix of old/new or new/missing.
> Tara
> Tim Sutton wrote:
>> Hi Tara
>> One thing I would suggest is to always use the exact same icon names
>> as used in qgis/images/themes/default/ so that any future changes to
>> the icons can be sychronised to the manual simply by copying over the
>> icons.
>> with regards to ui changes, I would suggest getting hold of a snapshot
>> of the code from trunk (perhaps Marco Pasetti can help you with a
>> snapshot build for win on an occasional basis). i have already made
>> many revisions to the ui for the upcoming 0.11.0 release - mainly with
>> an eye towards visual consistancy and general cleanups. Around about
>> the 15th of this month we will enter feature freeze and I will try as
>> much as possible to refrain from making further ui changes in the run
>> up to releasing 1.0. Where such changes are unavoidable (labelling and
>> composer will be two such cases) we will try to keep you informed as
>> to what needs updating.
>> best regards
>> Tim
>> On 6/5/08, Tara Athan <tara_athan at alt2is.com> wrote:
>>> After looking at Otto's revision, I think I have not been clear about
>>> which macros apply to which  GUI items.
>>> \button  - I was thinking of this one to be used when the button has no
>>> icon, just text. Save As Default is a button that appears in the Layer
>>> Properties dialog. So to reproduce the appearance of the version 0.10
>>> GUI, it would have text inside a box with slightly rounded corners, with
>>> a shadow to indicate it is clickable. The fill is a gray gradient - I
>>> don't know if this is reproducible in latex.
>>> \toolbtn - I was thinking of this one for the icons that appear in the
>>> toolbars. Per earlier e-mail, this should perhaps have 2 required
>>> arguments, the icon and the label (tooltip). The icon would have the
>>> shadow, since it is the clickable part, and the tooltip could have a
>>> yellow fill. For this to work, we need to have all the GUI icons present
>>> in the image folders. In a very quick check, I could not find, for
>>> example, the print icon, unless it appears under another name.
>>> \toolbox - This was intended for GRASS tools. In skimming through the
>>> toolbox, I see that many tools are indicated by multiple icons, such as
>>> the conversion tools. So perhaps this macro requires multiple versions
>>> to accommodate different numbers of icons. The whole line is clickable,
>>> so it would have a shadowbox around all the icons and label.
>>> \menuopt - There are two kinds of menu options - the first level has no
>>> icons (like File), the second level sometimes has icons  (like New
>>> Project). Do we need a second menuopt macro (menuopt2 ?) that also
>>> requires the icon? I am inclined to NOT include the shortcuts in the
>>> macro, even though they appear in the GUI. We can leave it to the
>>> writers choice whether to mention the shortcut, using the keystroke
>>> macros.
>>> On a more general note, I am thinking that the appearance we should try
>>> to reproduce is the non-hover version, because if a new user is scanning
>>> the GUI for something that looks like what they see in the manual, it
>>> would be misleading to show an appearance that would only match if they
>>> were hovering on the right item already.  So I am thinking for a menu
>>> option, such as File, we could have a shadowbox with gray fill and no
>>> outline.
>>> I haven't made any of these changes yet - please let me know what you
>>> think. Also, it would be helpful to know if the appearance will be
>>> dramatically different in the version 1.0 GUI (Tim?)
>>> Tara
>>> PS I haven't been able to figure out the syntax for \shadowsize - does
>>> anyone have experience with the fancybox package to know how this works?
>>> Qgis-community-team mailing list
>>> Qgis-community-team at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
>> No virus found in this incoming message.
>> Checked by AVG. Version: 8.0.100 / Virus Database: 270.0.0/1485 - Release
>> Date: 6/5/2008 10:07 AM
> My e-mail delivery has been unreliable lately, so I am asking for
> return receipts from all my email messages.
> OK'ing the return receipt lets me know that my message was delivered.
> Thank you.
> Tara Athan
> Principal, Alternatives to Invasive Species
> tara_athan [AT] alt2is.com
> 707-485-1198
> PO Box 415
> Redwood Valley, CA 95470
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
More information about the Qgis-community-team mailing list
