[Qgis-community-team] Re: svn merge
Tara Athan tara_athan at alt2is.com
Sat Jun 7 21:13:34 EDT 2008
Jurgen - thanks for the help - that worked out very well in Tortoise
SVN, especially with the diff tool. I will add this tip to the
DocumentationWriters or Manual Management wiki when that is editable
again. So to reiterate, the procedure should be:
When commiting to SVN:
If the repository file has been modified since your last checkout, the
commit will fail.
There is no danger of accidentally overwriting someone else's modification.
If this error occurs,
1. In Tortoise SVN, run svn update to merge any changes that have been
made since the last checkout into your local copy
2. manually resolve any conflicts that appear.
    > In Tortoise SVN, right click on the original copy of the file with
conflicts and select Edit Conflicts.
    > Right-click on each conflict, shown in red and select a method of
resolution
3. run svn commit
Tara
More information about the Qgis-community-team mailing list
