[Qgis-community-team] manual images
Tara Athan tara_athan at alt2is.com
Sat Jun 7 21:41:27 EDT 2008
There are some issues regarding images in the manual, and I would like
to ask for opinions on the best way to get these resolved.
1. The GUI is being revised, with the icon images for tool buttons and
options having different names, as well as new tools and options being
added.
Alternatives I can think of are:
  A. Maintain parallel folders- keep the old image folders and add new
image folders, called something like images_new. Add  commands to the
Makefile to process both the new images as well as the old ones. Allow
all manual editors to migrate to the new images at their convenience
(but before the Version 1.0 release). Eventually all references to old
images are removed, these image folders are deleted and the "new" suffix
is dropped from the remaining image folders.
  B. One-Shot Switch. After the GUI freeze ( June 15) remove the old
images, put in the new images, and ask everyone to help update the latex
source. Missing images will give error messages when compiling that can
be bypassed with Enter or quiet mode. The error messages could be
helpful in finding all occurrences of old image names, but would also be
annoying to anyone modifying the manual in other ways.
2. Up until now, images used in the GRASS toolbox have not been  used in
the manual. These images have names like nviz.1.eps. This naming
convention, or something like it, is required because some modules
require a set of images to represent them, indicating for example, the
starting format and the ending format of a conversion module. When
referring to these images in the latex source, it is necessary to
include the .eps extension, otherwise the \includegraphics macro looks
for nviz.1 and can't find it.
Alternatives:
  A. Try to remember to use the .eps extension in the latex source when
referring to these images, add a note to the wiki about it (prone to
errors?)
  B. Change the naming convention in the source to not include an extra
"." (perhaps a lot of trouble?)
  C. batch rename all the images when copying from the source to the manual
  D. rewrite the \includegraphics macro to accommodate this case
Please let me know what you think,
Tara
More information about the Qgis-community-team mailing list
