[Qgis-community-team] Re: backup of qgis.org
Stephan Reber stephan.reber at sr-gis.de
Wed Jun 11 06:26:18 EDT 2008
Hi Otto,
Otto Dassau schrieb:
> Hi Stephan,
> On Tue, 10 Jun 2008 14:22:43 +0200
> Stephan Reber <stephan.reber at sr-gis.de> wrote:
>> Hi Otto,
>> I have recieved the data of qgis.org from Tim (Thanks, everything worked
>> fine!). The old template is copied to Joomla. Now I want to install the
>> backup of the qgis.org. Can I get access to MySQL or can I send the file
>> to you for installing the backup? Then I can rearrange the content and
>> put a first menu to the website.
> looking at the web backup size this morning, it seems that the import of the
> "old" qgis.org database into mysql on went well on xblade14-2.
Yes, it went well. I was only worried to do something wrong. But with
additional help from my old mysql book and a look in the web, I was
confident to the right things. Only problem was, that the database
prefix was not the same. So I changed the global configuration in Joomla.
I tried add to this points to the documentation file- but I couldn't
write the file. Can I get permission to write this file? ...the same
question again;-).
regards,
Stephan
>> About the user map I must say, that I have not worked with OpenLayers
>> until now. This is a point where I will need some help. And I like the
>> idea of using data of OSM for the user map.
> There was a mail I forwarded to you from Paolo Cavallini about the usermap
> on Mon, 9 Jun 2008 18:11:20 and there are more ideas as well - I will add them
> to the wiki as soon as we have write access again. After you reviewed the
> content, etc. we start to find a solution for it.
>> I put the website offline with a comment, the QGIS logo and a link to
>> qgis.org. I think it is nicer than a fragment of the website. In the
>> next days I will have more time. So I think there will be progress of
>> the website.
> thanks a lot
>  Otto
>> Regards,
>> Stephan
More information about the Qgis-community-team mailing list
