[Qgis-community-team] macros, example dataset
Tara Athan tara_athan at alt2is.com
Wed May 7 11:22:58 EDT 2008
These macros from Gary are a good headstart. If we discover other
categories, we can use these as a template.
A question for you latex gurus - Is it possible to include icons, such
as the icons for GRASS modules, in a macro for an inline style, or would
these need to be specified manually? The idea would be if the writer
refers to a tool having an icon, this icon is automatically included.
Now let me bring up a more challenging issue- a dataset for examples.
I would like to see a complete dataset with data in many formats, all in
the same location.
All examples in the manual would then use the same dataset.
I have no preference to the location - we could build from the Alaska
dataset by adding files in different formats (GRASS, etc), or if someone
has a better idea, I am willing to consider it.
Tara
Gary Sherman wrote:
> On May 6, 2008, at 7:44 PM, Tara Athan wrote:
>> OK, I was able to download the latex version of the manual and take a
>> quick look through the various sections.
>> What I see is a lot of inconsistency in format between sections.
>> This is to be expected, I guess, if the sections are written by
>> different authors and there is no agreement beforehand as to format.
> The manual has evolved over time with a number of authors working at
> different times so just like any "code base" you'll find these types
> of things.
>> But I think we need to aim for greater consistency for the 1.0 manual
>> release.
>> For a start, I would like to have macros for inline styles to
>> distinguish command line inputs, file names, buttons and so on.
>> I see this done frequently in software manuals-  there is a different
>> style of type for each category, and these are clearly spelled out in
>> the introduction.
>> At present there is a wide variety of formats being used.  \textsl is
>> used for a lot of different things, so it is not obvious when you see
>> text formated as \textsl what it corresponds to. And the same type of
>> item, such as an input field selection, is sometimes \textsl,
>> sometimes in quotes, sometimes \textbf, ...
> Rather than choosing a specific markup such as \textsl for an item, I
> would suggest using new commands to provide a layer of abstraction.
> This way you can simply modify the command definition to change all
> occurences of, for example, a tool button.
> Here are the commands I used in the FOSS4G2007 QGIS workshop document:
> % my commands
> \newcommand{\button}[1]{\cornersize{0.1}\ovalbox{\textsf{\scriptsize#1}}}
> \newcommand{\classname}[1]{\textsf{\textbf{#1}}}
> \newcommand{\fieldname}[1]{\textsl{#1}}
> \renewcommand{\filename}[1]{\texttt{#1}}
> \newcommand{\keystroke}[1]{\fbox{\textsf{\scriptsize#1}}}
> \newcommand{\menuopt}[1]{\textsf{#1}}
> \newcommand{\method}[1]{\textsf{\textit{#1}}}
> \newcommand{\server}[1]{\textit{#1}}
> \newcommand{\sqltable}[1]{\textsf{\textbf{#1}}}
> \newcommand{\toolbtn}[1]{\cornersize{7mm}\Ovalbox{\textsf{\scriptsize#1}}}
> \newcommand{\usertext}[1]{\texttt{#1}}
> So you would markup a tool button like this: \toolbtn{Add Vector Layer}
> This in turn is converted according to the command definition,
> resulting in an oval outline of the text in sans-serif scriptsize font.
> Of course you can tweak the commands as the team sees fit. The obvious
> advantage is you can consistently apply the same markup to the same
> items and easily change the style at any time by editing the commands
> in the preamble of the document.
> -gary
> -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
> Gary Sherman
> Chair, QGIS Project Steering Committee
> -Micro Resources: http://mrcc.com
>   *Geospatial Hosting
>   *Web Site Hosting
> -Desktop GIS Book:
>   *http://desktopgisbook.com
> "We work virtually everywhere"
My e-mail delivery has been unreliable lately, so I am asking for
return receipts from all my email messages.
OK'ing the return receipt lets me know that my message was delivered.
Thank you.
Tara Athan
Principal, Alternatives to Invasive Species
tara_athan [AT] alt2is.com
707-485-1198
PO Box 415
Redwood Valley, CA 95470
More information about the Qgis-community-team mailing list
