[Qgis-community-team] help with manual revision
Jürgen E. Fischer jef at norbit.de
Tue May 27 04:22:42 EDT 2008
Hi Werner,
On Tue, 27. May 2008 at 10:04:34 +0200, Werner Macho wrote:
> but two times enter compiles the manual .. with 1 error..
> Maybe someone understand whats wrong here? I found out that in
> qgis_user.sty there are a lot of "empty lines" at the end - if you
> delete them there are much more errors like that.. And I think cleaning
> out this error means a fine compile also under MikTeX without the
> Makefile (having prepared the .eps files before)
If you comment out the hyperref line at the end of qgis_style.sty
the error disappears.
BTW if you use pdflatex instead of plain latex you can also uses the
PNGs and JPGs directly, without the need to create eps first - and I
think PDF is our main target anyway...
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the Qgis-community-team mailing list
