[Qgis-community-team] more latex questions
Tara Athan tara_athan at alt2is.com
Sun May 25 11:39:40 EDT 2008
After installing the complete MikTex package (12 hour download, >1GB
installed #$@&!!!) I managed to use TexMaker to compile the manual, sort of.
It shows 110 errors, mostly missing graphics, and a total of 295 errors,
warnings, badboxes, etc.
It is full of undefined citations.
I have attached the log file, if anyone with more experience with the
manual, latex, TexMaker, ... would like to look at it and advise me.
Thanks, Tara
This is pdfTeX, Version 3.1415926-1.40.8-alpha-20080323 (MiKTeX 2.7) (preloaded format=latex 2008.5.24)  24 MAY 2008 21:48
entering extended mode
**user_guide.tex
(user_guide.tex
LaTeX2e <2005/12/01>
Babel <v3.8j> and hyphenation patterns for english, dumylang, nohyphenation, ge
rman, ngerman, french, loaded.
("C:\Program Files\MiKTeX 2.7\tex\latex\koma-script\scrartcl.cls"
Document Class: scrartcl 2007/12/24 v2.98 KOMA-Script document class (article)
("C:\Program Files\MiKTeX 2.7\tex\latex\koma-script\scrkbase.sty"
Package: scrkbase 2007/12/24 v2.98 KOMA-Script package (basics and keyval use)
("C:\Program Files\MiKTeX 2.7\tex\latex\graphics\keyval.sty"
Package: keyval 1999/03/16 v1.13 key=value parser (DPC)
\KV at toks@=\toks14
("C:\Program Files\MiKTeX 2.7\tex\latex\koma-script\scrlfile.sty"
Package: scrlfile 2007/12/18 v2.98 KOMA-Script package (loading files)
Package scrlfile, 2007/12/18 v2.98 KOMA-Script package (loading files)
                  Copyright (C) Markus Kohm
Package scrkbase Info: You've used obsolete option `onecolumn'.
(scrkbase)             \KOMAExecuteOptions{twocolumn=false} will be
(scrkbase)             used instead.
(scrkbase)             You may simply replace `onecolumn'
(scrkbase)             by `twocolumn=false'.
Package scrkbase Info: You've used obsolete option `11pt'.
(scrkbase)             \KOMAExecuteOptions{fontsize=11pt} will be
(scrkbase)             You may simply replace `11pt'
(scrkbase)             by `fontsize=11pt'.
Class scrartcl Info: File `size11.clo' used to setup font sizes on input line 9
10.
 ("C:\Program Files\MiKTeX 2.7\tex\latex\base\size11.clo"
File: size11.clo 2005/09/16 v1.4f Standard LaTeX file (size option)
("C:\Program Files\MiKTeX 2.7\tex\latex\koma-script\typearea.sty"
Package: typearea 2007/12/24 v2.98 KOMA-Script package (type area)
Package typearea, 2007/12/24 v2.98 KOMA-Script package (type area)
                  Copyright (C) Frank Neukam, 1992-1994
                  Copyright (C) Markus Kohm, 1994-
\ta at bcor=\skip41
\ta at div=\count79
Package scrkbase Info: You've used obsolete option `a4paper'.
(scrkbase)             \KOMAExecuteOptions{paper=a4} will be
(scrkbase)             You may simply replace `a4paper'
(scrkbase)             by `paper=a4'.
Package scrkbase Warning: You've used obsolete option `dvips'.
(scrkbase)                \KOMAExecuteOptions{pagesize=dvips} will be
(scrkbase)                You may simply replace `dvips'
(scrkbase)                by `pagesize=dvips' on input line 451.
\ta at hblk=\skip42
\ta at vblk=\skip43
\ta at temp=\skip44
Package typearea Info: These are the values describing the layout:
(typearea)             DIV  = 10
(typearea)             BCOR = 0.0pt
(typearea)             \paperwidth      = 597.50793pt
(typearea)              \textwidth      = 418.25555pt
(typearea)              DIV-departure   = -6/100
(typearea)              \evensidemargin = 17.3562pt
(typearea)              \oddsidemargin  = 17.3562pt
(typearea)             \paperheight     = 845.04694pt
(typearea)              \textheight     = 595.80026pt
(typearea)              \topmargin      = -25.16531pt
(typearea)              \headheight     = 17.0pt
(typearea)              \headsep        = 20.40001pt
(typearea)              \topskip        = 11.0pt
(typearea)              \footskip       = 47.60002pt
(typearea)              \baselineskip   = 13.6pt
(typearea)              on input line 906.
\c at part=\count80
\c at section=\count81
\c at subsection=\count82
\c at subsubsection=\count83
\c at paragraph=\count84
\c at subparagraph=\count85
\abovecaptionskip=\skip45
\belowcaptionskip=\skip46
\c at pti@nb at sid@b at x=\box26
\c at figure=\count86
\c at table=\count87
\bibindent=\dimen102
) (qgis_style.sty ("C:\Program Files\MiKTeX 2.7\tex\latex\base\makeidx.sty"
Package: makeidx 2000/03/29 v1.0m Standard LaTeX package
\@indexfile=\write3
Writing index file user_guide.idx
("C:\Program Files\MiKTeX 2.7\tex\latex\float\float.sty"
Package: float 2001/11/08 v1.3d Float enhancements (AL)
\c at float@type=\count88
\float at exts=\toks15
\float at box=\box27
\@float at everytoks=\toks16
\@floatcapt=\box28
\@float at every@Tip=\toks17
\c at Tip=\count89
("C:\Program Files\MiKTeX 2.7\tex\latex\fancybox\fancybox.sty"
Package: fancybox 2000/09/19 1.3
Style option: `fancybox' v1.3 <2000/09/19> (tvz)
\@fancybox=\box29
\shadowsize=\dimen103
\@Sbox=\box30
\do at VerbBox=\toks18
\the at fancyput=\toks19
\this at fancyput=\toks20
\EndVerbatimTokens=\toks21
\Verbatim at Outfile=\write4
\Verbatim at Infile=\read1
) ("C:\Program Files\MiKTeX 2.7\tex\latex\base\inputenc.sty"
Package: inputenc 2006/05/05 v1.1b Input encoding file
\inpenc at prehook=\toks22
\inpenc at posthook=\toks23
("C:\Program Files\MiKTeX 2.7\tex\latex\base\latin1.def"
File: latin1.def 2006/05/05 v1.1b Input encoding file
("C:\Program Files\MiKTeX 2.7\tex\latex\base\fontenc.sty"
Package: fontenc 2005/09/27 v1.99g Standard LaTeX package
("C:\Program Files\MiKTeX 2.7\tex\latex\base\t1enc.def"
File: t1enc.def 2005/09/27 v1.99g Standard LaTeX file
LaTeX Font Info:    Redeclaring font encoding T1 on input line 43.
("C:\Program Files\MiKTeX 2.7\tex\latex\ae\ae.sty"
Package: ae 2001/02/12 1.3 Almost European Computer Modern
LaTeX Font Info:    Try loading font information for T1+aer on input line 100.
("C:\Program Files\MiKTeX 2.7\tex\latex\ae\t1aer.fd"
File: t1aer.fd 1997/11/16 Font definitions for T1/aer.
("C:\Program Files\MiKTeX 2.7\tex\latex\ae\aecompl.sty"
Package: aecompl 1998/07/23 0.9 T1 Complements for AE fonts (D. Roegel)
("C:\Program Files\MiKTeX 2.7\tex\latex\caption\caption2.sty"
Package: caption2 2007/08/12 v2.2b Customising captions (AS)
Package caption2 Warning: ****************************************************
(caption2)                THIS PACKAGE IS OBSOLETE:
(caption2)                This package attempts to provide an `caption2'
(caption2)                package v2.0/2.1 author environment so that OLD
(caption2)                documents can be successfully processed. It should
(caption2)                NOT be used for NEW documents! New documents should
(caption2)                use the regular `caption' package v3.x instead.
(caption2)                ****************************************************
("C:\Program Files\MiKTeX 2.7\tex\latex\caption\caption3.sty"
Package: caption3 2008/03/20 v3.1h caption3 kernel (AR)
\captionmargin=\dimen104
\captionmargin@=\dimen105
\captionwidth=\dimen106
\caption at indent=\dimen107
\caption at parindent=\dimen108
\caption at hangindent=\dimen109
Package caption2 Info: Running in caption2 v2.0 compatibility mode on input lin
e 209.
\captionlinewidth=\dimen110
\realcaptionwidth=\dimen111
Package caption2 Info: float package v1.2 (or newer) detected on input line 318
) (html.sty
Package: html 1999/07/19 v1.38 hypertext commands for latex2html (nd, hws, rrm)
\c at lpart=\count90
\c at lchapter=\count91
\c at chapter=\count92
\c at lsection=\count93
\c at lsubsection=\count94
\c at lsubsubsection=\count95
\c at lparagraph=\count96
\c at lsubparagraph=\count97
\c at lsubsubparagraph=\count98
\ptrfile=\write5
("C:\Program Files\MiKTeX 2.7\tex\latex\psnfss\helvet.sty"
Package: helvet 2005/04/12 PSNFSS-v9.2a (WaS)
("C:\Program Files\MiKTeX 2.7\tex\latex\graphics\graphicx.sty"
Package: graphicx 1999/02/16 v1.0f Enhanced LaTeX Graphics (DPC,SPQR)
("C:\Program Files\MiKTeX 2.7\tex\latex\graphics\graphics.sty"
Package: graphics 2006/02/20 v1.0o Standard LaTeX Graphics (DPC,SPQR)
("C:\Program Files\MiKTeX 2.7\tex\latex\graphics\trig.sty"
Package: trig 1999/03/16 v1.09 sin cos tan (DPC)
("C:\Program Files\MiKTeX 2.7\tex\latex\00miktex\graphics.cfg"
File: graphics.cfg 2007/01/18 v1.5 graphics configuration of teTeX/TeXLive
Package graphics Info: Driver file: dvipdf.def on input line 90.
("C:\Program Files\MiKTeX 2.7\tex\latex\graphics\dvipdf.def"
File: dvipdf.def 1999/02/16 v3.0i Driver-dependant file (DPC,SPQR)
\Gin at req@height=\dimen112
\Gin at req@width=\dimen113
("C:\Program Files\MiKTeX 2.7\tex\latex\graphics\color.sty"
Package: color 2005/11/14 v1.0j Standard LaTeX Color (DPC)
("C:\Program Files\MiKTeX 2.7\tex\latex\00miktex\color.cfg"
File: color.cfg 2007/01/18 v1.5 color configuration of teTeX/TeXLive
Package color Info: Driver file: dvips.def on input line 130.
("C:\Program Files\MiKTeX 2.7\tex\latex\graphics\dvips.def"
File: dvips.def 1999/02/16 v3.0i Driver-dependant file (DPC,SPQR)
("C:\Program Files\MiKTeX 2.7\tex\latex\graphics\dvipsnam.def"
File: dvipsnam.def 1999/02/16 v3.0i Driver-dependant file (DPC,SPQR)
("C:\Program Files\MiKTeX 2.7\tex\latex\natbib\natbib.sty"
Package: natbib 2007/10/30 8.1 (PWD)
\bibhang=\skip47
\bibsep=\skip48
LaTeX Info: Redefining \cite on input line 602.
\c at NAT@ctr=\count99
("C:\Program Files\MiKTeX 2.7\tex\latex\floatflt\floatflt.sty"
Package: floatflt 1997/07/16 v. 1.31
\c at OptionTest=\count100
\figbox=\box31
\tabbox=\box32
\pagebox=\box33
\ffigcount=\count101
\ftabcount=\count102
\fftest=\count103
\hangcount=\count104
\nosuccesstryfig=\count105
\nosuccesstrytab=\count106
\figgutter=\dimen114
\tabgutter=\dimen115
\htdone=\dimen116
\pageht=\dimen117
\startpageht=\dimen118
\tabbredd=\dimen119
\floatfltwidth=\dimen120
\fltitemwidth=\dimen121
\outputpretest=\toks24
("C:\Program Files\MiKTeX 2.7\tex\latex\hyphenat\hyphenat.sty"
Package: hyphenat 2001/01/02 v2.3a hyphenation utilities
\langwohyphens=\language6
LaTeX Info: Redefining \_ on input line 46.
("C:\Program Files\MiKTeX 2.7\tex\latex\fancyhdr\fancyhdr.sty"
\fancy at headwidth=\skip49
\f at ncyO@elh=\skip50
\f at ncyO@erh=\skip51
\f at ncyO@olh=\skip52
\f at ncyO@orh=\skip53
\f at ncyO@elf=\skip54
\f at ncyO@erf=\skip55
\f at ncyO@olf=\skip56
\f at ncyO@orf=\skip57
Package Fancyhdr Warning: \fancyhead's `E' option without twoside option is use
less on input line 99.
less on input line 100.
Package Fancyhdr Warning: \fancyfoot's `E' option without twoside option is use
less on input line 106.
less on input line 107.
("C:\Program Files\MiKTeX 2.7\tex\latex\supertabular\supertabular.sty"
Package: supertabular 2004/02/20 v4.1e the supertabular environment
\c at tracingst=\count107
\ST at wd=\dimen122
\ST at rightskip=\skip58
\ST at leftskip=\skip59
\ST at parfillskip=\skip60
\ST at pageleft=\dimen123
\ST at headht=\dimen124
\ST at tailht=\dimen125
\ST at pagesofar=\dimen126
\ST at pboxht=\dimen127
\ST at lineht=\dimen128
\ST at stretchht=\dimen129
\ST at prevht=\dimen130
\ST at toadd=\dimen131
\ST at dimen=\dimen132
\ST at pbox=\box34
("C:\Program Files\MiKTeX 2.7\tex\latex\tools\tabularx.sty"
Package: tabularx 1999/01/07 v2.07 `tabularx' package (DPC)
("C:\Program Files\MiKTeX 2.7\tex\latex\tools\array.sty"
Package: array 2005/08/23 v2.4b Tabular extension package (FMi)
\col at sep=\dimen133
\extrarowheight=\dimen134
\NC at list=\toks25
\extratabsurround=\skip61
\backup at length=\skip62
\TX at col@width=\dimen135
\TX at old@table=\dimen136
\TX at old@col=\dimen137
\TX at target=\dimen138
\TX at delta=\dimen139
\TX at cols=\count108
\TX at ftn=\toks26
("C:\Program Files\MiKTeX 2.7\tex\latex\rotating\rotating.sty"
Package: rotating 2008/05/16 v2.15 rotated objects in LaTeX
("C:\Program Files\MiKTeX 2.7\tex\latex\base\ifthen.sty"
Package: ifthen 2001/05/26 v1.1c Standard LaTeX ifthen package (DPC)
\c at r@tfl at t=\count109
\rotFPtop=\skip63
\rotFPbot=\skip64
\rot at float@box=\box35
\rot at mess@toks=\toks27
("C:\Program Files\MiKTeX 2.7\tex\latex\colortbl\colortbl.sty"
Package: colortbl 2001/02/13 v0.1j Color table columns (DPC)
\everycr=\toks28
\minrowclearance=\skip65
("C:\Program Files\MiKTeX 2.7\tex\latex\tools\hhline.sty"
Package: hhline 1994/05/23 v2.03 Table rule package (DPC)
("C:\Program Files\MiKTeX 2.7\tex\latex\footmisc\footmisc.sty"
Package: footmisc 2005/03/17 v5.3d a miscellany of footnote facilities
\FN at temptoken=\toks29
\footnotemargin=\dimen140
LaTeX Warning: Command \@makecol  has changed.
               Check if current package is valid.
\c at pp@next at reset=\count110
Package footmisc Info: Declaring symbol style bringhurst on input line 817.
Package footmisc Info: Declaring symbol style chicago on input line 818.
Package footmisc Info: Declaring symbol style wiley on input line 819.
Package footmisc Info: Declaring symbol style lamport-robust on input line 823.
Package footmisc Info: Declaring symbol style lamport* on input line 831.
Package footmisc Info: Declaring symbol style lamport*-robust on input line 840
) ("C:\Program Files\MiKTeX 2.7\tex\latex\subfigure\subfigure.sty"
Package: subfigure 2002/07/30 v2.1.4 subfigure package
\subfigtopskip=\skip66
\subfigcapskip=\skip67
\subfigcaptopadj=\dimen141
\subfigbottomskip=\skip68
\subfigcapmargin=\dimen142
\subfiglabelskip=\skip69
\c at subfigure=\count111
\c at lofdepth=\count112
\c at subtable=\count113
\c at lotdepth=\count114
* Local config file subfigure.cfg used *
("C:\Program Files\MiKTeX 2.7\tex\latex\subfigure\subfigure.cfg")
\subfig at top=\skip70
\subfig at bottom=\skip71
("C:\Program Files\MiKTeX 2.7\tex\latex\placeins\placeins.sty"
Package: placeins 2005/04/18  v 2.2
\@float at every@karte=\toks30
\c at karte=\count115
 (bibtopic.sty
Package: bibtopic 2000/10/17 v1.0j Sectioned Bibliographies
\c at btauxfile=\count116
\bt at infilea=\read2
\bt at infileb=\read3
\bt at outfile=\write6
\bt at tempboxa=\box36
("C:\Program Files\MiKTeX 2.7\tex\latex\tools\xspace.sty"
Package: xspace 2006/05/08 v1.12 Space after command names (DPC,MH)
! Undefined control sequence.
\@fileswith at pti@ns ...served at b \reserved at a ,\@nil
                                                  ,}\fi \reserved at a
l.211
The control sequence at the end of the top line
of your error message was never \def'ed. If you have
misspelled it (e.g., `\hobx'), type `I' and the correct
spelling (e.g., `I\hbox'). Otherwise just continue,
and I'll forget about whatever was undefined.
Runaway definition?
->\@onefilewithoptions hyperref[bookmarks=true, bookmarksnumbered=fal\ETC.
! File ended while scanning definition of \reserved at a.
<inserted text>
l.6
I suspect you have forgotten a `}', causing me
to read past where you wanted me to stop.
I'll try to recover; but if the error is serious,
you'd better type `E' or `X' now and fix your file.
(user_guide.aux (title.aux) (preamble.aux) (toc.aux) (forward.aux)
(introduction.aux) (getting_started.aux) (working_with_vector.aux)
(working_with_raster.aux) (working_with_ogc.aux) (working_with_projections.aux)
(grass_integration.aux) (mapserver_export.aux) (map_composer.aux) (plugins.aux)
(plugins_decorations.aux) (plugins_gps.aux) (plugins_delimited_text.aux)
(plugins_graticule_creator.aux) (plugins_georeferencer.aux) (plugins_python.aux
) (creating_applications.aux) (help_and_support.aux)
(appendices/supported_data_formats.aux) (install.aux) (appendices/gpl.aux)
(appendices/qgis_qt_gpl_exception.aux) (literature.aux) (index.aux))
LaTeX Font Info:    Checking defaults for OML/cmm/m/it on input line 8.
LaTeX Font Info:    ... okay on input line 8.
LaTeX Font Info:    Checking defaults for T1/cmr/m/n on input line 8.
LaTeX Font Info:    Checking defaults for OT1/cmr/m/n on input line 8.
LaTeX Font Info:    Checking defaults for OMS/cmsy/m/n on input line 8.
LaTeX Font Info:    Checking defaults for OMX/cmex/m/n on input line 8.
LaTeX Font Info:    Checking defaults for U/cmr/m/n on input line 8.
LaTeX Font Info:    Try loading font information for T1+phv on input line 8.
("C:\Program Files\MiKTeX 2.7\tex\latex\psnfss\t1phv.fd"
File: t1phv.fd 2001/06/04 scalable font definitions for T1/phv.
Package caption Info: Begin \AtBeginDocument code.
Package caption Info: End \AtBeginDocument code.
 (title.tex
! LaTeX Error: File `qgis_icon_new_verylarge' not found.
See the LaTeX manual or LaTeX Companion for explanation.
Type  H <return>  for immediate help.
l.7 ...p=true, scale=0.4]{qgis_icon_new_verylarge}
I could not locate the file with any of these extensions:
.eps,.ps,.eps.gz,.ps.gz,.eps.Z
Try typing  <return>  to proceed.
If that doesn't work, type  X <return>  to quit.
[1
]) (preamble.tex
LaTeX Font Info:    Font shape `T1/phv/bx/n' in size <10.95> not available
(Font)              Font shape `T1/phv/b/n' tried instead on input line 3.
LaTeX Font Info:    Font shape `T1/phv/bx/n' in size <14.4> not available
LaTeX Font Info:    External font `cmex10' loaded for size
(Font)              <10.95> on input line 20.
(Font)              <8> on input line 20.
(Font)              <6> on input line 20.
LaTeX Font Info:    Try loading font information for OMS+phv on input line 49.
 ("C:\Program Files\MiKTeX 2.7\tex\latex\psnfss\omsphv.fd"
File: omsphv.fd
LaTeX Font Warning: Font shape `OMS/phv/bx/n' undefined
(Font)              using `OMS/phv/m/n' instead on input line 49.
LaTeX Font Info:    Font shape `OMS/phv/m/n' in size <10.95> not available
(Font)              Font shape `OMS/cmsy/m/n' tried instead on input line 49.
LaTeX Font Info:    Font shape `OMS/phv/bx/n' in size <10.95> not available
) [2
] (toc.tex (user_guide.toc
Class scrartcl Info: You've told me to use the font selection of the element
(scrartcl)           `sectioning' that is an alias of element `disposition'
(scrartcl)            on input line 1.
(scrartcl)            on input line 2.
(scrartcl)            on input line 3.
(scrartcl)            on input line 4.
(scrartcl)            on input line 5.
(scrartcl)            on input line 6.
(scrartcl)            on input line 8.
(scrartcl)            on input line 12.
 [3
(scrartcl)            on input line 37.
(scrartcl)            on input line 62.
(scrartcl)            on input line 72.
 [4]
(scrartcl)            on input line 83.
(scrartcl)            on input line 88.
(scrartcl)            on input line 105.
(scrartcl)            on input line 109.
(scrartcl)            on input line 115.
 [5]
(scrartcl)            on input line 149.
Overfull \hbox (1.29184pt too wide) detected at line 152
 []\T1/phv/m/n/10.95 101
Overfull \hbox (1.29184pt too wide) detected at line 153
(scrartcl)            on input line 154.
Overfull \hbox (1.29184pt too wide) detected at line 155
 []\T1/phv/m/n/10.95 103
[6]
Overfull \hbox (1.29184pt too wide) detected at line 156
 []\T1/phv/m/n/10.95 104
Overfull \hbox (1.29184pt too wide) detected at line 157
Overfull \hbox (1.29184pt too wide) detected at line 158
 []\T1/phv/m/n/10.95 105
Overfull \hbox (1.29184pt too wide) detected at line 159
(scrartcl)            on input line 160.
Overfull \hbox (1.29184pt too wide) detected at line 161
 []\T1/phv/m/n/10.95 106
Overfull \hbox (1.29184pt too wide) detected at line 162
 []\T1/phv/m/n/10.95 107
(scrartcl)            on input line 163.
Overfull \hbox (1.29184pt too wide) detected at line 164
 []\T1/phv/m/n/10.95 109
Overfull \hbox (1.29184pt too wide) detected at line 165
(scrartcl)            on input line 166.
Overfull \hbox (1.29184pt too wide) detected at line 167
 []\T1/phv/m/n/10.95 110
Overfull \hbox (1.29184pt too wide) detected at line 168
Overfull \hbox (1.29184pt too wide) detected at line 169
 []\T1/phv/m/n/10.95 111
Overfull \hbox (1.29184pt too wide) detected at line 170
Overfull \hbox (1.29184pt too wide) detected at line 171
Overfull \hbox (1.29184pt too wide) detected at line 172
Overfull \hbox (1.29184pt too wide) detected at line 173
 []\T1/phv/m/n/10.95 112
Overfull \hbox (1.29184pt too wide) detected at line 174
Overfull \hbox (1.29184pt too wide) detected at line 175
Overfull \hbox (1.29184pt too wide) detected at line 176
Overfull \hbox (1.29184pt too wide) detected at line 177
Overfull \hbox (1.29184pt too wide) detected at line 178
Overfull \hbox (1.29184pt too wide) detected at line 179
 []\T1/phv/m/n/10.95 113
Overfull \hbox (1.29184pt too wide) detected at line 180
Overfull \hbox (0.65663pt too wide) detected at line 181
\T1/phv/m/n/10.95 C.10.
Overfull \hbox (1.29184pt too wide) detected at line 181
 []\T1/phv/m/n/10.95 114
Overfull \hbox (0.65663pt too wide) detected at line 182
\T1/phv/m/n/10.95 C.11.
Overfull \hbox (1.29184pt too wide) detected at line 182
Overfull \hbox (0.65663pt too wide) detected at line 183
\T1/phv/m/n/10.95 C.12.
Overfull \hbox (1.29184pt too wide) detected at line 183
(scrartcl)            on input line 184.
Overfull \hbox (1.29184pt too wide) detected at line 185
 []\T1/phv/m/n/10.95 115
Overfull \hbox (1.29184pt too wide) detected at line 186
Overfull \hbox (1.29184pt too wide) detected at line 187
Overfull \hbox (1.29184pt too wide) detected at line 188
 []\T1/phv/m/n/10.95 116
Overfull \hbox (1.29184pt too wide) detected at line 189
Overfull \hbox (1.29184pt too wide) detected at line 190
Overfull \hbox (1.29184pt too wide) detected at line 191
 []\T1/phv/m/n/10.95 117
Overfull \hbox (1.29184pt too wide) detected at line 192
 []\T1/phv/m/n/10.95 118
Overfull \hbox (1.29184pt too wide) detected at line 193
Overfull \hbox (1.29184pt too wide) detected at line 194
[7]
Overfull \hbox (1.29184pt too wide) detected at line 195
 []\T1/phv/m/n/10.95 119
Overfull \hbox (1.29184pt too wide) detected at line 196
 []\T1/phv/m/n/10.95 120
Overfull \hbox (1.29184pt too wide) detected at line 197
Overfull \hbox (1.29184pt too wide) detected at line 198
 []\T1/phv/m/n/10.95 121
(scrartcl)            on input line 199.
Overfull \hbox (1.29184pt too wide) detected at line 200
Overfull \hbox (1.29184pt too wide) detected at line 201
Overfull \hbox (1.29184pt too wide) detected at line 202
 []\T1/phv/m/n/10.95 122
Overfull \hbox (1.29184pt too wide) detected at line 203
Overfull \hbox (1.29184pt too wide) detected at line 204
 []\T1/phv/m/n/10.95 123
Overfull \hbox (1.29184pt too wide) detected at line 205
Overfull \hbox (1.29184pt too wide) detected at line 206
Overfull \hbox (1.29184pt too wide) detected at line 207
 []\T1/phv/m/n/10.95 124
Overfull \hbox (1.29184pt too wide) detected at line 208
Overfull \hbox (1.29184pt too wide) detected at line 209
 []\T1/phv/m/n/10.95 125
(scrartcl)            on input line 210.
Overfull \hbox (1.29184pt too wide) detected at line 211
Overfull \hbox (1.29184pt too wide) detected at line 212
Overfull \hbox (1.29184pt too wide) detected at line 213
 []\T1/phv/m/n/10.95 126
Overfull \hbox (1.29184pt too wide) detected at line 214
Overfull \hbox (1.29184pt too wide) detected at line 215
Overfull \hbox (1.29184pt too wide) detected at line 216
Overfull \hbox (1.29184pt too wide) detected at line 217
 []\T1/phv/m/n/10.95 127
Overfull \hbox (1.29184pt too wide) detected at line 218
 []\T1/phv/m/n/10.95 129
Overfull \hbox (1.29184pt too wide) detected at line 219
Overfull \hbox (1.29184pt too wide) detected at line 220
 []\T1/phv/m/n/10.95 130
Overfull \hbox (1.29184pt too wide) detected at line 221
 []\T1/phv/m/n/10.95 131
Overfull \hbox (1.29184pt too wide) detected at line 222
Overfull \hbox (1.29184pt too wide) detected at line 223
Overfull \hbox (1.29184pt too wide) detected at line 224
 []\T1/phv/m/n/10.95 132
Overfull \hbox (1.29184pt too wide) detected at line 225
(scrartcl)            on input line 226.
Overfull \hbox (1.29184pt too wide) detected at line 227
Overfull \hbox (1.29184pt too wide) detected at line 228
Overfull \hbox (1.29184pt too wide) detected at line 229
 []\T1/phv/m/n/10.95 133
Overfull \hbox (1.29184pt too wide) detected at line 230
Overfull \hbox (1.29184pt too wide) detected at line 231
Overfull \hbox (1.29184pt too wide) detected at line 232
Overfull \hbox (1.29184pt too wide) detected at line 233
 []\T1/phv/m/n/10.95 134
Overfull \hbox (1.29184pt too wide) detected at line 234
[8]
Overfull \hbox (1.29184pt too wide) detected at line 235
 []\T1/phv/m/n/10.95 135
Overfull \hbox (1.29184pt too wide) detected at line 236
Overfull \hbox (1.29184pt too wide) detected at line 237
 []\T1/phv/m/n/10.95 136
Overfull \hbox (1.29184pt too wide) detected at line 238
Overfull \hbox (1.29184pt too wide) detected at line 239
 []\T1/phv/m/n/10.95 137
Overfull \hbox (0.87537pt too wide) detected at line 240
\T1/phv/m/n/10.95 G.2.10.
Overfull \hbox (1.29184pt too wide) detected at line 240
Overfull \hbox (1.29184pt too wide) detected at line 241
(scrartcl)            on input line 242.
Overfull \hbox (1.29184pt too wide) detected at line 243
 []\T1/phv/m/n/10.95 138
Overfull \hbox (1.29184pt too wide) detected at line 244
Overfull \hbox (1.29184pt too wide) detected at line 245
 []\T1/phv/m/n/10.95 139
Overfull \hbox (1.29184pt too wide) detected at line 246
Overfull \hbox (1.29184pt too wide) detected at line 247
 []\T1/phv/m/n/10.95 142
Overfull \hbox (1.29184pt too wide) detected at line 248
 []\T1/phv/m/n/10.95 144
Overfull \hbox (1.29184pt too wide) detected at line 249
 []\T1/phv/m/n/10.95 147
Overfull \hbox (1.29184pt too wide) detected at line 250
Overfull \hbox (1.29184pt too wide) detected at line 251
Overfull \hbox (0.98506pt too wide) detected at line 252
\T1/phv/m/n/10.95 H.10.
Overfull \hbox (1.29184pt too wide) detected at line 252
 []\T1/phv/m/n/10.95 148
Overfull \hbox (0.98506pt too wide) detected at line 253
\T1/phv/m/n/10.95 H.11.
Overfull \hbox (1.29184pt too wide) detected at line 253
 []\T1/phv/m/n/10.95 149
(scrartcl)            on input line 254.
Overfull \hbox (1.29184pt too wide) detected at line 255
 []\T1/phv/m/n/10.95 155
(scrartcl)            on input line 256.
\tf at toc=\write7
 [9] (user_guide.lof
LaTeX Font Info:    Font shape `T1/phv/m/it' in size <10.95> not available
(Font)              Font shape `T1/phv/m/sl' tried instead on input line 31.
 [10]
Overfull \hbox (1.29184pt too wide) detected at line 47
 []\T1/phv/m/n/10.95 102
Overfull \hbox (1.29184pt too wide) detected at line 48
\tf at lof=\write8
 [11] (user_guide.lot)
\tf at lot=\write9
 [12]) (forward.tex
LaTeX Font Info:    Font shape `T1/phv/bx/n' in size <12> not available
(Font)              Font shape `T1/phv/b/n' tried instead on input line 37.
(Font)              <9> on input line 51.
(Font)              <5> on input line 51.
 [1
] [2]
Underfull \hbox (badness 10000) in paragraph at lines 121--132
Underfull \hbox (badness 10000) in paragraph at lines 132--136
) [3] (introduction.tex
Package natbib Warning: Citation `mitchel05' on page 4 undefined on input line
5.
LaTeX Font Info:    Font shape `T1/phv/m/it' in size <9> not available
(Font)              Font shape `T1/phv/m/sl' tried instead on input line 8.
[4
] [5]) [6] (getting_started.tex
LaTeX Font Info:    Try loading font information for T1+aett on input line 25.
("C:\Program Files\MiKTeX 2.7\tex\latex\ae\t1aett.fd"
File: t1aett.fd 1997/11/16 Font definitions for T1/aett.
) [7
] [8]
LaTeX Font Warning: Font shape `T1/aett/bx/n' undefined
(Font)              using `T1/aett/m/n' instead on input line 114.
Underfull \hbox (badness 1478) in paragraph at lines 123--128
\T1/phv/m/n/10.95 Based on your lo-cale QGIS, se-lects the cor-rect lo-cal-iza-
tion. If you like to change your
Underfull \hbox (badness 1701) in paragraph at lines 123--128
\T1/phv/m/n/10.95 lan-guage, you can pro-vide an-other lan-guage code. E.g.: --
-lang=it starts QGIS in ital-
LaTeX Font Info:    Font shape `T1/phv/bx/n' in size <10> not available
(Font)              Font shape `T1/phv/b/n' tried instead on input line 151.
! LaTeX Error: File `startup09' not found.
l.152 ...raphics[clip=true, width=17cm]{startup09}
[9] [10] [11] [12] [13] [14] [15]
! LaTeX Error: File `measureline' not found.
l.493 \includegraphics[width=0.7cm]{measureline}
                                                 QGIS is also able to measur...
[16]
! LaTeX Error: File `measurearea' not found.
l.500 \includegraphics[width=0.7cm]{measurearea}
                                                 Also areas can be measured....
! LaTeX Error: File `measure_line' not found.
l.507 ...true, width=0.4\textwidth]{measure_line}}
                                                  \goodgap
Overfull \hbox (10.99786pt too wide) in paragraph at lines 507--507
[]\T1/phv/m/n/9 (a)
Overfull \hbox (20.5018pt too wide) in paragraph at lines 507--507
\T1/phv/m/n/9 Mea-
Overfull \hbox (17.50484pt too wide) in paragraph at lines 507--507
\T1/phv/m/n/9 sure
Overfull \hbox (18.50381pt too wide) in paragraph at lines 507--507
\T1/phv/m/n/9 lines
! LaTeX Error: File `measure_area' not found.
l.508 ...true, width=0.4\textwidth]{measure_area}}
Overfull \hbox (10.99786pt too wide) in paragraph at lines 508--508
[]\T1/phv/m/n/9 (b)
Overfull \hbox (20.5018pt too wide) in paragraph at lines 508--508
\T1/phv/m/n/9 Mea-
Overfull \hbox (17.50484pt too wide) in paragraph at lines 508--508
\T1/phv/m/n/9 sure
\T1/phv/m/n/9 ar-
Overfull \hbox (14.50787pt too wide) in paragraph at lines 508--508
\T1/phv/m/n/9 eas
[17]
! LaTeX Error: File `options' not found.
l.540 ...egraphics[width=0.7cm,clip=true]{options}
                                                   Some basic options for QGIS
[18] [19]) [20] (working_with_vector.tex
Underfull \hbox (badness 1867) in paragraph at lines 55--58
\T1/phv/m/n/10.95 we rec-om-mend the tech-ni-cal spec-i-fi-ca-tion for the shap
e-file for-mat, that can be found at
! LaTeX Error: File `addshapefile' not found.
l.60 {\includegraphics[width=0.7cm]{addshapefile}
                                                 } To load a shapefile, start
! LaTeX Error: File `shapefileopendialog' not found.
l.75 ...lip=true, width=14cm]{shapefileopendialog}
[21
! LaTeX Error: File `shapefileloaded09' not found.
l.85 ...[clip=true, width=17cm]{shapefileloaded09}
[22]
! LaTeX Error: File `addpostgis' not found.
l.166 \includegraphics[width=0.7cm]{addpostgis}
                                                The first time
LaTeX Warning: `h' float specifier changed to `ht'.
[23]
l.214 \includegraphics[width=0.7cm]{addpostgis}
                                                Once you have one or more
[24]
! LaTeX Error: File `spiticon' not found.
l.294 \includegraphics[width=0.7cm]{spiticon}
                                              QGIS comes with a
[25] [26]
Package natbib Warning: Citation `PostGISweb' on page 27 undefined on input lin
e 359.
[27]
! LaTeX Error: File `vectorLayerSymbology09' not found.
l.422 ...true, width=12cm]{vectorLayerSymbology09}
[28] [29] [30] [31]
! LaTeX Error: File `identify_action' not found.
l.642 ...cs[clip=true, width=8cm]{identify_action}
Underfull \hbox (badness 10000) in paragraph at lines 646--651
[]\T1/phv/m/n/10.95 When we click on the ac-tion, it brings up Fire-fox and nav
-i-gates to the URL
[32]
! LaTeX Error: File `StartEditing' not found.
l.715 ...ics[width=0.4cm, clip=true]{StartEditing}
LaTeX Font Info:    Font shape `T1/phv/m/it' in size <10> not available
(Font)              Font shape `T1/phv/m/sl' tried instead on input line 722.
[33]
[34]
! LaTeX Error: File `digitising_attributes09' not found.
l.799 ...rue, width=16cm]{digitising_attributes09}
[35] [36] [37]
! LaTeX Error: File `newvectorlayer' not found.
l.1027 ...cs[clip=true, width=7cm]{newvectorlayer}
[38]
! LaTeX Error: File `querybuilder' not found.
l.1062 ...ics[clip=true, width=14cm]{querybuilder}
[39]) [40] (working_with_raster.tex
! LaTeX Error: File `addraster' not found.
l.47 \includegraphics[width=0.7cm]{addraster}
                                              Raster layers
[41
! LaTeX Error: File `rastercontextmenu' not found.
l.64 ...s[clip=true, width=5cm]{rastercontextmenu}
! LaTeX Error: File `raster_properties' not found.
l.91 ...[clip=true, width=14cm]{raster_properties}
[42] [43] [44]) [45] (working_with_ogc.tex
! LaTeX Error: File `wmssupport' not found.
l.38 \includegraphics[width=0.7cm]{wmssupport}
[46
[47]
! LaTeX Error: File `connection_wms' not found.
l.143 ...true,width=0.6\textwidth]{connection_wms}
[48]
[49]
Package natbib Warning: Citation `OGCWMS010101web' on page 50 undefined on inpu
t line 271.
Package natbib Warning: Citation `OGCWMS010300web' on page 50 undefined on inpu
t line 271.
[50] [51]
! LaTeX Error: File `wfs_dmsolutions' not found.
l.406 ...p=true,width=\textwidth]{wfs_dmsolutions}
[52]) [53] (working_with_projections.tex
! LaTeX Error: File `projectiondialog08' not found.
l.73 ...clip=true, width=14cm]{projectiondialog08}
[54
! LaTeX Error: File `customprojection' not found.
l.124 ...[clip=true, width=14cm]{customprojection}
[55]) [56] (grass_integration.tex
Package natbib Warning: Citation `GRASSweb' on page 57 undefined on input line
3.
! LaTeX Error: File `add_grass_vector' not found.
l.12 ...udegraphics[width=0.7cm]{add_grass_vector}
                                                   Add GRASS vector layers
! LaTeX Error: File `add_grass_raster' not found.
l.13 ...udegraphics[width=0.7cm]{add_grass_raster}
                                                   Add GRASS raster layers
! LaTeX Error: File `grass_tools' not found.
l.14 ...\includegraphics[width=0.7cm]{grass_tools}
                                                   GRASS Toolbox
! LaTeX Error: File `grass_region_edit' not found.
l.15 ...degraphics[width=0.7cm]{grass_region_edit}
                                                   Changing the GRASS region
! LaTeX Error: File `grass_edit' not found.
l.16 ... \includegraphics[width=0.7cm]{grass_edit}
                                                   Vector layers digitizing
! LaTeX Error: File `grass_open_mapset' not found.
l.17 ...degraphics[width=0.7cm]{grass_open_mapset}
                                                   Open existing mapset
! LaTeX Error: File `grass_new_mapset' not found.
l.18 ...udegraphics[width=0.7cm]{grass_new_mapset}
                                                   Create new GRASS mapset
! LaTeX Error: File `grass_new_vector_layer' not found.
l.19 ...phics[width=0.7cm]{grass_new_vector_layer}
                                                   Create new GRASS
! LaTeX Error: File `grass_close_mapset' not found.
l.21 ...egraphics[width=0.7cm]{grass_close_mapset}
                                                   Close GRASS mapset
[57
! LaTeX Error: File `grass_location' not found.
l.80 ...hics[clip=true, width=8cm]{grass_location}
[58] [59]
l.176 \includegraphics[width=0.7cm]{grass_edit}
                                                The digitizing tools for GRA...
! LaTeX Error: File `grassedit' not found.
l.188 ...raphics[clip=true, width=13cm]{grassedit}
! LaTeX Error: File `grass_new_point' not found.
l.205 ...udegraphics[width=0.7cm]{grass_new_point}
                                                   & New Point & digitize ne...
! LaTeX Error: File `grass_new_line' not found.
l.206 ...ludegraphics[width=0.7cm]{grass_new_line}
                                                   & New Line &  digitize ne...
! LaTeX Error: File `grass_new_boundary' not found.
l.207 ...graphics[width=0.7cm]{grass_new_boundary}
                                                   & New Boundary & digitize...
! LaTeX Error: File `grass_new_centroid' not found.
l.208 ...graphics[width=0.7cm]{grass_new_centroid}
                                                   & New Centroid & digitize...
! LaTeX Error: File `grass_move_vertex' not found.
l.209 ...egraphics[width=0.7cm]{grass_move_vertex}
                                                   & Move vertex & select on...
! LaTeX Error: File `grass_add_vertex' not found.
l.211 ...degraphics[width=0.7cm]{grass_add_vertex}
                                                   & Add vertex & add a new ...
! LaTeX Error: File `grass_delete_vertex' not found.
l.212 ...raphics[width=0.7cm]{grass_delete_vertex}
                                                   & Delete vertex & delete ...
! LaTeX Error: File `grass_move_line' not found.
l.214 ...udegraphics[width=0.7cm]{grass_move_line}
                                                   & Move line & select exis...
! LaTeX Error: File `grass_split_line' not found.
l.215 ...degraphics[width=0.7cm]{grass_split_line}
                                                   & Split line & split an e...
! LaTeX Error: File `grass_delete_line' not found.
l.216 ...egraphics[width=0.7cm]{grass_delete_line}
                                                   & Delete line & delete ex...
! LaTeX Error: File `grass_edit_attributes' not found.
l.218 ...phics[width=0.7cm]{grass_edit_attributes}
                                                   & Edit attributes & edit ...
! LaTeX Error: File `grass_close_edit' not found.
l.220 ...degraphics[width=0.7cm]{grass_close_edit}
                                                   & Exit & close digitizing...
Overfull \hbox (9.68483pt too wide) in paragraph at lines 203--223
[60] [61]
l.276 ...egraphics[width=0.7cm]{grass_region_edit}
                                                   The current region (windo...
l.301 \includegraphics[width=0.7cm]{grass_tools}
                                                 The GRASS toolbox provides
[62] [63]
! LaTeX Error: File `grass_add_map' not found.
l.378 ...cludegraphics[width=0.7cm]{grass_add_map}
                                                   Add selected map to canvas
! LaTeX Error: File `grass_copy_map' not found.
l.379 ...ludegraphics[width=0.7cm]{grass_copy_map}
                                                   Copy selected map
! LaTeX Error: File `grass_rename_map' not found.
l.380 ...degraphics[width=0.7cm]{grass_rename_map}
                                                   Rename selected map
! LaTeX Error: File `grass_delete_map' not found.
l.381 ...degraphics[width=0.7cm]{grass_delete_map}
                                                   Delete selected map
! LaTeX Error: File `grass_set_region' not found.
l.382 ...degraphics[width=0.7cm]{grass_set_region}
                                                   Set current region to sel...
! LaTeX Error: File `grass_refresh' not found.
l.383 ...cludegraphics[width=0.7cm]{grass_refresh}
                                                   Refresh browser window
! LaTeX Error: File `grassbrowser' not found.
l.393 ...true, width=0.4\textwidth]{grassbrowser}}
                                                  \goodgap
Overfull \hbox (10.99786pt too wide) in paragraph at lines 393--393
[]\T1/phv/m/n/9 (a)
Overfull \hbox (31.50867pt too wide) in paragraph at lines 393--393
\T1/phv/m/n/9 GRASS
Overfull \hbox (31.86879pt too wide) in paragraph at lines 393--393
\T1/phv/m/n/9 browser
Overfull \hbox (9.99887pt too wide) in paragraph at lines 393--393
\T1/phv/m/n/9 in-
Overfull \hbox (16.50584pt too wide) in paragraph at lines 393--393
\T1/phv/m/n/9 side
Overfull \hbox (12.50978pt too wide) in paragraph at lines 393--393
\T1/phv/m/n/9 the
Overfull \hbox (17.50471pt too wide) in paragraph at lines 393--393
\T1/phv/m/n/9 tool-
Overfull \hbox (14.23793pt too wide) in paragraph at lines 393--393
\T1/phv/m/n/9 box
! LaTeX Error: File `grassshell' not found.
l.394 ...p=true, width=0.4\textwidth]{grassshell}}
Overfull \hbox (10.99786pt too wide) in paragraph at lines 394--394
[]\T1/phv/m/n/9 (b)
Overfull \hbox (31.50867pt too wide) in paragraph at lines 394--394
\T1/phv/m/n/9 GRASS
Overfull \hbox (18.50381pt too wide) in paragraph at lines 394--394
\T1/phv/m/n/9 shell
Overfull \hbox (9.99887pt too wide) in paragraph at lines 394--394
\T1/phv/m/n/9 in-
Overfull \hbox (16.50584pt too wide) in paragraph at lines 394--394
\T1/phv/m/n/9 side
Overfull \hbox (12.50978pt too wide) in paragraph at lines 394--394
\T1/phv/m/n/9 the
Overfull \hbox (17.50471pt too wide) in paragraph at lines 394--394
\T1/phv/m/n/9 tool-
Overfull \hbox (14.23793pt too wide) in paragraph at lines 394--394
\T1/phv/m/n/9 box
[64]
! LaTeX Error: File `vbuffer' not found.
l.422 ...clip=true, width=0.45\textwidth]{vbuffer}
[65]) [66] (mapserver_export.tex [67
] [68]
! LaTeX Error: File `mapserver_export' not found.
l.99 ...ue, width=0.8\textwidth]{mapserver_export}
) [69] (map_composer.tex
! LaTeX Error: File `map_composer_blank09' not found.
l.23 ...ip=true, width=14cm]{map_composer_blank09}
! LaTeX Error: File `composer_add_image' not found.
l.45 ...egraphics[width=0.7cm]{composer_add_image}
                                                   To add
[70
! LaTeX Error: File `composer_open_template' not found.
l.68 ...phics[width=0.7cm]{composer_open_template}
                                                   Already existing QGIS tem...
l.73 ...egraphics[width=0.7cm]{composer_add_image}
                                                   To add a logo, north arro...
! LaTeX Error: File `composer_add_legend08' not found.
l.77 ...aphics[width=0.7cm]{composer_add_legend08}
                                                   A
! LaTeX Error: File `composer_add_scalebar08' not found.
l.84 ...hics[width=0.7cm]{composer_add_scalebar08}
                                                   To
! LaTeX Error: File `composer_add_label' not found.
l.89 ...egraphics[width=0.7cm]{composer_add_label}
                                                   You can
! LaTeX Error: File `map_composer09' not found.
l.99 ...ics[clip=true, width=14cm]{map_composer09}
! LaTeX Error: File `composer_save_template' not found.
l.118 ...hics[width=0.7cm]{composer_save_template}
                                                   To save the composer canvas
[71]
! LaTeX Error: File `composer_export_image' not found.
l.122 ...phics[width=0.7cm]{composer_export_image}
                                                   It is possible to export ...
! LaTeX Error: File `composer_export_svg' not found.
l.125 ...raphics[width=0.7cm]{composer_export_svg}
                                                   To export the composer ca...
) [72] (plugins.tex
! LaTeX Error: File `pluginmanager2' not found.
l.43 ...ics[clip=true, width=14cm]{pluginmanager2}
[73
(Font)              <7> on input line 91.
! LaTeX Error: File `copyright' not found.
l.94 \includegraphics[width=0.7cm]{copyright}
                                              & Copyright Label \index{plugi...
! LaTeX Error: File `delim_text' not found.
l.96 \includegraphics[width=0.7cm]{delim_text}
                                               & Delimited Text \index{plugi...
! LaTeX Error: File `gps' not found.
l.98 \includegraphics[width=0.7cm]{gps}
                                        & GPS Tools \index{plugins!gps}& Loa...
! LaTeX Error: File `gridmaker' not found.
l.100 \includegraphics[width=0.7cm]{gridmaker}
                                               & Graticule Creator \index{pl...
! LaTeX Error: File `scalebar' not found.
l.102 \includegraphics[width=0.7cm]{scalebar}
                                              & Scalebar \index{plugins!scal...
! LaTeX Error: File `northarrow' not found.
l.104 \includegraphics[width=0.7cm]{northarrow}
                                               & North Arrow \index{plugins!...
! LaTeX Error: File `buffer' not found.
l.106 \includegraphics[width=0.7cm]{buffer}
                                            & PostgreSQL Geoprocessing \inde...
l.108 \includegraphics[width=0.7cm]{spiticon}
                                              & SPIT \index{plugins!SPIT}& S...
! LaTeX Error: File `georeferencer' not found.
l.110 \includegraphics[width=0.7cm]{georeferencer}
                                                   & Georeferencer\footnote{...
LaTeX Font Info:    Font shape `T1/phv/m/it' in size <7> not available
(Font)              Font shape `T1/phv/m/sl' tried instead on input line 110.
LaTeX Font Info:    Font shape `T1/phv/m/it' in size <6> not available
LaTeX Font Info:    Font shape `T1/phv/bx/n' in size <9> not available
(Font)              Font shape `T1/phv/b/n' tried instead on input line 110.
LaTeX Warning: Reference `sec:install_gsl' on page 74 undefined on input line 1
10.
! LaTeX Error: File `wfs-icon' not found.
l.112 \includegraphics[width=0.7cm]{wfs-icon}
                                              & WFS & Load and display WFS l...
[74]) [75] (plugins_decorations.tex
l.18 ...egraphics[clip=true, width=8cm]{copyright}
! LaTeX Error: File `north_arrow' not found.
l.52 ...raphics[clip=true, width=8cm]{north_arrow}
[76
! LaTeX Error: File `scale_bar' not found.
l.83 ...egraphics[clip=true, width=8cm]{scale_bar}
) [77] (plugins_gps.tex
! LaTeX Error: File `icon' not found.
l.24 \includegraphics[width=0.7cm]{icon}
                                         To load a GPX file you need to use the
! LaTeX Error: File `loadgpx' not found.
l.34 ...degraphics[clip=true, width=12cm]{loadgpx}
Underfull \hbox (badness 1325) in paragraph at lines 45--54
\T1/phv/m/n/10.95 Since QGIS uses GPX files you need a way to con-vert other GP
S file for-mats to GPX.
[78
! LaTeX Error: File `importdialog' not found.
l.74 ...phics[clip=true, width=12cm]{importdialog}
! LaTeX Error: File `download' not found.
l.90 ...egraphics[clip=true, width=12cm]{download}
[79]) [80] (plugins_delimited_text.tex [81
! LaTeX Error: File `toolbar_icon' not found.
l.62 \includegraphics[width=0.7cm]{toolbar_icon}
! LaTeX Error: File `dialog' not found.
l.70 ...ludegraphics[clip=true, width=8cm]{dialog}
! LaTeX Error: File `file_selected' not found.
l.83 ...phics[clip=true, width=8cm]{file_selected}
! LaTeX Error: File `file_selected2' not found.
l.95 ...hics[clip=true, width=8cm]{file_selected2}
! LaTeX Error: File `file_selected3' not found.
l.109 ...ics[clip=true, width=8cm]{file_selected3}
) [82] [83] (plugins_graticule_creator.tex
! LaTeX Error: File `graticule' not found.
l.11   \includegraphics[scale=0.5]{graticule}
) [84
] (plugins_georeferencer.tex
! LaTeX Error: File `select_image' not found.
l.27   \includegraphics[clip=true]{select_image}
l.37 ...clip=true,width=\textwidth]{georeferencer}
! LaTeX Error: File `choose_points' not found.
l.57 ...p=true,width=0.8\textwidth]{choose_points}
[85
! LaTeX Error: File `result_map' not found.
l.108 ...lip=true,width=0.8\textwidth]{result_map}
) [86] (plugins_python.tex
Package natbib Warning: Citation `sherman07' on page 87 undefined on input line
 5.
[87
] [88] [89] [90]
! LaTeX Error: File `gettablename' not found.
l.245   \includegraphics[scale=0.8]{gettablename}
[91]
! LaTeX Error: File `getfieldname' not found.
l.261   \includegraphics[scale=0.8]{getfieldname}
! LaTeX Error: File `getdsn' not found.
l.293   \includegraphics[scale=0.8]{getdsn}
[92]
! LaTeX Error: File `plugin_results' not found.
l.360 ...ncludegraphics[scale=0.8]{plugin_results}
[93]) [94] (creating_applications.tex [95
] [96] [97]
Overfull \hbox (15.48982pt too wide) in paragraph at lines 159--159
[]\T1/aett/bx/n/10.95 60     self.actionZoomFull = QAction(QIcon(":/foss4g2007/
mActionZoomFullExtent.png"), \[]
[98] [99] [100] [101]
l.343   \includegraphics[scale=0.8]{getdsn}
l.353   \includegraphics[scale=0.8]{getdsn}
) [102] (help_and_support.tex [103
] [104]) [105]
(appendices/supported_data_formats.tex [106
] [107] [108]) (install.tex [109
Underfull \hbox (badness 7631) in paragraph at lines 92--94
[]\T1/phv/m/n/10.95 If you plan to do some de-bug-ging, you'll need to com-pile
 de-bug ver-sion of Qt:
[110] [111] [112] [113]
Underfull \hbox (badness 5533) in paragraph at lines 246--249
[]\T1/phv/m/n/10.95 Another pos-si-bil-ity is to run qgis.exe when your path co
n-tains c:$\OMS/cmsy/m/n/10.95 n$\T1/phv/m/n/10.95 msys$\OMS/cmsy/m/n/10.95 n$\
T1/phv/m/n/10.95 local$\OMS/cmsy/m/n/10.95 n$\T1/phv/m/n/10.95 bin and
(Font)              <14.4> on input line 258.
[114] [115] [116] [117] [118] [119] [120] [121] [122] [123] [124] [125]
[126] [127] [128] [129]
Underfull \hbox (badness 10000) in paragraph at lines 983--984
[]\T1/phv/m/n/10.95 when call-ing \T1/aett/bx/n/10.95 g++ \T1/phv/m/n/10.95 on
line 5 (which cre-ates libg-dal.dll), add these ar-gu-ments:
\T1/aett/bx/n/10.95 -L/usr/local/grass-6.3.cvs/lib -lgrass_-vect -lgrass_-dig2
-lgrass_-dgl -lgrass_-
\T1/aett/bx/n/10.95 rtree -lgrass_-linkm -lgrass_-dbmiclient -lgrass_-dbmibase
-lgrass_-I -lgrass_-gproj
[130] [131]
Underfull \hbox (badness 3189) in paragraph at lines 1090--1092
\T1/phv/m/n/10.95 We're done with prepa-ra-tion of MSYS en-vi-ron-ment. Now you
 can delete all stuff in
Underfull \hbox (badness 1132) in paragraph at lines 1113--1114
[]\T1/phv/m/n/10.95 Add \T1/aett/bx/n/10.95 %PlatformSDKDir%$\OMS/cmsy/m/n/10.9
5 n$\T1/aett/bx/n/10.95 Include$\OMS/cmsy/m/n/10.95 n$\T1/aett/bx/n/10.95 atl \
T1/phv/m/n/10.95 and \T1/aett/bx/n/10.95 %PlatformSDKDir%$\OMS/cmsy/m/n/10.95 n
$\T1/aett/bx/n/10.95 Include$\OMS/cmsy/m/n/10.95 n$\T1/aett/bx/n/10.95 mfc \T1/
phv/m/n/10.95 to the
[132] [133] [134]
Underfull \hbox (badness 10000) in paragraph at lines 1234--1236
\T1/phv/m/n/10.95 Get geos from svn (svn check-out http://svn.refractions.net/g
eos/trunk geos). Edit
[135] [136] [137]
Underfull \hbox (badness 1990) in paragraph at lines 1332--1333
[]\T1/phv/m/n/10.95 Install QGIS by build-ing the IN-STALL project. By de-fault
 this will in-stall to c:$\OMS/cmsy/m/n/10.95 n$\T1/phv/m/n/10.95 Program
[138] [139] [140] [141]
Overfull \hbox (4.01427pt too wide) in paragraph at lines 1525--1525
[]\T1/aett/bx/n/10.95 Library files: C:\Program Files\Microsoft Platform SDK fo
r Windows Server 2003 R2\Lib[]
Overfull \hbox (15.48982pt too wide) in paragraph at lines 1533--1533
[]\T1/aett/bx/n/10.95 C:\Program Files\Microsoft Visual Studio 8\VC\VCProjectDe
faults\corewin_express.vsprops[]
[142] [143] [144]
Underfull \hbox (badness 10000) in paragraph at lines 1693--1703
[]\T1/phv/m/n/10.95 Include files: $(QTDIR)$\OMS/cmsy/m/n/10.95 n$\T1/phv/m/n/1
0.95 include $(QTDIR)$\OMS/cmsy/m/n/10.95 n$\T1/phv/m/n/10.95 include$\OMS/cmsy
/m/n/10.95 n$\T1/phv/m/n/10.95 Qt $(QTDIR)$\OMS/cmsy/m/n/10.95 n$\T1/phv/m/n/10
.95 include$\OMS/cmsy/m/n/10.95 n$\T1/phv/m/n/10.95 QtCore
\T1/phv/m/n/10.95 $(QTDIR)$\OMS/cmsy/m/n/10.95 n$\T1/phv/m/n/10.95 include$\OMS
/cmsy/m/n/10.95 n$\T1/phv/m/n/10.95 QtGui $(QTDIR)$\OMS/cmsy/m/n/10.95 n$\T1/ph
v/m/n/10.95 include$\OMS/cmsy/m/n/10.95 n$\T1/phv/m/n/10.95 QtNetwork $(QTDIR)$
\OMS/cmsy/m/n/10.95 n$\T1/phv/m/n/10.95 include$\OMS/cmsy/m/n/10.95 n$\T1/phv/m
/n/10.95 QtSvg
/cmsy/m/n/10.95 n$\T1/phv/m/n/10.95 QtXml $(QTDIR)$\OMS/cmsy/m/n/10.95 n$\T1/ph
v/m/n/10.95 include$\OMS/cmsy/m/n/10.95 n$\T1/phv/m/n/10.95 Qt3Support $(LIB_-D
IR)$\OMS/cmsy/m/n/10.95 n$\T1/phv/m/n/10.95 include (needed dur-ing
[145] [146]
Overfull \hbox (4.01427pt too wide) in paragraph at lines 1760--1760
[]\T1/aett/bx/n/10.95 Download http://www.riverbankcomputing.com/Downloads/PyQt
4/GPL/PyQt-win-gpl-4.3.1.zip[]
[]\T1/aett/bx/n/10.95 From a Visual C++ command line cd to the directory where
you extracted PyQt4 and run:[]
[147] [148]) [149] (appendices/gpl.tex [150
] [151] [152]) [153] [154]
(appendices/qgis_qt_gpl_exception.tex) [155
] (literature.tex (user_guide1.bbl)
(user_guide2.bbl)) [156
] (index.tex
No file user_guide.ind.
Package natbib Warning: There were undefined citations.
Package bibtopic Warning: Rerun to get indentation of bibitems right.
Package natbib Warning: Citation(s) may have changed.
(natbib)                Rerun to get citations correct.
) (index.aux))
LaTeX Font Warning: Some font shapes were not available, defaults substituted.
LaTeX Warning: There were undefined references.
(\end occurred when \ifx on line 211 was incomplete)
Here is how much of TeX's memory you used:
 7614 strings out of 95338
 163801 string characters out of 1184089
 146838 words of memory out of 1500000
 7862 multiletter control sequences out of 110000
 51202 words of font info for 55 fonts, out of 1200000 for 2000
 14 hyphenation exceptions out of 8191
 46i,19n,50p,420b,420s stack positions out of 5000i,500n,10000p,200000b,5000s
Output written on user_guide.dvi (168 pages, 569284 bytes).
More information about the Qgis-community-team mailing list
