[Qgis-community-team] compiling manual & image quality
Werner Macho werner.macho at gmail.com
Mon Aug 24 05:27:40 EDT 2009
Hmmm
Well - you can use french version as a "sandbox" and try to change the
build from latex to pdflatex - but i guess it will be hard to port it to
trunk afterwards .. But at least we would know that it works ..
regards
Werner
> Le Monday 24 August 2009 11:14:20 Werner Macho, vous avez écrit :
>> Hi!
>> I'm with Carson .. It would not make any sense changing the wohle manual
>> procedure now ..
>> But for the next release it's a good idea to change to a "better" way of
>> compiling (at least the manual will be released in a better pdf quality)
>> regards
>> Werner
>> Qgis-community-team mailing list
>> Qgis-community-team at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Please, note that we are talking about the *french* traduction of the user
> guide, not about the trunk release ;) The french release is in
> docs/branches/1.0.0/french/user_guide of svn ;)
> May be that's not change anything?! Am I wrong if I say there is no problem to
> change the french user guide build process? and *then* see what we can do for
> the trunk release after 1.2.0 release.
> The french release won't be release before ... hum, end of september as we are
> still in the traduction process, well almost in the final proof reading
> process :)
> Regards,
> Y.
More information about the Qgis-community-team mailing list
