[Qgis-community-team] sec 8.2.1 - CRS automatically set by 1st loaded layer
Werner Macho werner.macho at gmail.com
Tue Jan 20 04:49:17 EST 2009
If you want I can take a closer look on chapter "Working with
Projections" as I run into troubles lately anyway.
So I just take the manual and look if everything is working as described
(expected).
Is there any solution to the .prj problems available or is it just a
thing of ESRI writing .prj out wrong?
regards
Werner
Otto Dassau schrieb:
> Hi Lars,
> On Mon, 19 Jan 2009 16:20:29 +0100
> Lars Stöwesand <lars at sai.uni-heidelberg.de> wrote:
>> Hi Tara and Otto - just found a description of a feature which is not
>> supported anymore: page 73: 8.2.1 Specifying a Projection
>> "QGIS automatically sets the map projection to the coordinate system
>> of the first layer loaded."
>> see: https://trac.osgeo.org/qgis/ticket/946
>> see also: https://trac.osgeo.org/qgis/ticket/967 (can be tricky when
>> creating a new layer (sec 5.4.4 ))
>> Is it possible to add/change it in the current manual?
> usually not, but I think this is an exception and since we haven't started the
> translation yet, I changed it in trunk, in the tagged version and the pdf.
> I changed quite a lot in that chapter to make the projection part hopefully
> clearer and it would be great, if some people can have a closer look at the
> chapter "Working with Projections" pp. 71. and check if I haven't made any
> mistakes. You find the PDF here:
> http://download.osgeo.org/qgis/doc/manual/qgis-1.0.0_user_guide_en.pdf
> regards,
>  Otto
>> Regards
>> /Lars
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
