[Qgis-community-team] sec 8.2.1 - CRS automatically set by 1st loaded layer
Carson Farmer carson.farmer at gmail.com
Tue Jan 20 06:00:01 EST 2009
Hi Otto et al.,
> usually not, but I think this is an exception and since we haven't started the
> translation yet, I changed it in trunk, in the tagged version and the pdf.
> I changed quite a lot in that chapter to make the projection part hopefully
> clearer and it would be great, if some people can have a closer look at the
> chapter "Working with Projections" pp. 71. and check if I haven't made any
> mistakes. You find the PDF here:
> http://download.osgeo.org/qgis/doc/manual/qgis-1.0.0_user_guide_en.pdf
I realise I'm coming in at a relatively late date, but reading through
the section 'Working with projections', I notice some of the terminology
is not quite right. In many cases, you refer to all CRS as projections,
when in fact the projection is really only one component of the CRS. The
coordinate (or 'spatial' as I prefer) reference system is a combination
of the ellipsoid used, the datum associated with that ellipsoid, and
some sort of geographic, or projection coordinate system. Of course the
projection also always has a geographic coordinate system associated
with it. There is a pretty good blog entry available here that does a
nice job of presenting this information:
http://www.sharpgis.net/post/2007/05/05/Spatial-references2c-coordinate-systems2c-projections2c-datums2c-ellipsoids-e28093-confusing.aspx
As an example of what I'm talking about, the first couple of paragraphs
should really read something like:
8 Working with Projections
QGIS allows *users* to define a global and project*-*wide CRS
*(Coordinate Reference System)*
for layers without a *pre-defined* CRS. It also allows *the user to
define custom coordinate reference systems*, and supports on-the-fly
(OTF) projection of vector layers. All these features allow you to
display layers with different CRS*,* and have them overlay properly.
8.1 Overview of Projection Support
QGIS has support for approximately 2,700 known *CRS*. *Definitions for
each of these CRS* are stored in a SQLite database that is installed
with QGIS. Normally you do not need to manipulate the database directly.
In fact, doing so may cause projection support to fail. Custom *CRS* are
stored in a user database.
See Section 8.4 for information on managing your custom *coordinate
reference systems*.
The *CRS* available in QGIS are based on those defined by EPSG and are
largely abstracted
from the spatial_references[1] table in PostGIS version 1.x. The EPSG
identifiers are present in the
database and can be used to specify a CRS in QGIS.
In order to use OTF projection, your data must contain information about
its coordinate *reference* system or you have to define a global, layer
or project*-*wide CRS. For PostGIS layers QGIS uses the spatial
reference identifier that was specified when the layer was created. For
data supported by OGR, QGIS relies on the presence of a format specific
means of specifying the CRS. In the case of shape-files, this means a
file containing the Well Known Text (WKT) specification of the CRS.
The projection file has the same base name as the shapefile and a prj
extension. For example, a
shapefile named alaska.shp would have a corresponding projection file
named alaska.prj.
8.2 Specifying a Projection
QGIS *no longer sets* the map CRS to the coordinate *reference* system
of the first layer loaded.
When you start a QGIS session with layers that do not have a CRS, you
need to control and define *the* CRS definition for these layers. This
can be done global*ly*, or project-wide in the...
where *bold* items have been added
[1] note the use of *spatial* reference here ;-)
I don't have the time right now to go through the rest, but I think it's
important to make sure that these things are correct. Many people will
be using QGIS as an initial foray into GIS, and IMHO it's important that
they start out using the correct terminology.
Cheers,
Carson
More information about the Qgis-community-team mailing list
