[Qgis-community-team] sec 8.2.1 - CRS automatically set by 1st loaded layer
Carson Farmer carson.farmer at gmail.com
Tue Jan 20 07:42:03 EST 2009
Hi Otto,
A few more quick changes:
*The* global default CRS proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
*comes* predefined *in QGIS,* but can *of course* be changed, *and the
new definition* will be saved for *subsequent* QGIS sessions.
If you want to define *the* coordinate reference system for a layer
*without CRS * information, you can
do this in the General tab of the raster (6.3.4) or vector properties
(5.3.1) dialog. If your layer already has a CRS *defined*, it will be
displayed as shown in Figure 6.
8.3 Define On The Fly (OTF) Projection
QGIS does not have OTF projection enabled *by* default*,* and *this
function* is currently only supported for vector layers. To use OTF
projection, ...
If you have already loaded a layer*,* and want to enable OTF projection,
*the best practice is to* open the
Coordinate Reference System tab of the Project Properties dialog and
find the CRS of the
*currently* loaded layer in the list of CRS*,* and activate the x Enable
on the fly projection checkbox.
All *subsequently loaded* vector layers will then be ...
1. Enable on the fly projection - this checkbox is used to enable or
disable OTF projection. When
  off, [1] each layer is drawn using the coordinates as read from the
data source. When on, the
coordinates ...
[1] several words deleted from here
... The cartographic parameters used with proj.4 *are* described in the
user manual*, and* are the same as those ...
Figure 18 shows the dialog with an example CRS. [2] The parameters shown
were entered based on a
knowledge of the CRS and the information found in OF90-284.
[2] in the pdf that you provided, there is no example CRS, is this an error?
More information about the Qgis-community-team mailing list
