[Qgis-community-team] switch to pdflatex is over
MORREALE Jean Roc jr.morreale at enoreth.net
Thu May 13 15:10:37 EDT 2010
Le 13/05/2010 21:07, MORREALE Jean Roc a écrit :
> Hi,
> The switch of the documentation trunk to pdflatex is over, there is
> some quirks we'll fix asap but most of the manual is correct.
> Main change is that there is no need to use makefiles anymore, if
> you're on unix you just have to follow these steps :
> $ pdflatex user_guide.tex which will ask for the biblio $ bibtex
> user_guide.aux for the bibliography (which needs to be feed) $
> pdflatex user_guide.tex to get the final pdf
> The TeX distribution that has been used is TeXlive 2009 [1], it works
> on Windows, MacOS X, linux and comes with a nice GUI called TeXwork.
> This editor allow to work with the PDF and the source side by side
> (click on the pdf to modify the corresponding tex part).
> One improvement would be to make better screen capture, many can't be
>  placed into the tex and have to be put at the end of the section
> because of their size but they often have a lot a useless space. My
> advice would be to resize your windows and uncheck useless toolbars
> when taking a capture
> With these changes any contributor can obtain an updated manual in
> 2mn (well if you don't count the texlive's download).
> Regards, MORREALE Jean Roc
> [1] http://www.tug.org/texlive/acquire-netinstall.html
> _______________________________________________ Qgis-community-team
> mailing list Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
I've forgotten to add that the work has only been done on the user guide
so, well, the siwtch may not be fully over. I'll do the coding guide later.
Oh and and here is the updated pdf ->
https://svn.osgeo.org/qgis/docs/trunk/english_us/user_guide/user_guide.tex
More information about the Qgis-community-team mailing list
