[Qgis-community-team] Coding and compilation guide 1.6.0
Otto Dassau dassau at gbd-consult.de
Mon Jan 17 03:52:54 EST 2011
Hi Jean-Roc,
would be nice, if you have time, but it is not so important at the
moment, because most people are not really interested in its translation
yet.
Regards,
 Otto
Am Mon, 17 Jan 2011 09:44:01 +0100
schrieb <jr.morreale at enoreth.net>:
>  Sorry, I didn't saw it was that one. Is a port needed ?
>  On Mon, 17 Jan 2011 09:40:40 +0100, Otto Dassau <dassau at gbd-consult.de>
>  wrote:
> > Hi,
> > the coding and compilation is not moved to pdflatex. So you need
> > ImageMagick's convert installed, as Jürgen wrote.
> > Regards,
> >  otto
> > Am Fri, 14 Jan 2011 09:38:03 +0100
> > schrieb MORREALE Jean Roc <jr.morreale at enoreth.net>:
> >> Le 13/01/2011 22:40, emperor Stef a écrit :
> >> > Hello !!!
> >> > I am trying to build the translation and I get errors when typing
> >> > "make" ... specifically I get make[2]: convert: Command not found
> >> > make[2]: *** [cpp1_application.eps] Error 127
> >> > It does not compile at all... I get the same error when I type
> >> "sudo
> >> > make"
> >> > Why is this happening?
> >> > Regards,
> >> > Stefanos
> >> Hi, converting to *.eps is not necessary since we moved to pdflatex.
> >> Copy the following line in .sh file and it should be ok :
> >> #! /bin/sh
> >> cd /home/user/path/to/QGIS/1.6/user_guide/
> >> # clean the folder of previous builds
> >> rm -rf *.aux *.bbl *.blg *.idx *.ilg *.ind *.lof *.log *.lot *.toa
> >> *.toc
> >> *.synctex*.gz *.html *.4ct *.4tc *.css *.dvi *.idv *.tmp *.xref *.lg
> >> # build the manual with bibliography and index
> >> pdflatex user_guide.tex
> >> bibtex user_guide
> >> makeindex -cl -o user_guide.ind user_guide.idx
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Geoinformatik Büro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support  and analysis
Davenstedter Str. 60  ,  D - 30453 Hannover , Germany
Phone:  +49-(0)511-2615322 ,  Fax: +49-(0)511-2615323
Community Advisor - QGIS Project Steering Committee
More information about the Qgis-community-team mailing list
