[Qgis-community-team] QGIS Docs in GIT
Otto Dassau dassau at gbd-consult.de
Sat Nov 12 03:43:39 EST 2011
Hi Jean Roc, all,
Am Fri, 11 Nov 2011 23:27:53 +0100
schrieb MORREALE Jean Roc <jr.morreale at enoreth.net>:
> Le 10/11/2011 23:30, Tim Sutton a écrit :
> > Hi Otto&  other community members
> > I have migrated the documentation to git. Please have a play around
> > and see if everything is as expected before you start doing any
> > serious work. Otto and I will probably do some more tweaks over the
> > hackfest this weekend. The repository is available here:
> > git at github.com:qgis/QGIS-Documentation.git
> > Best regards
> > Tim
> Hi, this is great. I'll create a french_fr folder at the root level when
> the translation of the manual 1.7 is over.
> I guess we will not longer create branches for a new version but only
> add git tag, right ?
what I have in mind / on the todo list is:
- create QGIS-Documentation repository (done)
- add trunk from svn (done)
then, we probably should migrate also the tags and branches to keep all the
work we have done so far in the new git repository. Or does it make more
sense to leave it in svn or to create a backup and close svn docs repo? I
don't know but would prefer to still have it all available in the git
environment.
then we need to define how to structure the docs repo in the future. How
should it be managed?
in svn:
- english master in trunk
- english tagged versions in tags
- translation in branches
in git:
And we need to update all the howto documentation in the wiki.
Is that all?
Regards
Otto
More information about the Qgis-community-team mailing list
