[Qgis-community-team] automatically create substitutions for icons in global.rst
Larissa Junek junek at gbd-consult.de
Thu Jul 5 02:30:56 PDT 2012
On Thu, 5 Jul 2012 10:36:45 +0200
Otto Dassau <dassau at gbd-consult.de> wrote:
> Hi,
> I also agree and would leave it in conf.py. This makes it easier for
> new translators/writers to work on the manual. Keep it simple is very
> important since contributors often change - I think.
> Regards
> Otto
> Am Wed, 4 Jul 2012 22:28:09 +0200
> schrieb Diethard Jansen <diethard.jansen at gmail.com>:
> > Yes, maybe you are right.
> > I am finishing the replacements in an hour. It could take a few
> > hours to program the python program. I have seen quite a lot
> > substitutions in conf.py that definetely are used just in on rst. I
> > will put all my substitutions in top of the rst document when
> > others find they can use it as well it can be transferred to
> > conf.py. I guess in the document working_with_vector.rst you will
> > find the majority, so just have a look there first.
> > regards, Diethard.
> > 2012/7/4 Paolo Corti <pcorti at gmail.com>
> > > On Wed, Jul 4, 2012 at 6:32 PM, Diethard Jansen
> > > <diethard.jansen at gmail.com> wrote:
> > > > Hi,
> > > > Yesterday I started with adding some substitutions for icons
> > > > used in the
> > > RST
> > > > file I am working on.
> > > > 'working_with_vector.rst' contains many! It is not too hard
> > > > but.. to
> > > include
> > > > them only in the document I am working on.
> > > > I found that substitutions for Icons like |nix| are defined in
> > > > conf.py,
> > > but
> > > > I do not like the idea of adding the new definitions in there.
> > > > On the following interesting site I found an alternative way.
> > > http://packages.python.org/an_example_pypi_project/sphinx.html#substitutions
> > > > The idea:
> > > > I want to automatically create a global.rst using a python
> > > > script to
> > > include
> > > > all substitutions to images of icons in there.
> > > > The script will search and include all png files < 8 kb that
> > > > will be
> > > found
> > > > under directories "img/en/".
> > > > In the latex script most substitutions are equal to the icon
> > > > name so it should not be too hard to generate this file.
> > > > The advantage is that you only need to to include a single
> > > > 'include' line referring to the global.rst file and most of the
> > > > icons should show up immediately after the build. Another
> > > > advantage is that you can remove
> > > most
> > > > of these substitions from config.py so it is less cluttered and
> > > > it does
> > > not
> > > > need to be changed too often which (I believe) could break the
> > > > build process. It is also an easier place to find the
> > > > substitutions. A disadvantage could be that in a few places the
> > > > reference needs to be
> > > changed
> > > > in the rst file because it was not equal to the name of the
> > > > file. (i.e.
> > > in
> > > > rst file -> |labeling|  however the image::
> > > ../img/en/mActionLabeling.png,
> > > > so in that case I will need to change it to |mActionLabeling|).
> > > > Whatever, I will write the python script. I am sure the result
> > > > can also
> > > be
> > > > quickly included in the config.py instead of the global.rst.
> > > > Let me know when you see a problem with this idea.
> > > > Regards,
> > > > Diethard
> > > Hi
> > > the idea would be to have a common place where to store
> > > substitution only for images that are in many pages.
> > > I believe that a big part of the ones that now are in conf.py are
> > > used only once in the user guide, so it would make sense to me to
> > > leave in conf.py only the images that are used more times, and
> > > place the other to each single page.
> > > p
> > > Paolo Corti
> > > Geospatial software developer
> > > web: http://www.paolocorti.net
> > > twitter: @capooti
> > > skype: capooti
I see a problem proceeding like this.
Not only that now we have a complicated procedure to include the
icons, it will be difficult to check which icon is used only once and
which icon is not. I would like to go on as is and define the icons in
the conf.py. We are nearly finished with the migration of the user
guide it won't take a long time to define the icon in the conf.py...
Kind regards,
Larissa
More information about the Qgis-community-team mailing list
