[Qgis-community-team] enumeration for figures
Diethard Jansen diethard.jansen at gmail.com
Tue Oct 9 14:02:29 PDT 2012
There is a directive for conditional output!
.. only:: html
   This text will only be printed in HTML not in PDF!!
We can use this as follows:
.. only:: html
   Figure Subject 1
.. _figure_subject_1
.. figure:: /static/user_manual/subject/a_figure.png
   :align: center
   :width: 30em
   This is the caption of a figure (not preceded anymore with
   Figure Subject 1:)
I am pretty sure this is a working solution but also a lot of work to
change!
I think I just have managed to finish putting all figures & icons back in
the manual since the reconstruction of the manual which took place in
Essen.
Regards, Diethard Jansen
2012/10/9 Larissa Junek <junek at gbd-consult.de>
> Hello Richard and all,
> I had a look a the build now and found a new issue.
> Working on the pathes for the images I saw that the scripts create a
> pdf with automatic numeration not only for the headlines but also for
> the images. Now we have a doubled caption in there, e.g.:
>  Figure 23.1: Figure Attributes 2: Field Calculator
> Figure Attributes 2 is the caption we inserted manually in the
> rst-files, Figure 23.1. is created automatically.
> The problem is that we need the manually created caption for the html
> where until now there's no enumeration neither for the headlines nor
> for the images.
> Will it be the best to use only a caption without a numeration for the
> images? Or will there be another solution? This way we don't have a
> numeration for the figures in html.
> Kind regards,
> Larissa
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20121009/b1752904/attachment.html>
More information about the Qgis-community-team mailing list
