[Qgis-community-team] enumeration for figures
Larissa Junek junek at gbd-consult.de
Tue Oct 16 01:23:24 PDT 2012
Hi Diethard and Otto,
using Diethards suggestion I found out that if we insert the expression
later in case of linkage you are linked also to the headline of the
figure:
.. _figure_browser_import:
.. only:: html
   **Figure browser 1**
.. figure:: /static/user_manual/qgis_browser/browser_import_shapes.png
   :align: center
   :width: 40em
   Drag and drop shapefiles with QGIS browser |nix|
This way you can call the reference and you will be linked to **Figure
browser 1**.
What do you think about my suggestion? If you agree with me I will
insert it into the README.
Kind regards, Larissa
> Hi Diethard and Larissa,
> the solution for html and pdf figures works well I think. It is of
> course again some work to adapt it, but I would suggest we change it.
> Regards
> Otto
> Am Tue, 9 Oct 2012 23:02:29 +0200
> schrieb Diethard Jansen <diethard.jansen at gmail.com>:
> > Hi,
> > There is a directive for conditional output!
> > .. only:: html
> >    This text will only be printed in HTML not in PDF!!
> > We can use this as follows:
> > .. only:: html
> >    Figure Subject 1
> > .. _figure_subject_1
> > .. figure:: /static/user_manual/subject/a_figure.png
> >    :align: center
> >    :width: 30em
> >    This is the caption of a figure (not preceded anymore with
> >    Figure Subject 1:)
> > I am pretty sure this is a working solution but also a lot of work
> > to change!
> > I think I just have managed to finish putting all figures & icons
> > back in the manual since the reconstruction of the manual which
> > took place in Essen.
> > Regards, Diethard Jansen
> > 2012/10/9 Larissa Junek <junek at gbd-consult.de>
> > > Hello Richard and all,
> > > I had a look a the build now and found a new issue.
> > > Working on the pathes for the images I saw that the scripts
> > > create a pdf with automatic numeration not only for the headlines
> > > but also for the images. Now we have a doubled caption in there,
> > > e.g.:
> > >  Figure 23.1: Figure Attributes 2: Field Calculator
> > > Figure Attributes 2 is the caption we inserted manually in the
> > > rst-files, Figure 23.1. is created automatically.
> > > The problem is that we need the manually created caption for the
> > > html where until now there's no enumeration neither for the
> > > headlines nor for the images.
> > > Will it be the best to use only a caption without a numeration
> > > for the images? Or will there be another solution? This way we
> > > don't have a numeration for the figures in html.
> > > Kind regards,
> > > Larissa
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Geoinformatik Büro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support  and analysis
Ackerstrasse 144c  ,  D - 40233 Düsseldorf  , Germany
Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
More information about the Qgis-community-team mailing list
