[Qgis-community-team] enumeration for figures
Otto Dassau dassau at gbd-consult.de
Tue Oct 16 02:06:44 PDT 2012
Hi Larissa,
good idea. Please go ahead.... :)
Thanks
Otto
Am Tue, 16 Oct 2012 10:23:24 +0200
schrieb Larissa Junek <junek at gbd-consult.de>:
> Hi Diethard and Otto,
> using Diethards suggestion I found out that if we insert the expression
> later in case of linkage you are linked also to the headline of the
> figure:
> .. _figure_browser_import:
> .. only:: html
>    **Figure browser 1**
> .. figure:: /static/user_manual/qgis_browser/browser_import_shapes.png
>    :align: center
>    :width: 40em
>    Drag and drop shapefiles with QGIS browser |nix|
> This way you can call the reference and you will be linked to **Figure
> browser 1**.
> What do you think about my suggestion? If you agree with me I will
> insert it into the README.
> Kind regards, Larissa
> > Hi Diethard and Larissa,
> > the solution for html and pdf figures works well I think. It is of
> > course again some work to adapt it, but I would suggest we change it.
> > Regards
> > Otto
> > Am Tue, 9 Oct 2012 23:02:29 +0200
> > schrieb Diethard Jansen <diethard.jansen at gmail.com>:
> > > Hi,
> > > There is a directive for conditional output!
> > > .. only:: html
> > >    This text will only be printed in HTML not in PDF!!
> > > We can use this as follows:
> > > .. only:: html
> > >    Figure Subject 1
> > > .. _figure_subject_1
> > > .. figure:: /static/user_manual/subject/a_figure.png
> > >    :align: center
> > >    :width: 30em
> > >    This is the caption of a figure (not preceded anymore with
> > >    Figure Subject 1:)
> > > I am pretty sure this is a working solution but also a lot of work
> > > to change!
> > > I think I just have managed to finish putting all figures & icons
> > > back in the manual since the reconstruction of the manual which
> > > took place in Essen.
> > > Regards, Diethard Jansen
> > > 2012/10/9 Larissa Junek <junek at gbd-consult.de>
> > > > Hello Richard and all,
> > > > I had a look a the build now and found a new issue.
> > > > Working on the pathes for the images I saw that the scripts
> > > > create a pdf with automatic numeration not only for the headlines
> > > > but also for the images. Now we have a doubled caption in there,
> > > > e.g.:
> > > >  Figure 23.1: Figure Attributes 2: Field Calculator
> > > > Figure Attributes 2 is the caption we inserted manually in the
> > > > rst-files, Figure 23.1. is created automatically.
> > > > The problem is that we need the manually created caption for the
> > > > html where until now there's no enumeration neither for the
> > > > headlines nor for the images.
> > > > Will it be the best to use only a caption without a numeration
> > > > for the images? Or will there be another solution? This way we
> > > > don't have a numeration for the figures in html.
> > > > Kind regards,
> > > > Larissa
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Geoinformatik Büro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support  and analysis
Ackerstrasse 144c  ,  D - 40233 Düsseldorf  , Germany
Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
Community Advisor - QGIS Project Steering Committee
More information about the Qgis-community-team mailing list
