[Qgis-community-team] added script to build only english master
Otto Dassau dassau at gbd-consult.de
Tue Oct 16 11:08:52 PDT 2012
Am Tue, 16 Oct 2012 19:06:33 +0200
schrieb Richard Duivenvoorde <richard at duif.net>:
> On 10/16/2012 05:55 PM, Otto Dassau wrote:
> > Hi,
> > if you only want to update the english master document and see what it
> > looks like in html or pdf, you can now use the script master_build.sh.
> > This way it doesn't take so much time.
> Hi Otto,
> the pre_translate script is there to update po files. If you only want
> to BUILD a clone from github, it is sufficient to run the post_translate
> script with the parameter 'en' as locale (or another one if you only
> want to build your own locale)
> ./scripts/post_translate.sh en
> Or am I missing something? If not I would suggest to remove the
> master_build.sh script. Maybe will add it to the readme also
> Regards,
> Richard
Hi Richard,
good - i missed that, please remove it again and add some notes to the
readme file.
thanks
Otto
More information about the Qgis-community-team mailing list
