[Qgis-community-team] manuarl pdf refs broken
Alexander Bruy alexander.bruy at gmail.com
Fri Oct 26 02:13:39 PDT 2012
Hi Richard and all,
for me PDF build didn't work at all, texi2pdf just failed to build
doc. If anyone interested, I can provide logs
2012/10/26 Richard Duivenvoorde <richard at duif.net>:
> Hi,
> since I changed the index.rst for the doc-project from a manual-rst to a
> more general index, all references in the pdf output is broken. Html output
> is still doing fine.
> Any Sphinx-guru available to dive into this?
> Is it someting in sources/conf.py that can be easily fixed?
> Or is it because we are using one conf.py for all sub-systems?
> I will try out some options, but was wondering if there was maybe someone
> available with better Spinx knowledge,
> Regards,
Alexander Bruy
More information about the Qgis-community-team mailing list
