[Qgis-community-team] whee warning free
Diethard Jansen diethard.jansen at gmail.com
Sun Oct 28 22:43:34 PDT 2012
Hi Richard,
Pity, we both worked on same warnings. It's not easy to get going again when a git merge fails. Maybe we should also include some advice how to prevent and solve these situations. Same happened to me last week :( . I decided to undo last commit (not pushed yet).
Regards,
Diethard
Op 29 okt. 2012 om 02:12 heeft Richard Duivenvoorde <richard at duif.net> het volgende geschreven:
> Just cleaned up the last warnings from the documentation build proces
> (EDIT: that was before some (for me unmergable) new commits :-) )
> Some remarks from that:
> - one warning was about referencing to figures in other rst files: it looks (to me) if that is not possible. As Otto proposed, we maybe should not try that, but refer to the section which holds the figure (that is how I solved that warning)
> - dvi2png warning: although I had a succesfull pdf and html build, there was still some warning about dvi2png path. After installing it that one was solved BUT I'm not sure if it is actually needed???
> (I added it in the index.rst)
> - the 'release disclaimer' is working a little different then proposed. Please consult the working example in conventions.rst
> I also hope that others also can build the pdf docs, and not that I'm the only one (together with Otto and the documentation server) who can succesfully build those)
> With me it is actually ending with:
> /usr/bin/texi2dvi: pdflatex exited with bad status, quitting.
> Not sure what that means...
> Richard
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
