[Qgis-community-team] whee warning free
Richard Duivenvoorde richard at duif.net
Mon Oct 29 01:04:51 PDT 2012
On 10/29/2012 07:15 AM, Tim Sutton wrote:
> Are you guys talking about sphinx warnings or pdflatex warnings? It
> would be good to set up a Jenkins job to check for sphinx warnings and
> red flag commits that introduce new warnings. If folks are interested, I
> will look into that when I have a sec.
Jenkins job +1 :-)
I was talking about Sphinx warnings, just run the
'scripts/post_translate.sh nl' command.
Currently there are only some new warnings in the release-2.0.rst of
which I think you are in the middle of transition
For pdflatex there are (I think) real problems:
- pdf does not have a table of contents (toc) anymore
- pdf does not have working (internal) references anymore
- ending with "/usr/bin/texi2dvi: pdflatex exited with bad status,
quitting.'
We have to work out this problems. I'm not very familiar with the
doc-tree/source.py dependancy. But the pdf is broken since I created the
top index.rst (actually changing it from a copy of the index.rst of
user_manual to the current one).
I'm wondering if we not should change the build scripts in a way that we
actually build one doc (manual, intro, govern.., cookbook, guidelines)
at a time, instead of the sphinx-build in the root for all docs. BUT we
still want to have the possibility to do inter document referencing.
This would nog only save time for devs testing and building a doc, but
(hopefully) also make it possible to let every doc have it's own
'side-bar' with it's own toc. While currently all docs share the
top-level side-bar. A doc with it's own toc in the sidebar will be much
more friendly.
I think it should be possible. Python docs are also not build in one go,
and refering to classes in other modules. We just have to find the way
Regards,
Richard
More information about the Qgis-community-team mailing list
