[Qgis-community-team] doc translation
Werner Macho werner.macho at gmail.com
Fri Apr 12 10:35:17 PDT 2013
add the upstream repo
howto merge
you could take some things from NathanW blog
http://nathanw.net/2013/02/05/my-qgis-git-workflow/
I'll add and improve some things for running several versions of qgis side
by side in linux afterwards
thanks a lot
Werner
On Fri, Apr 12, 2013 at 7:33 PM, Otto Dassau <dassau at gbd-consult.de> wrote:
> Am Fri, 12 Apr 2013 19:23:45 +0200
> schrieb matteo <matteo.ghetta at gmail.com>:
> > > I amnot sure, if it will be in a very short time, so a good
> documentation
> > > would be nice. Could you have a look? If it is all fine, even better.
> > I hope it will take not so long (git is a sort of monster.... :-) ).
> > I write some documentation for git: it 's just a list of commands, here
> > an example:
> > *fork and clone*
> >   * fork the repo from github.com
> >   * from github set the manual_en_v1.8 as the default branch
> >   * clone the repo (on your computer go on the the folder you want, e.g
> >     cd /home/user/Document) and in a terminal write **git **clone*
> >     *https://github.com/ghtmtt/QGIS-Documentation.git**
> > Do you mean it can be useful?
> > Cheers,
> > Matteo
> yes, maybe with code example
> clone the repo ...
> git clone ...
> and so on
> Thanks a lot!
> Otto
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130412/4ea8887f/attachment.html>
More information about the Qgis-community-team mailing list
