[Qgis-community-team] update from translated files
Otto Dassau dassau at gbd-consult.de
Mon Apr 22 01:18:27 PDT 2013
Am Mon, 22 Apr 2013 09:47:04 +0200
schrieb matteo <matteo.ghetta at gmail.com>:
> Hi Otto,
> > error 1 means, there is a start-string wouthour an end-string. This can
> > have many reasons, Try to compare the english and the italian text to
> > find out, what might cause the warning. If you don't see, you could send
> > the two paragraphs and we have a look.
> thanks for the reply... I looked into the file but I haven't find out
> the problem...
> Can I send the file so we can together find the solution?
> What file do you need (rst source or italian po)?
> Thank you
> Matteo
We would need the paragraph from the .po file with the line, where the error
occurs.
Regards
Otto
More information about the Qgis-community-team mailing list
