[Qgis-community-team] Looking for help to update the englisch manual (Otto Dassau)
Otto Dassau dassau at gbd-consult.de
Thu Jul 4 00:48:10 PDT 2013
Hi Hien,
I haven't heard from you again after I sent you the list of features, that
need to be added to the print composer? Are you still interested to work on
it? Do you have questions or problems to start?
Kind Regards
Otto
Am Fri, 14 Jun 2013 12:19:00 +0200
schrieb Otto Dassau <dassau at gbd-consult.de>:
> Hi Hien,
> if you have a look at the manual task list:
> http://hub.qgis.org/wiki/17/ManualTasks#Updates-QGIS-20-User-Guide
> There are several features listed for chapter "print composer" at the
> bottom now. I added your name to the lines and extended the list to what I
> think needs to be added/updated for the print composer.
> * snap to left/mid/right coordinates of other items when moving composer
>   items for alignment
> * custom linestyle for composer grid
> * add support to SVG images from url
> * new element "add html frame"
> * Support for creation of map atlasses (new tab)
> * possibility to show composer map grid coordinates in
> degree/minute/seconds
> * Multipage compositions
> * split legend in several columns
> * Display rectangle of another composer map (overview map)
> * Zebra style for composer grid (black/white pattern at borders)
> * New Rendering menu with several blending modes (here Larissa has more
>   information)
> * General new structure of the item property tab for all elements
> * describe item ID feature in element tab (was already in 1.8)
> I would suggest you start using the master branch and send pull requests
> for your changes, so we can have a look. Is that ok for you?
> Thank you very much for your help and don't hesitate to ask, if there are
> questions.
> Regards
> Otto
> Am Fri, 14 Jun 2013 11:40:55 +0200
> schrieb Hien TRAN-QUANG <hien.tranquang at gmail.com>:
> > Hello,
> > I'm replying to Otto's call for help on the QGIS users mailing list.
> > I just started helping translating the 1.8 manual in French at FROG's
> > Code Sprint a few days ago.
> > I would like to help you release new QGIS 2.0 as soon as possible. So
> > here I am.
> > My preferences go to print composer, so if someone can tell me which
> > features I can work on.
> > Hien TRAN-QUANG
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Geoinformatik Büro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support  and analysis
Ackerstrasse 144c  ,  D - 40233 Düsseldorf  , Germany
Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
Community Advisor - QGIS Project Steering Committee
More information about the Qgis-community-team mailing list
